10-25-2011, 07:14 PM
#1561 |
Brett
Oddometer: 4,722
Thanks for the info.
Does anyone know, besides the changes made in 2001 I think, if all the other parts are the same? Same motor parts? I read the 1995 does not have a trip meter??? Would the 95 take the newer speedometer? I use the trip meter to tell when I will need gas... A kick starter is nice to have, the drum brakes likely work fine off road, I do not do much night dirt riding so the lower power headlight is not a big deal, I like manual carbs over the CV ones, so its all good except maybe the trip meter... |
10-25-2011, 08:22 PM
#1562 | |
Hoss Cat
Oddometer: 1,089
A few of the Tdub guys use those trailtech units as a speedo and odometer. Others use a gps. I think a gps with a bar attachment would be better since you're offroading. As far as the trip meter goes, I couldn't say for sure if it would work.
Some things shouldn't be left like you found them. |
10-25-2011, 08:41 PM
#1563 |
The DingDandKid
parts needed..
I took a pretty nasty spill around 40mph blasting down some jeep trails in the bald eagle state forest a month or so ago. The rear cyclerack kept the ass end from getting damaged but the front got a bit busted up. We didn't have the right tools so I spent the next 60 miles of single and double track with my handlebars positioned at 4 o' clock.
So, does anyone have a fork brace and/or front axle laying around? I'm sure I can find one on fleabay but I'd rather send my money to an inmate. Thanks, Spencer
2006 TW200 85mpg 1981 Honda CM400T How about some camping in Pennsylvania? How am I supposed to think out of the box; if they don't let me out of the box? |
10-26-2011, 04:23 AM
#1564 | |
Brett
Oddometer: 4,722
That has happened to me hundreds of times.
I just kick the wheel back into line, or sometimes bash the wheel against a tree till its lined up again. I NEVER used any tools to set it right.... I never crashed bad enough to actually bend anything other then bones... Quote:
10-26-2011, 04:31 AM
#1565 | |
Brett
Oddometer: 4,722
I wonder if the new parts will retrofit to the older bikes.
That might be the stator and regulator for the electrical system...not that I really need any more power. The automatic cam chain adjuster might be an easy retrofit. In a lot of area's in the pinelands, gas is not close, and with the little tank on the TW, I would have to be careful, carry spare gas or head out to gas up at some point. The trip meter is what I use on all bikes to tell when to worry about gas... I thought ALL bikes had one! Quote:
10-26-2011, 04:58 AM
#1566 | |
The DingDandKid
10-26-2011, 11:23 AM
#1567 |
Proud Army Dad
Location: Tucson, we keep our ice in the freezer, Arizona
Oddometer: 1,067
Right side panel
Hi guys ! Hey, following the belief that no good deed goes unpunished, I loaned one of my 02 TW's to a friend for the DMV riding test. I just got it back minus the right side panel. Just thought I would check and see if any body happened to have one they would sell. Here is a picture of the one on my other TW.
2006 KLR - RED- The Fast one ! - Sold and missed daily 1989 Yamaha Venture XVZ13DW 1987 Yamaha Venture XVZ13DW 1985 Yamaha YZ 250 - Sold |
10-26-2011, 11:30 AM
#1568 | |
Oddometer: 334
First Gen, if you will was 1987 only, first year of the TW. It had a separate lighting coil; the lights only came on if the bike was running. It had no front running light feature and the safeties were wired slightly differently from subsequent runs. It used a 1987-specific CDI unit. The left engine side cover only accommodates the 1987 charging/lighting system. Second Gen was '88-'01. It had an improved single phase, self-contained charging system, CDI was specific to those years, 35 watt headlamp, had front running lights and essentially the same system for the entire run. Left side engine cover again only accommodates components from these years Third Gen '01 to present. They have a higher output three phase charging system, higher wattage headlamp, and their own corresponding CDI unit and push cancelling turn signals. Another slight difference is the left side cover. More general information: All TW's are great bikes. Some (slightly} greater than others, depending on your point of view. '87's had one-year-only charging systems and ignition modules. Aside from that, they are essentially no different from an '88-2000 model. They're becoming a parts problem with regard ONLY to the electrical systems. In 2001, Yamaha giveth us a front disc brake, (but taketh away our kick starter) slightly more alternator output, a new CV carburetor, and a resettable trip meter. So basically the bike has had 3 versions of charging system, picked up a disc brake and lost its kick starter in 24-odd years. All plastics are interchangeable from year one to present. Lots of lovely Barbie colors over the years if yer into that. lol The basic motor is the same and all parts will interchange except for the left side covers, which have slightly different castings to accommodate the different charging systems over the years. Later models had a self-adjusting cam chain adjuster. Quality control has worsened considerably on the later model motors, so watch for base gasket leaks. Yamaha has issued a Band-Aid in the form of an "improved" base gasket, but the real problem stems from crappy cases. Some suck, some don't. All front end parts will swap between years. The disc front end differs from the drum only in the lower legs and that the lower triple tree has a tapped hole for the brake hose mount. The late model carb drives from the right, early model's cables are on the left. Swing arms and rear wheels are all the same. Gas tanks are all the same except later models got a smaller gas cap and Cali models have a fitting for a vapor hose. Early models have better starter solenoids, relays, and electrical components overall, IMO. Later models have more output and slightly more protected wiring harnesses. Lower fork legs lost their drain screws at some point. Early models had them. Kickstands, frame gussets and welds are better on the older units. Whether this was necessary or not is arguable, but they are different. The only real interchangeability problems I've encountered have been between the electrical systems, wiring harnesses and switchgear. Lots of variations here, with minor, sniggling changes to the various connectors and components. |
10-26-2011, 12:35 PM
#1569 |
Brett
Oddometer: 4,722
Wow, thanks much for the info!
The 1995 sounds great then, with only the trip meter an issue with me. I love having a kick starter, had a lot of bikes up to 750's without electric start and never wanted it on any bike really. The non cv carb sounds like a winner, the electrical system I dont care about as long as I can get parts for it. |
10-26-2011, 07:22 PM
#1570 |
Oddometer: 80
Added the side pelican cases today! What do you guys think?
#1571 |
Oddometer: 80
10-26-2011, 08:51 PM
#1572 |
Oddometer: 4,812
Like em! Got them on my WeeStrom but going with Dirtbagz on the TW
First gots to buy a battery after 6 years and 34 miles mine gave up
RIDE SAFE |
10-27-2011, 07:13 AM
#1573 |
likes the back roads
Oddometer: 361
Dude, WHAT? Don't you ride that thing???
And that road goes on and on into the sunset And my destiny is bound to move me on My website: gonnerman.org |
10-28-2011, 12:11 PM
#1574 |
Oddometer: 4,812
Just bought it and wife hasnt done the ms course so no ride and I am beginning to like it and she may have to buy her own.
Only had 27 miles when I bought it.....it is a ball for a 63 yo like me....my feet even touch the ground.
RIDE SAFE |
10-28-2011, 04:17 PM
#1575 | |
Oddometer: 4,812
RIDE SAFE |
