12-31-2012, 05:23 PM
#121 |
Oddometer: 1,433
A side benefit of the external filter/pump is an approx 1/2 gallon of extra fuel capacity.
2008 KTM 990 Adv & 2007 KTM 640 Adv |
01-01-2013, 10:34 AM
#122 | |
Dans le doute...gaz!
Oddometer: 1,720
but you already knew that
The race is long and, in the end, it's only with yourself...
01-04-2013, 12:42 AM
#123 | ||
Oddometer: 408
Re: the filters, they didn't really look that dirty, so no I'm thinking that the available surface area for the sock filter especially may be just too small? I'd bet a filter of similar width, but with added thickness and length would significantly improve filter longevity and performance. Looks like there is plenty of room for that.Quote:
I'd also be interested in an external pump/filter system. Disassembly and reassembly of the internal unit was not rocket science, but it does take a while, expecially with crash bar removal, etc. I'd be nice to simply detach a few lines and go.
01-04-2013, 04:39 AM
#124 | |
Life is a trip
Oddometer: 3,108
Cheers.
There is always a reason!! |
01-04-2013, 01:48 PM
#125 |
Ktooner
Oddometer: 17
OE Fuel Pump price increase
Just an FYI. KTM has increased the price on the 990 fuel pump to $540.00 from $495.00. The 690's fuel pump prices have also jumped to $391 for the pre '11 models and to $525 for the '11 and up. So the need for alternatives gets even greater! Thanks for the effort so far from those working on solutions.
06 KTM 200XCW, 07 KTM 990 Adventure S, 86 Honda Nighthawk S
dirtyac screwed with this post 01-05-2013 at 06:24 AM |
01-16-2013, 04:39 PM
#126 |
AWD please!!
Oddometer: 3,865
Got the 990 SD fired up last night with the new setup!
FPR needs to be dialed in, but it runs. That's a plus. It's been so cold and icing around here I'm a little fearful of a new bike with slicks out on the road. Might have to mount up some knobbies, or stud the tires.........
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! cjracer screwed with this post 01-16-2013 at 05:44 PM |
01-16-2013, 04:59 PM
#127 | |
Oddometer: 1,720
01-16-2013, 05:42 PM
#128 |
мотоциклист
Stories from the Seat Facebook My Photos Cannonball Charity Ride No Four Wheel Drives, No Fixers and No Fricken Whingers |
01-16-2013, 05:43 PM
#129 |
Oddometer: 1,020
Originally Posted by d0gWateR Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider! |
01-16-2013, 05:47 PM
#130 |
Oddometer: 1,720
Thanks. I'm familiar with them. On the 990s, it's inside the tank with the fuel pump. Hence the question
01-16-2013, 06:04 PM
#131 |
AWD please!!
Oddometer: 3,865
Should be up to 38F on Thurs and Fri.
If the glacier recedes from the driveway, I'll take is for a test spin.Best chance before it's down to -5F this weekend.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
01-16-2013, 06:51 PM
#132 |
мотоциклист
Ah clearly I misunderstood the question. :)
01-20-2013, 08:50 AM
#133 |
AWD please!!
Oddometer: 3,865
![]() Yesterday I got out on the test bike for a lap around the neighborhood. This bike was in a front end crash with a car. 3,200 miles. Front rim is bent - won't hold more than 20 psi when tire is cold (20F). Radiator was smashed - I fit a 950 ADV Radiator in for test purposes. Oil tank was cracked - welded that back up to seal it. Hung the headlight back on with a few bolts and zip ties. No point to stick a bunch of money in this as a test "RAT" bike. I've got other ideas for that in the future. As long as it runs and is ride able, I'm happy. I have more adaptor plates made, o-ring sealed to the tank with pick-up and return line fittings. I'm running a CPR filter kit on the bike so I have room to fit the external Filter, Pump, FPR. The FI light is blinking and I need to look it over for vacuum leaks and confirm SAS and all the junk were removed properly once it warms up and I have more time. Well...... The bike runs, idles great, revs nice. I let it idle for about 20 min and it was stable. Fuel pump stayed cool to the touch. Fuel lines were cold, so that's a plus. Now it's time to toss on the gear and helmet. Remember, Flat front tire with dinged up rim..... When pulling out of drive, RPM revved up a bit..... something I failed to check in my excitement. Throttle cable play from lock to lock. I guess something needs a look at when I get a chance. NO biggy for now though. Let see what it's like. Well.... It's no ADV. This thing is LOW, and planted, but still has room for my 6'4" body. Steering was very heavy, Low air in tire, but the engine felt nice with a small hick up off bottem. Not sure if that's mapping, with all the mods and screwing around or the NEW FP setup. Straight line, this thing comes alive in a big way around 5,000 RPMs. Front end up...... Ooops. upon contact to ground I think more air got pushed out of tire. Very flat now. Hard to corner. Time to head back to the garage before I'm in the ditch. Big smile though. This is going to fun. This would be a blast at a track day. I'm happy with the first ride even with the small issues. New bike to me and this should be a great test bike for Engine and FI mod testing in the future. Easy to do engine swaps and strap down to dyno. These are the same rims as I use on the 17" ADV/SE rim conversion so I'll put a new front rim on it when time and weather allows and get out for round 2. The Tank adaptor plates are complete and if anyone is interested in one to build there own kit, contact me. I hope to have a complete External 990 FI pump kit ready in Spring. This should install and fit very well on a 990 ADV It's 10F hear now, so bike is parked until it warms up a bit, at least back to 40F.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! cjracer screwed with this post 01-20-2013 at 08:03 PM |
01-20-2013, 10:14 AM
#134 | |
Oddometer: 1,720
![]() Count me in!!!!
01-20-2013, 01:10 PM
#135 |
Oddometer: 61
I'm in.
