05-28-2012, 04:29 PM
#2506 |
Oddometer: 93
Sea Foam
Get some Sea Foam (Auto Part store or Walmart) and put it in the gas.
Dump some directly in the carb, slosh it around. Let sit for a day or two. Slosh some more. Empty carb and clean it out. Reassemble. Keep using heavy doses of Sea Foam for the next 4 or 5 tank fulls of gas. Just add a few ounces to each fill up. Think long and hard before spending $$$ on a CDI. Many CDI's have been replaced that turned out not to be the problem. I did most of the above to mine. I got it running but it skipped a lot at any type of higher speed. Then on maybe the second treated tank of fuel it went thru a very bad short spell of missing, a large backfire and it has run perfect ever since. Good Luck. |
05-28-2012, 04:40 PM
#2507 | |
Howling "Mad", Adventurer
Oddometer: 8,778
What you described is what I did and plan to keep on doing. The thing that has me mystified is if I take the spark plug out, give the engine a SHORT shot of starting fluid, it will fire up and run for a few revolutions. Repeat this procedure a few times and the darn thing will then start with out the starting fluid and when warmed up will run good and easily start either by kick or use of the electric starter. What ever it is I am sure its something so darn simple I am going to feel like crawling under a rock when I figure it out or someone suggests the fix to me.
Dave, aka "Mr. Cob" Want a STEEL SKID PLATE for your Ural, contact me for details. My photos, http://mr-cob.smugmug.com/ Help a CHEAP bastard keep his Smugmug, use this coupon ( geyYbNZwLLrl6 ) thank you. |
05-28-2012, 05:19 PM
#2508 |
Oddometer: 155
Led fog light night pics
Here is my night time headlight comparison pictures for anyone thinking about putting led fog lights on there 01+ TW or a HID kit. These are advmonster model 44's and they rock the night..
http://tw200forum.com/index.php?/top...__1#entry45322 |
05-28-2012, 06:29 PM
#2509 |
Oddometer: 155
Tw night comparison pics
The 98 has a piaa super plasma gtx 35w bulb the 07 has a bikemaster 6000k 35w HID and two advmonster model 44's led fog lights. Both lights are better than the stock bulbs 98 had a 35w and 07 55w halogen.
98 low beam ![]() 07 low beam
05-28-2012, 06:35 PM
#2510 |
Oddometer: 155
Lights
98 high beam
![]() 07 high beam ![]() 07 high beam + leds
05-29-2012, 07:06 AM
#2511 | |
such a pud..
air filter is clean. one thing i didn't think about till last night.. the spark plug is original one... maybe it is just getting weak spark. i am gonna install a new spark plug and see what that does, if it doesn't fix it i will swap the 128 pilot for a 126. if neither of them changes fixes it... guess i will check valves.
you push it!......... it's your motorcycle. There will only be two things left moving after WW3. Cockroaches & KLRs. |
05-29-2012, 07:10 AM
#2512 |
such a pud..
i rode this tw the other night.... MAN!! what i difference those lights make. thinking of getting a set for my klr.
05-29-2012, 11:23 AM
#2513 | |
Oddometer: 16
So I suggest you remove the carb completely and look for dirt. Since I removed the slide and deceleration bypass bits, cleaned thoroughly, the hesitation has almost gone away. I bet the issue would go away completely if I did a better cleaning (with a wire to poke all the fuel passages). |
05-29-2012, 06:19 PM
#2514 | |
misadventurer
Oddometer: 313
My '09 does a similar thing when it gets cooler, like below 50. In fact it almost won't start below that, never has. I've just parked it and ridden my F800 when it got cooler but I would like to know what I need to do to fix it. I've rejetted the carb and it starts like a champ when it is warmer but acts like it is flooding out when it is cooler
Christi Quote:
"I have this moment and no idea when it will end" - Andrea Gibson "The adventure begins when the plan turns to shit." I don't know who said that first but I like it 'cause my plan turned to shit a long time ago |
05-29-2012, 06:48 PM
#2515 |
Oddometer: 8,778
Howdy All,
I think I fixed my old T-dub, its starting very well now, I'll let it sit over night and try it again in the morning, "IF" it starts then I'll declare victory, if not I'll whine and work on it some more. Stay tuned for what I think the problem was.
06-02-2012, 05:14 PM
#2516 |
Oddometer: 996
06-04-2012, 09:15 PM
#2517 |
Adventure Traveller
Oddometer: 154
The contrast is amazing!
Please list brand, parts # & who sells them. I'd like to get a set for my TW & another set for my Versys. Thanks
KJ 2012 Suzuki V-Strom-ADV, 2011 Kawasaki Versys, 2008 Yamaha TW200, 2013 Honda CRF250L I'm never lost... Because I'm always right where I'm at... |
06-09-2012, 05:18 PM
#2518 |
Oddometer: 996
Mischief and Mr. cobb...........go to the tw200 discussion forum....the doctors will fix you right up!.
06-10-2012, 04:23 PM
#2519 |
Renegade
Oddometer: 40
'07TW200-'05XR650R-'02Sherco290 |
06-11-2012, 11:03 AM
#2520 |
Wackjob
Oddometer: 795
Over the weekend Ronnydog and I completed an Iron Butt Saddlesore 1000, each of us on TW's.
I think this is a first for these particular bikes and among what appears to be only a handful of small displacement singles to have done a registered ride. ![]()
Lizrdbrth screwed with this post 06-11-2012 at 11:45 AM |
