Old 03-21-2011, 11:39 AM   #61
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Hey Guys, ready to pull the trigger on a set of forks for my 690R, anyone looking for a very low mileage front fork to bring an E up to R specs?
crankshaft is offline   Reply With Quote
Old 03-21-2011, 12:02 PM   #62
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 431
Originally Posted by CHRIS_D View Post
Will do!!
Did you ever bite the bullet and get the suspension work done? C'mon man, we need a guinea pig!
Jeff
Edit: PM sent to Crankshaft
FriedDuck is offline   Reply With Quote
Old 03-21-2011, 03:16 PM   #63
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Jeff
No sorry not yet. I have spent way too much money already on stuff I may or may not need.
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 03-22-2011, 10:57 AM   #64
LukasM
Oddometer: 5,426
Originally Posted by GS simp View Post
How do the 950/990 forks compare to the 690r ones lucas, can i change mine to say 950 adventure forks so i can have full adjustment.
cheers steve
Hi Steve,
Not sure why you would want to change to 950 Adv forks? Yours offer the same adjustability (except maybe the preload caps, not sure if the 690 has them?).
Old 03-22-2011, 12:21 PM   #65
olec
Rookie
Oddometer: 273
Where can I source another stiffer spring for the rear? I know about that "new" 95NM spring offered on those rally sites, but wat about other rates?
What is your view on taking one of those 250 or 260mm's and cut to proper length? Will I get some issues with the cutted end?
olec is offline   Reply With Quote
Old 07-26-2011, 10:22 PM   #66
risniak
Oddometer: 0
hello from munich!
I bought a exc fork for my 690 enduro with 5cm more travel. do you have solutions for the rear shock? use the 690 enduro r damper and improve it? i would like to have 30cm travel at my rear shock- is this possible?
thanks and greetings,
risniak
risniak is offline   Reply With Quote
Old 07-27-2011, 12:28 AM   #67
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,044
You can use a shorter internal spacer to get 10mm more travel (measured at the wheel) on the rear shock. Doing that to the R shock gives you 285mm. In theory you could get a little more shock travel out of it with an even thinner spacer, but the swingarm would smash into the rear brakeline/master cylinder/mount at full extension. If you look at the rally models, the rear master cylinder is positioned differently to work around this problem.
The Letter J is offline   Reply With Quote
Old 07-27-2011, 03:54 AM   #68
risniak
Oddometer: 0
thank you- my wp-dealer will change the internal spacer.
Old 07-27-2011, 04:58 AM   #69
crankshaft
crankshaft's Avatar
Oddometer: 14,005
I had my SXS forks lowered 1/2" because of the limitations of the rear shock/swingarm. Honestly, it works great and I've never missed that 1/2", it goes down the nasty trails just fine. I still think my 690E suspension was much better right out of the box than the R suspension., not sure why but it's true.
The speedo pickup bracket from RR works like a champ also, so if you guys go EXC style forks, it's a must.
Just say'IN
Old 11-18-2011, 01:30 PM   #70
11485
Oddometer: 4
Sorry for a basic question...
I understand (please corrrect if incorrect) the difference between the e and the r is about an inch or so in suspension travel and a black frame instead of an orange frame.
So- if I buy a nice, used e bike with the intention of having the suspension reworked, will the e bike's suspension then be the same as an r bike? Are they the same forks/shocks but with different internals?
I'm reasonably tall, and unconcerned about ride height.
Thanks.
11485 is offline   Reply With Quote
Old 11-18-2011, 02:36 PM   #71
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 921
different parts
you can make the e close but it costs a lot
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 11-18-2011, 08:43 PM   #72
11485
Oddometer: 4
Originally Posted by bobzilla View Post
different parts
Thank you, and again, I apologize for what was surely contained in the dead mega-thread, but:
What is the nature of the difference between the e and the r? Is there a way to quantify it?
I'm beginning the hunt for a bike, and I'd like to know if having an R represents a significant gain in suspension performance- worth paying a lot more for the bike. There seems to be a good supply of e bikes, not so much the r.
Thanks again.
Old 11-23-2011, 01:53 PM   #73
bigborefan OP
Making new friends
bigborefan's Avatar
Oddometer: 1,668
I got an E. I don't think there is a huge difference. The R has a little more travel. I don't know if the valving or action is any better. The R has the cool orange frame and different plastic. The R looks good. I think the R has a weaker head light and a different speedo/computer.
Didn't Crank say he liked his E suspension better than his R?
I bought mine in 08 when there was no R in the USA, but I have no regrets. I ride mine pretty hard. I ride with guys on 450/525/530s and have no problems until it gets tight.
If there is a huge difference in price, get an E, you'll like it just fine.
And that 690 mega thread, that thing is brutal. I quit looking at it myself.
How much you got in it? StreetBikeMike
bigborefan is offline   Reply With Quote
Old 11-23-2011, 02:32 PM   #74
Dazed Productions
Oddometer: 188
Just to add back into this thread, i have a 690e and found the suspension very harsh. Backing off preload on the rear helped and I have stuck some 2008 sxf 250 forks on it with about 20mm above the yoke (this is still higher than my stock forks even with the added sag). The harshness is now mostly gone and the bike is stable but I am still thinking of fitting a softer rear spring
www.dazedproductions.co.uk
Dazed Productions is offline   Reply With Quote
Old 11-23-2011, 05:50 PM   #75
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
It's not only more travel, the suspension is realy better ...
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Times are GMT -7.   It's 01:28 AM.
