Old 05-23-2013, 02:14 PM   #151
pilacs
pilacs's Avatar
Oddometer: 72
Thumb
Interested 990 ADV
pilacs is offline   Reply With Quote
Old 05-23-2013, 02:52 PM   #152
willh
willh's Avatar
Oddometer: 42
Interested, SD 990
willh is offline   Reply With Quote
Old 06-23-2013, 05:53 AM   #153
Bowser
Oddometer: 168
Interested 990 adv
Bowser is offline   Reply With Quote
Old 06-23-2013, 07:24 AM   #154
renogeorge
Oddometer: 1,390
I don't have an opinion on which thread goes where. But I will pass on that I have installed the GEFR pump and filters on my 2007 ADV. It is working fine. Same design as stock--easy install and way cheaper.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 06-24-2013, 08:29 AM   #155
willh
willh's Avatar
Oddometer: 42
Link to this other thread please.
Old 06-24-2013, 12:02 PM   #156
Hootowl
Oddometer: 1,259
Send a PM to the OP of this thread. Looks like he's out on a ride
http://www.advrider.com/forums/showthread.php?t=874262
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is online now   Reply With Quote
Old 06-24-2013, 02:32 PM   #157
willh
willh's Avatar
Oddometer: 42
Thanks,
Those filters look good but I need an external pump. Will get in touch with CJ when it's time to pull the trigger.
Will
Old 06-24-2013, 02:42 PM   #158
Hootowl
Oddometer: 1,259
Thanks,
Will
The guy who sells the filters also sells the pumps (Gefr)
'07 990A
'12 Super Tenere
Old 06-24-2013, 03:46 PM   #159
renogeorge
Oddometer: 1,390
Yep. His pump is the OEM style in-the-tank, with stock filter setup. I am using his pump and filters. Cheap enough, you could change them often.
KTMs--300, 518, 990
Old 08-18-2013, 06:06 AM   #160
willh
willh's Avatar
Oddometer: 42
Looking for the whole Cannondale setup but not having much luck. Did anyone come up with an external pump kit for the 990?
Old 02-07-2015, 05:20 PM   #161
JesseVn
Oddometer: 7
Resurrecting an oldie.
Has anyone come up with an external fuel pump option to replace the 990 in-tank one?
Thanks.
JesseVn is offline   Reply With Quote
Old 02-08-2015, 08:59 AM   #162
guglemonster
Oddometer: 294
like many times over discussed, you are riscking too much with en external in-line fuel pump on a motorbike.
we have, thanks to all in-mates, many different solutions, pump filters copy of the original ones, nicely priced fuel pump, neck fuel filters.
all this makes the external fuel pump an issue only if you think the eventuality of piercing the Left tank on some remote trip, otherwise, no need to worry
Fuel cap filter
guglemonster is offline   Reply With Quote
Old 02-08-2015, 10:45 AM   #163
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,328
My project will rely on external feed and automotive sized filter.
I need to be able to service my filter and pump without the clumsy fueltank work.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 02-08-2015, 11:41 AM   #164
JesseVn
Oddometer: 7
Right. Those are alternatives that work with the stock tanks.
My project involves a new tank design and I don't have the luxury of internally mounting the fuel pump.
Hence, my question.
I'm open to any suggestions and alternatives.
Cheers!
Old 02-08-2015, 02:31 PM   #165
guglemonster
Oddometer: 294
beware vapour lock, heat, pump blow-up, hose clogging (from tank feed)
have to alo have a separete back-loop line from the external pressure regulator
Amp absorption lower than 5,5/6 A
keep us posted :)
Fuel cap filter
Times are GMT -7.   It's 08:46 PM.
