Old 02-24-2009, 11:21 AM   #136
Surfn54
Surfn54's Avatar
Oddometer: 49
Shoco,
Your weight is not an issue. Many weigh much more and the bike handles fine due to its low torque and low suspension and handling. You cant really compare to other 225's or dirt bikes.
It shouldnt be a problem to go test ride one at a dealer. The bike in 09 is the exact same bike since 2001. Just whatever you buy, plan on maybe a grand or less for what are considered by some as needed mods. But that is a personal matter that everyone decides.
I can only say that after riding lots of fast and more powerful bikes, this tw200 has given me an attitude change for the better. I now ride and have more fun and worry less.
Surf
Surfn54 is offline   Reply With Quote
Old 02-24-2009, 11:37 AM   #137
shoco
Not So Gnarly Adventurer
shoco's Avatar
Oddometer: 467
Is that because of the fat tires, or some other reason?
Awesome. As my wife reminded me this morning, I can use an attitude change.
shoco is offline   Reply With Quote
Old 02-24-2009, 11:41 AM   #138
Surfn54
Surfn54's Avatar
Oddometer: 49
Yes, and its not as light and so not as nervous as a dirt bike tends to be. Easier to control. More like a tractor, but with some better speed. I hope that helps.
Surf
Old 02-24-2009, 11:59 AM   #139
Lima Tango
Lima Tango's Avatar
Oddometer: 65
Originally Posted by shoco
Hey Matt,
Thanks for the input, and for the tw200 forum thread (which I've already read).
I'm hoping to hear from more tw200 owners here.
FWIW, I'm not looking for any info on the other two bikes I mentioned. Just the TW (that's why I posted here in the TW thread).
Thanks again!
I'm 6'2", 250lbs and I have an '07 TW200. For the kind of off road stuff you want to do, its fine. The TW is a little mountain goat. I ride on roads. It is a little slow on uphill grades, but overall, not a big problem. I stick with smaller roads. I don't do freeways, and avoid highways whenever I can. For speeds up to about 50, its ok.
LT
Lima Tango is offline   Reply With Quote
Old 02-24-2009, 01:17 PM   #140
dynamos2000
is boinking your mom
dynamos2000's Avatar
Oddometer: 1,560
My 47 tooth replacement rear sprocket just shipped and ...well I'm a pussy and have never swapped a sprocket, any advice on what I need to do aside from taking it to the dealer?
2010 Honda Shadow RS
dynamos2000 is offline   Reply With Quote
Old 02-24-2009, 06:21 PM   #141
Macadam Drifter
Explorer of the Backroads
Macadam Drifter's Avatar
Oddometer: 723
TW200 Handlebar Mounted Instruments
1. Aerostich Mount for Zumo
2. Vapor Gage for RPM and CHT (CHT in upper left of gage)
The TW200 is slow but the Earth is patient
A Solo TW200 Travels From WA to MN
My Travelblog Updated 11/22/2011
Macadam Drifter is offline   Reply With Quote
Old 02-24-2009, 10:37 PM   #142
shoco
shoco's Avatar
Oddometer: 467
LT
Thanks for the input.
I am planning on going to a fellow ADV member's house tomorrow morning to try her TW200. I will report back with my impression of the bike.
Old 02-25-2009, 11:53 PM   #143
shoco
shoco's Avatar
Oddometer: 467
Well, I rode the TW today, and...wow that was fun! First gear was ridiculously short, but otherwise, I couldn't help but smile while riding the thing.
One of these just might be in my future.
Old 02-27-2009, 11:57 AM   #144
Macadam Drifter
Oddometer: 723
Heading to Utah Saturday For 2 Months
Tweated and ready to load up for some spring weather.
MkD
Old 02-27-2009, 12:21 PM   #145
Laoch
Buying more ammo
Laoch's Avatar
Oddometer: 4,349
TW handling
Hey, sorry if this is 205.
What is normal handling for the TW?
I rode my SO's around a little today. First time on the road. It doesn't lean in corners and making turns is a bit wierd. The front seems to have a mind of it's own.
Is it wonky because of the big tires?
Any tips?
www.damnriders.org
Laoch is offline   Reply With Quote
Old 02-27-2009, 12:22 PM   #146
JB44
Oddometer: 43
JB44......... I will however do the 130 jet.......did you also adjust the needle?Thanks, Surf
As with all carb work there is a bit of trial and error, even on identical bikes.
The carb tutorial by Centerline I linked to in an earlier post, suggested using 5 (.01) washers as shims under the needle. I ended up using 3. Unfortunately you need to disassemble and reassemble the carb for each trial...can be a pain.
http://tw200forum.com/forums/32778/ShowPost.aspx
If you are careful, you can remove the throttle cables, loosen the carb clamps, and rotate the carb 90 degrees to change the shims without having to fully remove the carb.
jb
JB44 is offline   Reply With Quote
Old 02-27-2009, 01:06 PM   #147
dynamos2000
Oddometer: 1,560
D2Moto pegs
Slowly turning into the perfect commuter
Original on left, D2Moto on right, cost less than $25 to my door
Old 02-27-2009, 02:49 PM   #148
Surfn54
Surfn54's Avatar
Oddometer: 49
Hey dirtygrunt.........What is a 205? What is an SO?
Old 02-27-2009, 02:59 PM   #149
Bowfin
Knobby Shredder
Bowfin's Avatar
Oddometer: 111
What model did you buy the pegs for? I didn't see TW on the list, just like i don't see my '86 XT600 on there. I want to adapt some big pegs and those look pretty similar to mine.
Bowfin is offline   Reply With Quote
Old 02-27-2009, 06:02 PM   #150
elkchaser
elkchaser's Avatar
Oddometer: 2
Enlarge
YAMAHA PW 50 80 TW 200 Foot Pegs
SKU: FP003
Price: $22.95
Now $14.95
Quantity:
And if you sign up for there gold card you get 15% off.
Gold Membership Program
Become one of our FREE Gold member TODAY, you will receive :
- Instant 10% off on your first order subtotal
- SAVE up to 15% on your future orders from our website www.D2moto.com ! (new promotional code will be sent along with your gold membership card)
-NO Annual Fee, NO Hidden Fee, 100% FREE Lifetime Membership!!
10% off Promotional code: GHJJJK(use this code during checkout)
Sign Up now!!
Woodrow F. Call (Lonesome Dove):
"I hate rude behavior in a man. I won't tolerate it."
Maximus Decimus Meridius (Gladiator):
"What we do in life echoes in eternity."
RMEF
"Pass it on"
elkchaser is offline   Reply With Quote
Times are GMT -7.   It's 01:49 AM.
