Old 02-25-2013, 05:42 PM   #3196
Old White Truck
Old White Truck's Avatar
Oddometer: 27
Originally Posted by tommu56 View Post
My wife dropped her bike and pretzeled the brake lever.
What are you guys using for hand guards????
The Tusk D-Flex are fairly popular on the TW200 forum. I have 2 sets (on my 2 TWs). The right side needed tweaking but I can get them to fit. They are not very expensive.
Other options are Emgo and Cycra Probends.
Old White Truck is offline   Reply With Quote
Old 02-25-2013, 06:05 PM   #3197
tommu56
tommu56's Avatar
Oddometer: 777
thanks
What did you have to tweak?
tommu56 is offline   Reply With Quote
Old 02-25-2013, 07:02 PM   #3198
Old White Truck
Oddometer: 27
thanks
First of all, don’t make your decision based on what I do. I am kind of an odd bird. Others have installed the D-flexs without tweaking.
I try to get them to fit without grinding off the alignment tit that fixes the horizontal position of the throttle, without moving the brake lever mount inward, and I like to leave a bit of the outer end flange on the rubber throttle grip (rather than cutting it off entirely).
To accommodate the above, I end up bending the angle at the end of the aluminum bar in a vice just a tad and adding a couple of spacer washers. Then it works great.
I never have any problem with the left side. The issue described above only comes into play on the throttle side. And, as I said, I believe other people have installed these hand guards with no problem.
If you do buy these, and end up having any issues at installation time, just drop me a note and I can send you photos or provide more info.
Also keep in mind that I have the stock handlebars. YMMV if you have after-market bars.
Cheers,
Old 02-25-2013, 07:35 PM   #3199
tommu56
tommu56's Avatar
Oddometer: 777
Cheers,
I wont have any problem I'm pretty good at MacGyvering
I've been running with a piece of bailing wire holding my stock KLR's in place after a crash I smashed them up.
and just put tusks on mine.
Old 02-26-2013, 11:37 AM   #3200
r80rt
Woods bum
r80rt's Avatar
Oddometer: 77
I run a cheap set of universal handguards from e-bay, they are strong and fit up easy.
Not all who wander, are lost.
r80rt is offline   Reply With Quote
Old 02-27-2013, 05:27 AM   #3201
Yooper_Bob
Yooper_Bob's Avatar
Oddometer: 1,947
The Tusk handguards are super tough....my wife has "dropped" her TW numerous times at speeds between 20 and 50 MPH, and they have held up to the abuse.
I have never seen another bike with as much road rash as her poor little bike has.
Yooper_Bob is offline   Reply With Quote
Old 02-27-2013, 12:00 PM   #3202
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
I believe the TW200 rear rim is size 4.50-14. Is this correct?
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Spud Rider screwed with this post 02-27-2013 at 12:07 PM
Old 02-27-2013, 12:05 PM   #3203
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 795
Originally Posted by Spud Rider View Post
I've searched a bit, but I can't find the information. What size is the rear rim on the TW200?
Spud
4.50x14
Lizrdbrth is offline   Reply With Quote
Old 02-27-2013, 12:09 PM   #3204
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Originally Posted by Lizrdbrth View Post
4.50x14
As always, thank you for you prompt and helpful reply. I just found the rim size on a parts diagram; that's why I edited my previous post.
Spud
Old 02-27-2013, 04:23 PM   #3205
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 795
Spud
Anytime, Senor Spud. I'm not sure what you're up to but the rear rim is also an oddball in that it has 32 spokes. Check your spoke count if you're thinking of lacing one to something other than a TW hub.
The front rim is the more common 36 spoke.
Lizrdbrth screwed with this post 02-27-2013 at 04:44 PM
Old 02-27-2013, 05:14 PM   #3206
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
The 32 spokes for the rear rim is good information to know; thank you. I was just curious to learn how wide the rim needs to be to mount an ATV tire. I know someone who has a size 3.00x15 rim, which I am sure is too narrow to mount any ATV tires.
Spud
Old 02-27-2013, 05:55 PM   #3207
Dyno
Conquistador
Dyno's Avatar
Oddometer: 1,116
I know that a 4" x 12" works well for an 8" wide tire. The 3" might be pushing it....
Dyno is offline   Reply With Quote
Old 02-27-2013, 06:58 PM   #3208
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Thank you for good information, Dyno.
Does anyone know of a 15-inch, ATV tire which will mount on a size 3.00x15 rim? My Zongshen 200GY-2 originally had a rear wheel with a size 2.75x15 rim. Later, I installed an XT225 swingarm, and switched to the 18-inch, XT225 rear wheel.
Since then, I've been building custom, 18-inch wheels for Zong owners, because you can't buy a knobby tire in North America which will fit the Zong's rear wheel. This other fellow bought another Chinese motorcycle with a size 3.00x15 rim on the rear wheel. I'm happy to build him a custom wheel, but he might prefer to mount an ATV tire, if it will save him some money.
Spud
Old 02-27-2013, 08:14 PM   #3209
Keithert
Oddometer: 159
Interesting because I've read the rear wheel is a weak point on the XT225. Have you heard that?
2001 Kawasaki Vulcan 1500
2005 Yamaha XT225
Keithert is online now   Reply With Quote
Old 02-27-2013, 09:32 PM   #3210
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
I might have heard of an occasional rear hub cracking; I don't remember. However, I haven't had any problems whatsover, myself. One could always install a TT-R225 rear wheel, which is beefier; the swingarms are identical for both bikes.
Spud
Times are GMT -7.   It's 02:09 AM.
