03-05-2010, 07:11 AM
#751 |
Oddometer: 312
What is a normal highway speed for a TW? What is average top speed?
03-05-2010, 07:21 AM
#752 |
Oddometer: 764
I think ParadoxPete may be at high elevation, there are a couple people that report abnormally terrible running, usually elevation poor tune.
The TW has a rock crawler first gear compared to many others, we have 45tooth rear here from 2001-on and it still pulls wheelies from the lights max speed at about max power 7500rpm+ USA got 50tooth rear standard. XT225 is reputed for a very wide ratio 6 speed, that was missed by its fans when dropped for XT250 with 5 speed. TW top speed can hold 105kph (65mph?) indicated on flat in windy conditions. Up hills is like a roller coaster, can drop to 80kph and 4th, before over top speed on the descent. For us here we're able to run flat sea level 70mph highway zones for a tank load, before fuelling up. Elevation and hills will kill that. If highway keep up and top speed is essential 75mph+, or want more power to lose to elevation, check out the Kawasaki Sherpa 250 air cooled 6 speed, and the XT225 with 6 speed. If you're wealthy, the WR250X is fuel injected ;) eldavo screwed with this post 03-05-2010 at 07:29 AM |
03-05-2010, 07:35 AM
#753 | |
Oddometer: 764
Very happy they managed a 4 gallon tank. Now who wants a 4gal XT350 tank and seat combo for the TW
03-05-2010, 08:02 AM
#754 |
Master of None
Oddometer: 5,052
Anybody ever put an XT225 engine in a TW?
Originally Posted by Javarilla Evolution, or, natural selection, has nothing to do with better. It merely weeds out what is no longer suitable for the given context. Originally Posted by Dragoon I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle. |
03-05-2010, 10:26 AM
#755 | |
is boinking your mom
Oddometer: 1,560
03-05-2010, 07:05 PM
#756 | |
Half-assed adventurer
Oddometer: 1,421
Freedom is not simply the right of intellectuals to circulate their merchandise. It is, above all, the right of ordinary people to find elbow room for themselves and a refuge from the rampaging presumptions of their “betters.”- Tom Sowell |
03-06-2010, 02:41 AM
#757 | |
mach schnell
Oddometer: 1,436
Keep us posted.
****** Mess with me and you mess with the whole trailer park. |
03-06-2010, 05:59 AM
#758 | |
Oddometer: 227
It's been discussed on the TW forum. It will physically bolt into the frame but the sprockets won't line up due to the wide wheel and there's no easy way to solve the problem. The xt tranny won't go into the tw case and extending the xt output shaft involves making a very expensive custom output shaft. |
03-06-2010, 08:01 PM
#759 |
NorthWest Adventure Rider
Oddometer: 1,685
Thought I would post up a few pics of the extra fuel tank that my father and I are making for our TW.
Here's a few pics of the tank sitting where it will be mounted. I'm going to add some bars on the sides so straps can easily be attached to the tank. I plan on packing a large dry bag on top of the tank when we take our long cross country trip with it. I made an aluminum plate to attach to the top of the tank for that purpose but I don't think it will really be necessary. I decided on this setup since I really like the looks of the stock fuel tank ( I know a aftermarket tank is in the works for the TW's but the stock one just looks best IMHO) and I'll only need the tank on long cross country trips, Most of the time the stock capacity is fine. The tank will be easily removable when not needed. It will clamp to the bars with 4 mount points (yet to be welded onto the bike) and the tank will have it's own petcock so you will be able to reach back and turn on the reserve tank while in motion. The tank has baffles inside it to keep the fuel from sloshing around. I'd have to calculate the capacity again to make sure but I think it was around 2.5 gallons...Double the stock fuel range! Since the last update I've also added in two more stabilizing bars under the top part of the tank (just visible in the 2nd pic below). I welded two tabs onto the subframe and make the new stabilizer bars bolt at the attach point so the rack can still be easily removed. Now I just need the time to get it finished up ![]() ![]() ![]() Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE Adventure Is Out There - NV RR: CLICK HERE Riding Through History - NV RR: CLICK HERE And Then There Were Four - OR RR: CLICK HERE My VW Syncro Westy Build Thread: CLICK HERE Hodakaguy screwed with this post 03-06-2010 at 08:24 PM |
03-08-2010, 05:38 AM
#760 |
Oddometer: 1,560
I did my 1st real stupid thing while workin on my tdub this wkend. Put on the 47 tooth sprocket but didn't have the wheel aligned correctly so 3' from my garage, the chain slips and puts a semi-deep scratch in the new sprocket (hoping I can sand that tooth, its decently low on the tooth).
Anyway, gonna have the local dealership (wont call them a stealership here, good folks) to pick her up and put on the new chain I purchased and ensure I didn't screw up anything else. Damn you Captain Morgan. |
03-09-2010, 05:18 PM
#761 |
King of all manfu
Oddometer: 2,689
Ho - that bike is set up for some long haul truckin! You sure can haul some gear and now some extra range. I like the idea of the fuel switch on the go as well as the baffles. Well done, I loved working on stuff with my pops.
![]() Here is a pix from my ride to work this morning. My TW is an "around town" bike - only ADV is seeing how much crap I can load on the rack. hehe Holly Hill FL sunrise 3/9/10 Riverside Drive 1998 TW200
Guns keep society safe. |
03-10-2010, 05:44 AM
#762 |
Oddometer: 1,560
Shield
About to get a shield for the lil guy, what are you guys using with the standard square headlight and plastic around it?
National deflector has been a great shield on previous bikes but I no longer have it, not interested in the mini "jimbo". |
03-10-2010, 05:58 AM
#763 | |
Oddometer: 764
03-10-2010, 08:33 AM
#764 | |
Oddometer: 1,560
03-10-2010, 09:03 AM
#765 |
Oddometer: 764
Not joking, but check out shields for scooters, especially what the average European gets around on. They take weather sheltered legs in standard fairing design, then step it up with serious screens. This is an example from Florence at height of summer... streets of scooters parked everywhere like this.
