Old 01-03-2011, 04:00 PM   #31
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by Country Doc View Post
I had my 450EXC resprung and setup by the guys at KTMWorld when I was riding at Highland Park prior to the last Sandblast. They _really_ seem to know their stuff, and there's a huge trail network right at the shop for testing suspension.
It might be worth dropping in there, Aaron, particularly if you happen upon a 690 before Sandblast, as it's only a few hours west.
At least you can test/ride on trails, singletrack, fireroad, and two different MX tracks to get the setup you want, and stay overnight in their cabins if necessary.
dc
I was actually thinking of you guys when I posted that. I had no idea it was KTM world though.
Just say'IN
crankshaft is offline   Reply With Quote
Old 01-03-2011, 04:23 PM   #32
Country Doc
Wanderer
Oddometer: 2,757
Yup, the shop is right on site. It's a fun place to ride, and they are a very, very well stocked department and were generally nice and helpful. I remember they had lots of good prices on their bikes also - they also might have a line on a 690E/R.
dc
edit: Here's a clip of us test-riding suspension on their MX track. Good times. It felt a lot higher than it looks!
http://gallery.me.com/decurran#100017/MVI_1156
Country Doc is online now   Reply With Quote
Old 01-04-2011, 01:15 AM   #33
LukasM
Oddometer: 5,426
Originally Posted by JNRobert View Post
Me neither. But I have to assume that the forks and shock are based on standard WP stuff. The fork swap seems to be fairly straight forward it's the longer shock that's a question for me. The PDS stuff is obviously not going to work with the 690 linkage. So, what are they using?
I'm afraid you assumed wrong, they are not. Forks are 52mm WPs which run about $2.5k by themselves, and then you need the special triple clamps for another $1.5k. The rear of the rally is indeed a linkage suspension, but the shock is about $4.5k
Might want to look for a different solution.
Old 01-04-2011, 05:13 AM   #34
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
dc
Hey maybe we could set up a KTMWorld 2 or 3 day 690 suspension fest!!
I haven't stayed in their cabins yet, but they sure look nice. I do know there's a lot of trails to ride from easy to expert.
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 01-04-2011, 05:28 AM   #35
crankshaft
crankshaft's Avatar
Oddometer: 14,005
Interesting idea.
Just say'IN
Old 01-04-2011, 05:40 AM   #36
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Originally Posted by crankshaft View Post
Interesting idea.
If there's enough interest I would be happy to look into it!!
Old 01-06-2011, 05:53 PM   #37
crankshaft
crankshaft's Avatar
Oddometer: 14,005
Can anyone tell me what spring rates the stock 690 R has. My suspension guy and I are talking and I'm trying to figure out which springs to have on hand when the time comes.
Just say'IN
Old 01-06-2011, 06:34 PM   #38
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,128
.52 fork
5.7 shock Dont quote me on that
While you in there will go the skf seal kit ?
Mudguts is offline   Reply With Quote
Old 01-06-2011, 07:04 PM   #39
Mudguts
Mudguts's Avatar
Oddometer: 2,128
80mn for shock I have 85mn in my for 97kg= 215lb
Old 01-06-2011, 07:21 PM   #40
crankshaft
crankshaft's Avatar
Oddometer: 14,005
Thanks guts! Hey, how do I get some tank nuts...
Just say'IN
Old 01-14-2011, 05:12 AM   #41
Evil Invader
Evil Invader's Avatar
Oddometer: 696
OK, trying to wrap my mind around this
Evil, why would you need to change the triple? Adjustable offset important, or is it the offset of the EXC triples that makes a difference over the stock 690E triple?
My mistake of assuming things instead of relly check. Forklegs on 690 is slightly tapered on topend, and I didn´t recall forks on me 640 adv. was that way, assuming that was the case on sx/exc modells.
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 01-14-2011, 06:49 AM   #42
LukasM
Oddometer: 5,426
All the 48mm KTM fork legs have the same taper and fit the same triple clamps (54mm on top, 60mm on the bottom). The 950/990 forks as well, they just have a bit more overlap on the sliders.
Old 01-14-2011, 03:10 PM   #43
Evil Invader
Oddometer: 696
Thanx mate!
M Motoadventures
Old 01-23-2011, 06:26 PM   #44
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 431
How does KTM World compare to someone like Superplush? Anyone have experience with both?
KTM World's local so they're definitely the easy path, but if I'm spending the money I want to do this right.
Anyone?
FriedDuck is offline   Reply With Quote
Old 01-23-2011, 06:59 PM   #45
bigborefan OP
Making new friends
bigborefan's Avatar
Oddometer: 1,658
I have not used either. I have heard nothing but good stuff about SPS. But if KTM World was in my backyard, I would have to weigh that pretty heavily.
I don't think the 690 fork is anything special, but the shock might be a bit of an oddball.
Have you priced out both shops?
This is interesting as well, try it before you buy it.
http://www.superplushsuspension.com/tryit.htm
How much you got in it? StreetBikeMike
bigborefan is offline   Reply With Quote
Times are GMT -7.   It's 12:25 PM.
