Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
Old 01-12-2009, 03:35 PM   #31
Gunslinger1
GIVE'R
Oddometer: 633
As all the rest are just waterproof car, soccer mom GPS's
Gunslinger1 is offline   Reply With Quote
Old 01-12-2009, 04:10 PM   #32
BigDogAdventures
Fart Letter
BigDogAdventures's Avatar
Oddometer: 5,134
I swore I'd never make a comment on what gps to use ever again as I just don't give a ratsa** what anybody else uses.
But it's nice to get some backup----Mr. Breese---with a capital M
They don't want to know what I really think do they
bigdogadventures.com
2008 Yamaha WR250R/2006 KTM 450EXC/2014 KTM690/2013 Husky 650 TR650
BigDogAdventures is online now   Reply With Quote
Old 01-12-2009, 06:40 PM   #33
fotobo
KTM rider
fotobo's Avatar
Oddometer: 1,636
Having to keep using my 276 is definitely not a problem for me.
"I don't want a pickle, I just wanna ride on my motorsickle" (Arlo Guthrie)
fotobo is offline   Reply With Quote
Old 01-16-2009, 04:58 AM   #34
NorthernTraveler
Long time Adventurer
NorthernTraveler's Avatar
Oddometer: 482
+1 on the 276c
After reading Big Dog and Gaspipe's write up of the western TAT in '06 I had to do it!
One of the pieces of gear I picked up to accomplish this goal was a Garmin 276c.
I guessed my old Garmin eMap just wasn't going to make it....
Spent the time to map it out, loaded it up and away I went. Got'er done!
That 276 served me well.... was so far out there at times I would have been in serious trouble if it went down - which it NEVER did!
TAT solo, the western end in Sept and Oct... through the early snow.
Had to buy a spare this past year....
Now I've reworked my routes and the 276c is the ONLY Garmin that will let me put the whole TAT in at once.... and the CDR at the same time!
So, definitely a +1 on the Garmin 276c! Thanks Big Dog!
NorthernTraveler is offline   Reply With Quote
Old 01-16-2009, 05:28 AM   #35
AugustFalcon
AugustFalcon's Avatar
Oddometer: 1,058
Originally Posted by NorthernTraveler
Now I've reworked my routes and the 276c is the ONLY Garmin that will let me put the whole TAT in at once.... and the CDR at the same time!...
Why was that?
I have a 276C, getting ready to do the TAT and thought about upgrading to a 478 since it appears to offer more. So, I am now wondering, based on your comment, if I shouldn't bother.
Which map products did you use for you TAT and CDR plots?
AugustFalcon is offline   Reply With Quote
Old 01-16-2009, 05:34 AM   #36
BigDogAdventures
Fart Letter
Oddometer: 5,134
Originally Posted by AugustFalcon
Why was that?
In terms of map loading, waypoint, track log and route functions the 478 is the same---------you will gain no navigational functions.
The 478 just has additional non navigational stuff.
I always load 3 different mapsets in my 276 and turn on the one that suits the situation. I load topo-----the very old Roads and Recreations---and then an autorouting mapset too (there are many versions of that out there).
Old 01-16-2009, 05:53 AM   #37
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,913
The 276c, 376c and 478 are basically the same units with some minor differences like the 376c XM radio/WX weather and the 478 adding CN loaded into its memory. These 3 are considered to be the best GPS's available for us Adventure riders!
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 01-16-2009, 06:28 AM   #38
NorthernTraveler
Oddometer: 482
TAT route in 276c
I just looked and my complete TAT route set (one route per day) has 2389 waypoints (every turn on Sam's roll charts are in there along with gas and motel points) using 25 routes (I have some of the optional routes too).
Loading Road and Rec, Topo 2008 and Metroguide NA v8 (no unlock codes) it takes right around 123MB with 283 maps. Haven't had a chance to load it into the GPS to make sure it handles that many map segments - I'm in the sandbox and the GPS is at home - but I think it will.
This is just the TAT.
I also have Big Dog's CDR route (thanks Mark!) that I've reworked slightly and that takes 290 waypoints, 5 routes and 138 maps totaling 73MB. But there is some overlap with the maps for the TAT, so it should all fit OK.
One thing that I've run in to... the 276 will allow 300 waypoints per route. Most other GPS's won't. I also have a 172c that I'm going to play with... but it only allows 250 waypoints per route... but has a bigger screen, lower res and no battery.
I wish somebody had a spreadsheet for GPSs showing # of routes, # waypoints per route, # tracks, # waypoints per track, total # points for the main tracklog, max # of maps, screen size, screen res.
Would be handy to compare them......
Old 01-16-2009, 06:45 AM   #39
BigDogAdventures
Fart Letter
Oddometer: 5,134
All maps you load---go into the data card only on the 276---not in the gps itself.
