11-18-2011, 08:30 AM
#511 |
Old Guy nOOb
Oddometer: 2,686
Clock with seconds display
Has anyone found a clock display on the Oregon 450 that displays seconds? This is the 1st GPS I have ever had that did not have a good clock display. It seems a shame to only have 1 minute resolution on a clock that should be accurate to better than a microsecond
It isn't the conditions its the decisions Don't bring a motorcycle to a car fight |
11-18-2011, 02:07 PM
#512 | |
Procrastinators
Oddometer: 5,778
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
11-20-2011, 01:11 PM
#513 |
Old Guy nOOb
Oddometer: 2,686
I knew somebody on advrider would be smart enough to know the answer.
01-22-2012, 04:11 PM
#514 |
LD-Ordie
Oddometer: 369
Thanks to all who have contributed to this thread, a wealth of information has been shared here!
I've been pretty happy with my 376C, then later, adding a 60CSX. But after my wife got hooked on Geocaching, I decided to add either the Montana or the Oregon to my gadgets. As much as I liked the Montana,I just can't justify the extra expense right now, so even with the known USB issue, after reading this thread, I decided to go with the 550T. Most of my usage will be on a road bike and a 4-wheel drive, so I don't think 'llI have the vibration issues discussed here. Thanks again to all for giving me the tools to make the right decision
There are no problems that cannot be resolved with the proper application of explosives ! Jim Member of "Team Pterodactyl" Combat Touring!! 05-FJR 1300 05-650 Dakar 03-1150 GS Sport 70-FLH Shovelhead 50-FL Panhead 76- Bultaco 370 Pursang 98-Yamaha TW200 84-Yamaha TT-600 56-650 Triumph T-120, needs work...... 1964 Land Rover Series IIA Gotta have at least one car
01-25-2012, 03:25 AM
#515 |
Procrastinators
Oddometer: 5,778
Garmin Oregon x50 (WebUpdater) software version 5.30
http://www8.garmin.com/support/downl...ls.jsp?id=4523 Change History Changes made from version 5.20 to 5.30:
04-23-2012, 10:11 AM
#516 |
In my Pajama pants
Oddometer: 681
Route Problem
Hopefully someone can help me with this problem. I have read an not found a solution.
I have a problem that the Oregon 200 that I have always recalculates the route once on the gps. I have a route downloaded from the internet that looks great in both Mapsource and Bacecamp. These are routes with few waypoints but with many turns. When I load the route on the gps it immediately recalculates the route to a different route than is shown on the computer. Is there anyway to make it keep the same route? What settings do I have wrong? I am on the latest 4.20 firmware. I have tried adding waypoints in the past and also translating the route into a track and following that. There should be a better way. Thanks for your help.
Bikes I own 2008 Yamaha WR250R 1992 Yamaha XT225 |
04-23-2012, 01:36 PM
#517 |
Wannabe
Oddometer: 1,242
There is no way of avoiding the recalc that I am aware of. Add (way) more waypoints (called via points) to your route to keep it more true to the original. Or create a track from it and follow the track...
2008 Suzuki DRZ400S |
04-25-2012, 08:49 PM
#518 | |
Oddometer: 90
And also a thanks out to Emmbeedee as well for a wealth of real world experience, not just opinion. Great posts by both you guys. Thanks.
TS 250 KSM |
04-26-2012, 03:22 AM
#519 | |
Procrastinators
Oddometer: 5,778
I just noticed, there's been a few software updates for the Oregon. Must update my wife's 550 to the latest. Changes made from version 5.40 to 5.50: Improved GPS response at low speeds. Fixed potential issue when exiting geocache descriptions Changes made from version 5.20 to 5.40: Added Geocaching with Photos (http://garmin.blogs.com/softwareupda...th-photos.html) Fixed potential naming issues with imported routes from BaseCamp Fixed issue with 'Hut' point type in TOPO Australia & New Zealand maps Fixed issue with magnetic north offset when projecting a waypoint Fixed issue with track log recording while using the stopwatch Fixed mass storage issue when used without batteries http://www8.garmin.com/support/downl...ls.jsp?id=4523
04-30-2012, 07:58 AM
#520 | |
In my Pajama pants
Oddometer: 681
I have found that I have trouble using Basecamp for some of the things that I want to do and Mapsource does them easier. Basecamp does some things that Mapsource won't though. I now feel that I can make routes that actually work.
05-02-2012, 06:56 AM
#521 | ||
Oddometer: 107
Thanks for the feedback, indeed like Emmbeedee says, it's good to know it's useful to others :) Still using this baby, and now almost a year with it I'm still a super happy user. Even if I'm a gear freak, I don;t even feel the need to look for what's out there now in terms of GPS devices, because this little wizard does everything I need it to :) Quote:
Invisible Shield by ZAGG, bought on Amazon here ![]() I initially put it to protect the screen but it's possible that it helps reading it with sunglasses on too - I wouldn't know as I never used the GPS without the screen, put it on right out of the box. Maybe if you can afford it, a $15 trial of the screen to see how it fairs with your sunglasses on could be a solution ? Even if you end up selling the Oregon off, this screen is a must have and will be a great addition for the person who buys the GPS from you. Unlike other screens I've tried on my phone and other devices before, this screen cak take ANYTHING. Believe it or not, there is not a single scratch on it after riding in dirt, rocks and crappy weather, and carrying the GPS around in pockets and bags with all sorts of other items (keys, tools, pens, random crap that finds its way in my pockets..) Oh and I always use the Oregon with brightness at the max. (and energy saving option ON). Hope this helps ! O'Ren screwed with this post 05-02-2012 at 07:02 AM |
05-02-2012, 01:33 PM
#522 |
Oddometer: 3,978
Yes quite simple. LCDs use polarization to work, therefore you should not use polarized sun glasses or goggles. Reflected glare is mostly horizontal polarization so all these lenses are vertical polarization to block it. Any time you use two cross polarized lenses, it blocks most of the light. Just use tinted lenses and they will work fine.
Jerry Counts |
05-27-2012, 05:22 AM
#523 |
Procrastinators
Oddometer: 5,778
New Beta Release for the Oregon X50 Series:
Changes made from version 5.50 to 5.60: Added new route activity types and improved BaseCamp compatibility. See TrailTech (http://garmin.blogs.com/softwareupda...th-garmin.html) for more information. Added support for Kenwood NMEA Waypoint Sentence Improved GPS response at low speeds Fixed issue with preserving routes imported from Basecamp (identical maps required) Fixed Spell Search in German Problems with this software may be reported to OregonBeta@garmin.com
07-09-2012, 06:53 AM
#524 |
DumbA$$
Oddometer: 699
Hi, I am just looking for some updates in regards to the hardwire mini-usb situation. I have decided to go with an Oregon 450 that I can get for $250. The next best thing is the Montana, but I dont want to spend that much right now, so Oregon it is.
I have read through this thread completely, and really the only drawback seems to be that silly mini-usb. It looks like some hardwire/USB solutions fit tighter and seem to hold up better? I already have the 3BR Powersports TAPP USB so a USB power seems to make the most sense. So, to those with the Oregon still, how are the mini USB's holding up? Does the 3BR one seem to hold up best or ??? Thanks! DAVE
2009 R1200RT-P Swapped for an Impala2009 R1200GSA Sold!2011 Ural Gobi GU |
07-09-2012, 11:18 AM
#525 | |
Wannabe
Oddometer: 1,242
When I use my Oregon on my DRZ, it's run on battery power simply because I don't yet have a 12V power source on it. In my experience, I wouldn't exclude the Oregon 450 from my GPS choices simply because of the mini-USB.
