Old 02-28-2010, 02:53 PM   #91
bkshovel
Old Adventurer
bkshovel's Avatar
Oddometer: 118
Ok fellas, fer us dumb ol' country boys that speak psi. instead of nm. What kind of pressure are you talking about? If I understand correctly the pump you're working with puts out 43gph at 45psi free flow. I gather that' not enough. Summit sells a pump that is 43gph at 85 psi free flow, part # sum-g3138. It's also cheaper, $81.95. I've had good luck with Summit's stuff as far a quality. It looks like a twin brother measures 1.87 x7.25. Probably comes out of the same factory. This with a bypass regulator and a return line to the tank to keep the fuel and pump cool? Am I out of line?
bkshovel is offline   Reply With Quote
Old 02-28-2010, 04:18 PM   #92
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
just so us other ol' country folk are not misunderstood, you cannot have "free flow" and 45psi of pressure.... in that if you have a open hose to atmosphere coming from the output of the pump I would call that "free flow" with no head pressure on the pump. In my understanding this is the pumps full on capability to move X number of Liter/Gallons of fuel per minute/hour. So, as described, the Summit pump will flow/pump 43 gallons per hour at a 85 pounds per square inch pressure. Which in this application, given the horse power rating of the engine, this pump would be able to deliver enough fuel to the injectors/engine to support the roughly 100 horse power that the LC8 produces. HOWEVER, we still need to REGULATE that pressure down to a usable level, in this case the stock pressure is 3.5 bar (50.7632082 pounds per square inch), so if we chose to use a fuel pressure regulator that is set at 3.0 bar (43.5113213 pounds per square inch) the fuel rail pressure would be reduced by roughly 7.2 PSI, a ~4.3% reduction in pressure, will result in a reduction of flow through the injectors.
So we either chose to create a system that bleeds the pressure off into the tank prior to the fuel rail or we do it at the end of the fuel rail, which in most cases for high performance (IMO) is best (end of rail pressure regulation/dump/drainback). The stock system dumps the fuel directly back into the tank at the pump assembly, and "dead heads" the fuel rails at the injectors. So the only fuel that flows is the fuel that is injected, which can lead to higher fuel temperatures at the point of injection and all the fun that comes along with that.... Again, in a high(er) performance application, cool(est) fuel and cool(est) air is best for maximum performance with current fuels and technologies. third beer for the day watching the hockey game so I might be off a bit.....
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 02-28-2010, 05:43 PM   #93
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,371
I run a custom adjustable pressure regulator set at 51 psi...
~ Ken
www.powercellperformance.com
PowerCell is online now   Reply With Quote
Old 02-28-2010, 07:31 PM   #94
bkshovel
Old Adventurer
bkshovel's Avatar
Oddometer: 118
Thanks Powercell. That's what I was asking.
Old 02-28-2010, 09:26 PM   #95
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,371
These are a direct drop-in into the Cannondale FPR housing...
http://www.eurospecsport.com/product...regulators.htm
~ Ken
Old 03-01-2010, 12:50 AM   #96
madbiker1
Evilman
madbiker1's Avatar
Oddometer: 162
I just pulled a fuel regulator out of a 1992 BMW 325i with an e36 engine that looks exactly like that. 3.5 bar I believe as well.
madbiker1 is offline   Reply With Quote
Old 03-08-2010, 07:51 AM   #97
jeremyk
jeremyk's Avatar
Oddometer: 91
Not sure if this has been mentioned yet, but running at a lower pressure will screw up air/fuel ratios under "open loop" operation (i.e. full throttle). In closed loop, the O2 sensors will likely detect the lean condition created by not enough fuel (~40 PSI vs ~ 50 PSI) and may be able to correct. However, most FI systems go into an open loop mode under full throttle and no longer use O2 feedback. They use "fixed" look-up tables in the ECU to determine proper air/fuel ratio and those tables are based on a assumption of 50 PSI fuel pressure.
jeremyk is offline   Reply With Quote
Old 05-03-2012, 06:53 PM   #98
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,173
I thought I'd bring this back to life.
A few years have past and I was wondering if any reliable solutions have been used and if these could be shared with everyone.
Thank you in advance!
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 05-03-2012, 07:17 PM   #99
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,927
I haven't abandoned research yet.
According to my findings there are plenty of replacement fuel pumps with the needed diameter of 38mm. Length is usually shorter at the large dia part, but can fit. The same goed for the connections area and the intake side. Small modifications are needed but not to difficult. The major obstacle is the power consumption. All the car fuel pumps I saw have power consumption close to 6Amps. This prooves too spendy for our electrical corcuit. So when driving in traffic and the fan comes on, the voltage plunges and the motor starves from fuel. I have yet to find a fuel pump with car fuel pump dimensions and motorcycle fuel pump consumption close to 3,2amps rated at 3,5bar and flowing 35lit/hour. Most of these little babies come in smaller packages. Maybe they can fit with some transormation. Still searching.
Cheers.
Old 05-03-2012, 09:48 PM   #100
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Gefr, i know i replied to your query on my thread that i never had any issues with voltage drop on the toyota fuel pump retrofitted into the stock assembly on my 990 but now that i think of it, my dual battery setup might have had a hand in this. It might have prevented the loss of pumping capacity when the radiator fan kicked in.....
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 05-04-2012, 12:49 AM   #101
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,927
Hey guys, this is tough.
Thanks Vicks
I ask for fuel pump specs and the chinese feed me with whatever they have in hand.
I start leaning to the possibility of using a 3bar fuel pump, as long as it draws close to 3,2Amps. I think I saw such a pump. I think It is worth it even if the dia=30mm.
I am contacting suppliers that say they can upgrade fuel pressure to 3,5bar on items they quote at 3.0bars.
Cheers.
Old 05-04-2012, 06:03 AM   #102
jeremyk
jeremyk's Avatar
Oddometer: 91
One trick to get more power to the pump would be to use a relay in the circuit (triggered by the stock fuel pump "hot" wire) and run a dedicated, larger diameter wire from the battery to the relay to the pump. This might be enough to take care of the drop in power when the fan comes on.
Old 05-04-2012, 10:51 AM   #103
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,927
You think?
I didn't think of that. When it comes to electrics I am totally numb.
Thnx.
Old 05-04-2012, 08:24 PM   #104
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
The limiting factors could be either the crappy stock wiring (quite a few ppl have reported about changing out the wiring completely with higher gauge copper wires) OR the stock battery capacity being just enough to handle the FI and electronics on the bike. It does not hurt to just replace the FI pump wire with a higher gauge one and check if that helps.
You can also ensure that the battery is fully charged up and then see if the pump still stumbles when the rad fan kicks in. By this you can eliminate these causes and narrow down the issue.
Old 05-05-2012, 01:34 AM   #105
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,927
I have a voltmeter installed
I read:
14,2V engine running, no lights
13,8V lights on
13,2V lights on + heated grips
12,4V lights on + heated grips + fan on but it is not stable and plunges occasionally under 12V.
gefr screwed with this post 05-05-2012 at 02:20 AM
Times are GMT -7.   It's 03:41 PM.