So you can load as many MB's as your data card is big.
Nothing else goes to the data card----only maps.
And if you didn't know--the 276 holds 3,000 waypoints--these are stored in the unit---and cannot be stored on the data card.
You might be able to upgrade (free) the unit software and make routes hold more route waypoints.
Hope i'm not telling you stuff you already know.
Old 01-16-2009, 10:36 AM   #40
NorthernTraveler
Oddometer: 482
Yeah, on the 276 the maps go into the data card, but there still is a limit on the number of map segments - so there is really two limits - MB size and number of map segments.
That is one of the problems of Road and Rec - it has quite small map segments, which is good for older GPS's with small memory, but to cover a larger area it takes LOTS of map segments.
If you look at Metroguide or even Topo 2008, the area covered in a map segment is much larger - so it takes fewer segments to cover the same amount of area.
Yep, the 276c allows 3000 user defined waypoints... with the current GPS system software for the 276 (5.30) and the current good version of Mapsourse (6.13.7, not the latest - 6.14.1 is buggy) when you create a route you can have 'route' waypoints (otherwise known as via's) that don't count against your user defined waypoints. These via's do count against the number of waypoints in a route however.
For example, if you define two waypoints, one at the start of a route and one at the end, then using the routing tool connect them together using say 100 vias, you have only used 2 waypoints out of your 3000 waypoints, and you have used one route out of your 50.
The 60 and 76 series only allows something like 1000 user defined waypoints.... way too few for what I want to do.
Another problem with some of the other models.... some only allow 50 waypoints in a route. Who are they trying to kid? Sheesh!
On the 276 all waypoints, routes, tracks and tracklogs go into internal memory while only maps go onto the data cards. On some of the newer GPSs they allow the tracks and tracklog to go onto the data card, everything being stored the same as the 276.
I think what I'm going to do when I go to do some really extended wandering is to load several data cards up to cover vast areas for maps, then put waypoints, routes and whatever else else I need on a thumb drive along with EasyGPS. Just swap data cards to have the maps I need for an area, then upload new routes and waypoints as needed off the thumb drive using a public computer. No need to carry a laptop that way, and you can download back to the thumb drive if you want to save your tracks.
NorthernTraveler screwed with this post 01-16-2009 at 10:49 AM
Old 01-20-2009, 08:43 AM   #41
MotoJim
MotoJim's Avatar
Oddometer: 226
Garmin Doesn't Get or Want Motorized Offroad Travel
Sometimes we have to observe the obvious. Garmin is moving away from the functionality that supports motorized offroad travel.
I can't believe they are removing all the track log functionality from new units because they are stupid. It's not because they are unaware of our need for the functionality because I have told them as have many others.
How hard would it be for them to add the functionality of the Lowrance Baja 540C which supports 100 track logs of 10,0000 track points each on the instrument? That's all I need to make any of the #76 or #78 units a near perfect gps for offroad motorized travel.
Our demographics don't give us enough purchase to effect change with Garmin.
MotoJim is offline   Reply With Quote
Old 01-20-2009, 10:21 AM   #42
Countdown
Oddometer: 5,921
Why do they look at it as a "Black Box" not a computer/controller and offer verioius firmware downloads depending on your application? Or even open it up to 3rd party firmware writers. It is not that hard to develop a hardware platform that is desireable to all but there are as many firmware options as there are customers.
Jerry Counts
Countdown is offline   Reply With Quote
Old 01-20-2009, 10:23 AM   #43
EmmEff
Oddometer: 1,786
I'd love to see them open it up... wonder if there aren't already some hacking projects to replace the built-in firmware.
The hardware capability is certainly there for everything we want to do, but Garmin doesn't see fit to provide the capability.
2001 F650GS Dakar
2008 DR-Z 400S
EmmEff is offline   Reply With Quote
Old 01-27-2009, 12:21 PM   #44
RL Lemke
RL Lemke's Avatar
Oddometer: 1,596
Is the new Garmin GPSMap 640 the answer?
Maybe the new ultimate motorcycle GPS is the new Garmin GPSMap 640. Garmin's site says it is: "Automotive/motorcycle-friendly: yes"
Great screen, waterproof, XMWX ready, ....
What's missing is a Touratech mount.
https://buy.garmin.com/shop/shop.do?cID=148&pID=14898
RL Lemke
Dallas, Texas
RL Lemke is online now   Reply With Quote
Old 01-27-2009, 12:27 PM   #45
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,913
It is not as good as the 276c, 376c and 478. There is already a big discussion on this. http://www.advrider.com/forums/showthread.php?t=421999
Times are GMT -7.   It's 02:34 PM.
