Old 04-06-2013, 08:39 PM   #3346
frog13
frog13's Avatar
Oddometer: 1,337
Closing in on the 1000 mile mark.....the TW is really loosening up now.....road travel is MUCH better(yes, I've done the rejet etc.) now.In a few more thousand miles it should get REALLY good.Eventhough this bike is late 80's tech.....it sure was put together tight....glad it has loosened up!.
frog13 is offline   Reply With Quote
Old 04-08-2013, 06:56 AM   #3347
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,576
Well it was time. My sprocket chain combo is over 6 years old and was so bad I had to dig in to the crank case yesterday. I put it off as long as I could knowing what a PIA it was going to be - no shortage of rust on this beach bike. Is that the hardest counter shaft in the world to get to? Glad I had the skills to destroy every single screw - not a single one came directly out. Even left a custom shaft in 2 where I removed jus the head?? Most I could drill a pilot hole and use an extraction tool the others I cut a notch and used a flat head. Then there were the 2 that just lost their heads .
Looks like a 14/45 combo but curious about a combo that would give me more top end. It's a street only TW and the only hills it I ride are the 2 bridges going over to the beach. Any suggestions to increase my sweet spot from 45 to 55?
I am obviously going to have to replace the cc gasket and screws. Any other suggestions?
1998, 15,000 miles
Guns keep society safe.
Colemanfu screwed with this post 04-08-2013 at 07:02 AM
Colemanfu is offline   Reply With Quote
Old 04-08-2013, 07:11 AM   #3348
NJ-Brett
Brett
Oddometer: 6,411
I went down 2 teeth on the back sprocket, and installed an O ring chain, and it seemed good every place I rode the bike, street, swamp, thick sand.
NJ-Brett is offline   Reply With Quote
Old 04-08-2013, 07:45 AM   #3349
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,576
So what is your final raito? 14/43?
Old 04-08-2013, 08:09 AM   #3350
FootDoc
Gas it
FootDoc's Avatar
Oddometer: 105
I run a 14/42 on my mostly street TW. Im 225 and it has no problems hauling me up to highway speed, even 2 up. Big hills and strong headwinds make the bike struggle, but ill take the trade off for the relaxed cruising RPM. My top speed is @75 on a level road, so its not going to give you more MPH. Going over the causeways in your area shouldn't be an issue.
FootDoc is offline   Reply With Quote
Old 04-08-2013, 11:22 AM   #3351
assquatch20
Hoss Cat
assquatch20's Avatar
Oddometer: 1,102
Get new retainers and bolts for the sprockets, and replace the stator screws with something better while you're in there. They get stuck as well. Countershaft seals would definitely be good to replace, maybe the shifter seal as well.
Some things shouldn't be left like you found them.
assquatch20 is offline   Reply With Quote
Old 04-10-2013, 03:37 PM   #3352
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,576
counter shaft sprocket project
I settled on 14/43 combo, new chain, replacement screws all around, and a gasket. Should come in under $100.
After soaking with liquid wrench for 2 days I removed the last two screws or what was left of em .
Shit pix but here is the counter and the boogered up hardware as well as the extraction bit.
Yea a few short (missing) and a few odd ball allens - you can see the dissimilar material gunk build up on em.
Colemanfu screwed with this post 04-10-2013 at 04:42 PM
Old 04-12-2013, 09:13 PM   #3353
Small's
Oddometer: 327
Sprockets
You might want to count your rear sprocket teeth. The factory 50tooth has a 45 stamped on it. Not sure what for. I personally think a 15/47-14/44 or a 14/45 would be as low as i would go. I ran 15/47 on a 1600mile road trip and it was nice as long as there wasnt a head wind. It was ok because you could still pull 55-60 in fourth. A buddy of mine bought a 05 with a 14/40 and it would run 71-72mph in fourth ten when you shifted to 5th it would drop to 68. Not enough power for that tall of a gear.
Small's is offline   Reply With Quote
Old 04-12-2013, 09:31 PM   #3354
Small's
Oddometer: 327
Moab
Two TW's tackle Moab. Top of the World! In my opinion the best view of Moab.
Old 04-13-2013, 09:09 AM   #3355
Kwizard
Conservative
Kwizard's Avatar
Oddometer: 20
40 tooth sprocket
Hey Smalls,
Any idea where that 40T sprocket came from? The smallest I can find is a 42.
"I'll be your Huckleberry"
Kwizard is offline   Reply With Quote
Old 04-14-2013, 03:24 PM   #3356
tdbmd
Oddometer: 17
Talking 2003 tw?
I recently came across a 2003 TW for sale with 682 miles and they are asking $2600. Is that a reasonable price for a low mileage '03? Any kind of problem with the '03 model that a guy should be on the lookout for if purchasing a used one? Thanks.
tdbmd is offline   Reply With Quote
Old 04-14-2013, 03:42 PM   #3357
assquatch20
Hoss Cat
Oddometer: 1,102
That's about par for the course. With that age, consider rubber bits being dried out, chain/sprockets, carb cleaning, and a battery. But, that all depends on the owner.
Old 04-14-2013, 04:12 PM   #3358
tdbmd
Oddometer: 17
Thanks for the information. The photos look good, consistent with the low mileage, but I have learned that they can be deceiving for sure! The bike is a couple of hundred miles from here and wanted to see if there were any specifics before making a road trip!
Old 04-14-2013, 04:47 PM   #3359
frog13
frog13's Avatar
Oddometer: 1,337
tdbmd.....if you do purchase the TW.....your going to have alot of fun!.
Old 04-14-2013, 05:38 PM   #3360
assquatch20
Hoss Cat
Oddometer: 1,102
I'd say nitpick and chip off a few hundred bucks if you can get a look at it.
Times are GMT -7.   It's 07:12 AM.
