Old 01-09-2009, 07:17 AM   #1
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,967
Question Alternative fuel pumps for FI KTM990
I've been held up getting back to this project. If anyone has a bad stock 990 pump that is willing to send it in, I'd like to take one apart.
I've got a few 990 tank blank off plates to swap on an external pump in the works. Keep you posted w/ updates.
Has anyone installed one on a 990. I'm looking into making a fuel tank adaptor plate to use a pump on a FI bike and just want to make sure it would work first. Much cheaper than replacement KTM pumps.
I'd like to mount it outside the tank in the area that the 950 fuel pumps were mounted.
I'm sure it's only a matter of time before these start to go. FI is here to stay so let's deal w/ it.
I'd hate to be in the middle of nowhere and have to drain my tank to pull this pump.
I don't have a 990 to work w/ or on so that's where I need your help.
If you think it's a waist of time say so.
Stock pump:
61007088100FUEL PUMP 06$540.00
I'd think if an external pump for about $75-100 would work, a regulator if need be and an adaptor plate would work for about $200-250 it would be worth while. From then on all you would need is a new pump if it fails.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer screwed with this post 01-04-2013 at 03:10 PM
cjracer is offline   Reply With Quote
Old 01-09-2009, 08:28 AM   #2
Yzlvr
Oddometer: 845
I like the idea, I have the 990, maybe tahoeacr can help.
Yzlvr is offline   Reply With Quote
Old 01-09-2009, 09:14 AM   #3
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
What is the fuel rail pressure set at on the 990? usually on most modern cars it is ~40psi or so. I don't think that it does any dynamic pressure regulation either.
something like this Summit pump universal unit
and a regulator
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind screwed with this post 01-09-2009 at 09:44 AM
Head2Wind is offline   Reply With Quote
Old 01-09-2009, 09:16 AM   #4
990S Pilot
Is this round trip?
990S Pilot's Avatar
Oddometer: 232
I don't think it'd be a waste of time, I'm interested in a cheaper solution. Since this is a potential failure point I'd like to have a relatively inexpensive solution I could carry as a spare to more remote areas.
990S Pilot is offline   Reply With Quote
Old 01-09-2009, 09:29 AM   #5
aurel
Cheese&Wine!
aurel's Avatar
Oddometer: 3,687
Your link is not working. Here is the good one
In 20 years you'll only regret what you didn't do.
World Tour finished! http://www.the-great-adventure.fr
aurel is offline   Reply With Quote
Old 01-09-2009, 10:01 AM   #6
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
I fixed it....
Old 01-09-2009, 10:14 AM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
From what I have found so far, and I have been looking at this for the non EFI (950) for a while now, it is going to be ~300 or so to come up with a complete replacement solution with a external pump with return fuel regulation inclusive of a interface plate for the 990 fuel tank. it could be field installed, however I think that replacing the stock system with a improved external system would be my preference rather than trying to fix it in a remote area.
total system components:
fuel pump: ~$100
regulator: ~$100
990 tank plate: ~$50 (total guess)
fuel filter: ~$20
various fittings and hoses: ~$30
thoughts CJ? am I way off costs? is there another way?
I know that the FI in my old CBR600 FI tank mounted pump (and many other M/C systems) just dead headed to the fuel rail without return fuel to the tank like in a car, so maybe return fuel and adjustable FPR is not necessary.
Old 01-09-2009, 10:26 AM   #8
Dusty
Dusty's Avatar
Oddometer: 1,287
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 01-09-2009, 11:03 AM   #9
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,967
Ya, I guess you're correct. I didn't figure in the fittings, filter and stuff.
This is what I made to fit my Aqualine tanks after finding the the peice of inner tube rubber they give you as a seal failed, only to find about 5 gallons of fuel on the garage floor in morning. Good thing I don't smoke.
I'm not 100% sure this would fit on a 990, but it work on these tanks meant to fit the stock pump.
After looking into the cost of materials and time, about $50 sounds real close for the plate and viton O-ring.
An older model pump from a FI sport bike like you said might work.
If someone needs a plate and wants to run w/ this idea testing pumps and whatnot let me know. I could make another up for test purposes, before I make a larger batch.
I would think that this "kit" would be put on "Before" the stock dies if heading out on a long trip. If anything just carry another pump, easier to install like the 950 version.
fuel pump: ~$100
regulator: ~$100
fuel filter: ~$20
Would something like this bolt on to the stock tanks?
Old 01-09-2009, 11:28 AM   #10
aurel
Cheese&Wine!
aurel's Avatar
Oddometer: 3,687
I think it would fit.
Old 01-09-2009, 12:03 PM   #11
amaunu
amaunu's Avatar
Oddometer: 127
Does Facet have pump in their production line? I guess FI is not that sensitive to pressure variation if flow rate and adequate mean pressure is achieved. What is good for aeroplane is definetly out KTM engineers mind.
a--
KTM Adv 1190
KTM RC8 tracktoy
Gsxr 600 Project
amaunu is offline   Reply With Quote
Old 01-09-2009, 12:11 PM   #12
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,924
Could one of these work...
http://facet-purolator.com/index.php...d=43&Itemid=65
Cheers.
gefr is online now   Reply With Quote
Old 01-09-2009, 12:48 PM   #13
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,368
Try finding a Bosch FI pump off a '68 or so VW Type-III. They are a remote mount pump with a return ciruit that allows excess fuel to be cycled back through the tank to prevent vapor lock. All you will need is a return line to the tank - which should be easy.
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 01-09-2009, 02:53 PM   #14
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,967
Found this after a quick search, any idea if any of these look correct?
http://www.rockauto.com/catalog/rafr...c1280157k58625
Old 01-09-2009, 03:01 PM   #15
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,368
Originally Posted by cjracer
...any idea if any of these look correct?
Nope. The beattle was carbed. Try a 73 S-bug, I think that's when they went FI...
~ Ken
Times are GMT -7.   It's 12:13 AM.
