08-01-2009, 02:06 PM
#46 | |
Gravity flailer
Oddometer: 5,828
08-02-2009, 07:37 AM
#47 |
Oddometer: 1,670
One experience I had
I jumped a bit ahead - so forgive me if it's been said. I had a fuel starvation issue on my car and every time I stoped and restarted it was fine. After a few miles it would starve out again. Did this for 100 mi. What it was was a very fine (powder sized) particulate that would clog the filter, then when I stopped it would fall off the filter. I took the tank out and emptied the fuel into a garbage can. At first it looked fine, but closer inspection I could see the powder (I believe it was rust). Put in new fuel and was fine for several years. It did it again later. But in both cases I remember filling when the delivery truck was there.
Great work on the replacement pump research.
My 950KTM makes me feel like a little kid again......because it's so tall! |
08-02-2009, 08:40 AM
#48 | |
SE990R
Oddometer: 1,928
Sounds like the ol' "sugar in the tank" trick...
~ Ken |
08-03-2009, 01:00 PM
#49 | ||
Orange Invader
Oddometer: 431
Here's a link from another thread that might have parts that will help or provide information/inspiration: http://www.fuelsystem.co.uk/filters.pdf Good luck and keep us posted. Respect for actually trying something. |
08-03-2009, 06:44 PM
#50 |
Oddometer: 228
Here;s what I eneded up doing
Hey Sp4ce,
here's what I ended up doing http://www.advrider.com/forums/showthread.php?t=492100 Sitting down friday night and then shopping around on Sat...there was a lot of work basically redesigning the top of the fuel pump that houses the small filter, fpr and outlet gallery for the TB's. And as you correctly pointed out, many brackets to hold it all together under pressure for no that much gain..imo. Only issue, with the way I ended up going, is that how I did the post pump cannibalized paper filter...i did cut it so that the clearance was 0 (to the roof of chamber) so the filter couldn't raise off the outlet(offcentre hole) but there is a possibility of the bottom of the pleats flaring under pressure...oh well...will take it apart after the weekend and see how it handles the run. another 3 days of riding to work(320k's) then another 1000 over 2 days this weekend. So will be able to see how it's going by the end. Worst comes to worst I'll just remove the paper filter and rely on the inline filter above airbox. fpr shouldn't have an issue. On another note re everyone's failed pumps...did any of you notice the condition of each of the filters? Could it be that the post pump paper filter IS the problem if it gets clogged with either water, dirt OR both? And that it may not be the pump or the sock filter? Just throwing it out there.... Shawty |
08-04-2009, 04:08 AM
#51 |
UP FOR IT
Fuel
What Does Mounting The Pump Externally Do To The Fuel Capacity ?
08-05-2009, 10:16 PM
#52 | |
Life is a trip
Oddometer: 3,114
That is another issue, criminal I would describe it...
There is always a reason!! |
08-05-2009, 10:21 PM
#53 | |
ow, my balls!
Oddometer: 4,604
Riding the Americas: No Fumar Español - Terminado. ![]() _____________________________________________ |
08-06-2009, 04:54 PM
#54 |
AWD please!!
Oddometer: 3,866
I'm going to try and make 2 more of these blank of plate I use on my Aqualine tanks for testing. If anyone is interested in one let me know. If I put a standard pipe tap threads in for a barb fitting that would be the easiest.
Let me know, I'll see if I can dig up some material. If I ever get a 990 I'd want the pump and prefilter setup "outside" the tank.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
08-06-2009, 07:28 PM
#55 |
Oddometer: 838
I would take one.
08-06-2009, 09:19 PM
#56 | |
AWD please!!
Oddometer: 3,866
When you get it, you need to use it for something or pass it on to someone that will. I'm going to try and get 2 made up in time for the ID KTM Rally. If you'll be there I'll give it to you then. Otherwise I'll send it to you when I get home. What Size NPT thread would work the best. What kind of fittings are you going to use? Post up some pics.
08-12-2009, 09:07 PM
#57 |
Oddometer: 1
Fuel Pump Issues
Hi Everyone, My Friend On A 650 Vstrom Had Similar Fuel Issues As You Are Explaining, The Bike Would Run 20 Min. And Then It Wouldn't Have Enough Power To Maintain Highway Speeds. I Traced This Problem To Alcohol Enriched Fuel. (natures Friendly Fuel, Not) When We Run Any Other Fuel Without Alcohol The Bike Has No Problems, I Feel The Alcohol Evaporates Too Fast Within The Pump And Then Causes An Air Lock, When You Turn The Engine Off, It Clears And Then It Takes About 20 Minutes For It To Build Up Again. Try Running Non Alcohol Fuels In Your Bikes And See If The Problem Goes Away. Good Luck.
08-18-2009, 12:01 PM
#58 |
SE990R
Oddometer: 1,928
Aeromotive...
I ordered one of these last night to try on my SE950R fuel injection conversion. I'll let everyone know how it holds up...
![]() Also got one of these to handle the fuel pressure and allow overage to return to the tank...
~ Ken |
08-18-2009, 01:14 PM
#59 | |
MotorcycleMayhem
Oddometer: 2,158
EDIT: additional considerations: the system pressure at the veins of the pump is going to be 15-45 psi so this will also increase the "boiling point" of the Alcohol well beyond the "normal pressures" boiling point of ~180F.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind screwed with this post 08-18-2009 at 01:21 PM |
08-18-2009, 11:31 PM
#60 |
Oddometer: 2,170
Powercell,
I hope it works better for you than I. Nothing but crap from Aeromotive. Couldn't get there pumps to last even a month. Good thing is if you ordered it from Summit or Jegs, they will take it back when it goes South. |
