08-18-2009, 11:48 PM
#61 | |
SE990R
Oddometer: 1,928
Hey Tahoe, what model pump did you use? What type of failures did you experience? What did you use for a pressure regulator?
~ Ken |
08-19-2009, 07:38 AM
#62 | |
MotorcycleMayhem
Oddometer: 2,159
suggested alternative? Walbro?
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
08-19-2009, 09:05 AM
#63 | |
Oddometer: 1,547
that's way too much pump. you're going to heat the fuel when it circulates excessively. unless you lower the voltage supplied. I've had experience with aeromotive external pumps. they DON'T like being run dry so take that into consideration when mounting. what's the output of the stock pump? I think it would be much better to use a walbro intank pump. they are OEM quality and will last a long time.
Alan 2011 KTM RC8R 2012 BMW S1000RR 2000 Kawasaki ZRX1100 |
08-19-2009, 09:13 PM
#64 | |
Oddometer: 2,170
I prefer in line Bosch or Walbro. I've had 100% success with these. |
08-24-2009, 07:57 AM
#65 | |
Oddometer: 4,923
PowerCell,
Please me updated on your findings. I am using an FI engine (Kawi 650) in my project bike that will be equipped with the 4 tanks from a carbed 660 Rally and I am not sure which way to go yet. I'll probably need a surge tank, inline fuel pump and a return style pressure regulator (45psi) as well. Quote:
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
08-24-2009, 09:09 AM
#66 |
Oddometer: 1,547
I used an A1000 for about 10k miles. I had its predecessor (same design)for about 40k miles. I upgraded because it was not adequate for the HP I was making (550rwhp).
you must run the filter AFTER the pump.
08-24-2009, 09:13 AM
#67 | |
MotorcycleMayhem
Oddometer: 2,159
09-18-2009, 10:36 AM
#68 |
SE990R
Oddometer: 1,928
OK, here's an external pump that might help the 990 guys out. It's a Keihin product found on a Honda quad. Puts out 70 liters per hour at 2.4 amps. Includes a pickup filter and is very easy to service. Cost from Cheapcycleparts was $115. The only problems I currently see is the internal pressure regulator is set to 42psi, but I think it will be pretty simple to bump it up to 51. And the other problem is where to install it?
~ Ken |
09-30-2009, 03:25 PM
#69 |
SE990R
Oddometer: 1,928
If anyone has a dead 990 fuel pump that they no longer need (or care to look at), can you send me a PM. I'm looking for parts off the orginal unit for an experiment I've got going on my SE.
Also, I might have a lead on a cheap fuel filter that would be a factory fit, and I'd like to check it out and see if everything will fit correctly...
~ Ken |
09-30-2009, 09:05 PM
#70 | |
Life is a trip
Oddometer: 3,125
Could this pumps' motor fit in the OEM pump system?
There is always a reason!! |
09-30-2009, 09:47 PM
#71 | |
SE990R
Oddometer: 1,928
What pump are you referring to Gefr?
~ Ken |
09-30-2009, 10:24 PM
#72 |
Life is a trip
Oddometer: 3,125
The OEM 990Adv
Isn't that the one you are trying to find a replacement for?
There is always a reason!! gefr screwed with this post 09-30-2009 at 10:31 PM |
09-30-2009, 11:51 PM
#73 | |
SE990R
Oddometer: 1,928
No, I'm working on something completely different, but keeping an eye out for 990 solutions that might help others...
~ Ken |
10-01-2009, 02:44 PM
#74 |
MotorcycleMayhem
Oddometer: 2,159
I have a Denso pump out of a CBR600F4i that I have been chasing around trying to find spec's to no avail. Denso doesn't list it as a replacement so no pump graphs/details. Price might be better that the KTM part, however this latest unit that PowerCell is showing looks promising.
PowerCell, what are the dimensions of the "cell" that contains the pump and bits? there is a low lph Walbro out there too, might be interesting to pursue, however does not have the integrated pressure regulator.
10-01-2009, 02:50 PM
#75 |
SE990R
Oddometer: 1,928
It's about 6" tall, by 4" wide...
The smallest Walbro you want to run is the GSL393 at 160 LPH. The GLS395 (130 LPH) is only good for about 30psi...
~ Ken |
