Old 02-09-2009, 11:31 PM   #106
Sycamore
d00b
Sycamore's Avatar
Oddometer: 1,697
Saw this in Japan (Tokyo) - strictly minimal...
Sycamore is offline   Reply With Quote
Old 02-12-2009, 05:59 AM   #107
dynamos2000
is boinking your mom
dynamos2000's Avatar
Oddometer: 1,560
Added the tusks last night, helped keep my pinkies from freezing this morning - fun lil bike
From TW200
2010 Honda Shadow RS
dynamos2000 is offline   Reply With Quote
Old 02-14-2009, 10:16 AM   #108
neepuk OP
Such a drag...
neepuk's Avatar
Oddometer: 1,633
I love the air box! Gives ma some ideas....
neepuk is offline   Reply With Quote
Old 02-14-2009, 11:21 AM   #109
Frostbit
Is it cold in here?
Frostbit's Avatar
Oddometer: 1,046
I just added some Acerbis to save the levers from my ice riding inexperience.
It’s easier to have a strong opinion with less information.
Check out WWW.RideDualSport.com forum.
Frostbit is offline   Reply With Quote
Old 02-14-2009, 02:51 PM   #110
HenryJ
S-10CREWCAB.COM
HenryJ's Avatar
Oddometer: 57
Today I installed the bigger LED driving light and the Dyna beads. That was the end of a very long list of mods for this TW200. I think it is finally where I want it:
Ready to go for spring.
"Speed is just a matter of Money - How fast do YOU want to go?"-mechanic from Mad Max-
If at first you don't succeed - Don't take up Skydiving!
- ThunderII KE7CSK
HenryJ is offline   Reply With Quote
Old 02-15-2009, 06:14 AM   #111
trxcr
trxcr's Avatar
Oddometer: 159
http://www.vjmog.com/ftopict-3227.html
trxcr is offline   Reply With Quote
Old 02-15-2009, 06:25 AM   #112
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,812
Originally Posted by trxcr
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 02-15-2009, 07:41 AM   #113
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,431
Question LED's
Hey Henry ....
Tell us more about the LED driving light .... and post some pictures with it lit up !
Thanks ...
Honda
GsVs is offline   Reply With Quote
Old 02-15-2009, 08:12 AM   #114
Sloppy
Sloppy's Avatar
Oddometer: 210
Originally Posted by Turborob
My little fella.
Has the XT350 tank on it on occations where more range is required.
I was under the impression from the TW forums the XT350 tank wouldn't fit. Did you have to do anything weird to get it on, or does it fight right on?
Sloppy is offline   Reply With Quote
Old 02-15-2009, 09:30 AM   #115
HenryJ
S-10CREWCAB.COM
HenryJ's Avatar
Oddometer: 57
LED lights do not project like HID, but on the TW you don't really need lights that reach out 1/2 mile. The speeds just are not there to need that. I can see opening up the sides and reaching out a little though. I had one on the shelf from a long past project. It looks very similar to these: Hyper White LED Fog / Driving light
That search revealed several sets on Ebay under $20 a pair. I decided to shelve the 9 LED in favor of a larger light.
I did quite a bit of looking. For my application a small size and low power consumption are critical. The LED lights are not easy to find and you don't get much selection. Ease of installation and not a "one off" custom light. Price is another consideration as well. This is an economy bike.
It is mounted in the center below the bracket.
I don't have pictures of it illuminated yet. I just got it installed yesterday and the weather turned off bad. The photos I tried in the garage were worse than the one above.
It is a YTL "hyper bright" 28 LED light (China). I picked up a pair of them on Ebay for under $20 shipped. The light appears a bit more focused forward. Less blue and more white than the one I had. I have a headlamp off switch, so it is possible I could run with this on in the daytime to ease loads on the charging system. The TW is not know for an abundance of power being available. This might offset some accessories.
The round rocker switch on the left is my headlamp kill switch. It shuts off the low beam headlamp for starting. The one on the right is the LED driving light.
It will be fun to see how this works out. The installation blends in pretty well with the bike. Anything is an improvement over stock. The cost was minimal, so I don't have much to lose.
- ThunderII KE7CSK
Old 02-15-2009, 06:53 PM   #116
HenryJ
S-10CREWCAB.COM
HenryJ's Avatar
Oddometer: 57
...I don't have pictures of it illuminated yet.
Took care of that tonight.
Here are some quick light examples:
LED only. About a 10' circle at 25'
90W low beam --------------------------------------------------- LED and Low beam
130W high beam ------------------------------------------------- highbeam and LED
- ThunderII KE7CSK
Old 02-16-2009, 09:35 AM   #117
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,431
Question Switch
Hey Henry ....
Thanks for posting the pictures ....
A question about the rocker switch - are those just Radio Shack ones or ???
The mounts for the switches look great - did you make those ??
Thanks ...
Honda
GsVs screwed with this post 02-16-2009 at 10:28 AM
Old 02-16-2009, 02:25 PM   #118
HenryJ
S-10CREWCAB.COM
HenryJ's Avatar
Oddometer: 57
I had the switches on the shelf. Salvaged from a vehicle at the wrecking yard I suspect. I have seen similar switches at Radioshack.
I did make the mounting brackets. A simple paper pattern to fit them in place. Then drilled a hole for the switch and mounting bolt in .080" aluminum. Trace the pattern and cut it out.
- ThunderII KE7CSK
Old 02-17-2009, 05:32 AM   #119
Surfn54
Surfn54's Avatar
Oddometer: 49
I posted this elsewhere, but for you guys, maybe you can help.
Well, I just got my bike back with the 15/47 sprocket change. It was
a windy day and I have to say that it was a little disappointing. I
have a definite improvement in the lower gears and 4th is like 5th
used to be. 1st is like 2nd and so on. But when I went to 5th, I lost
power and would lose speed until I reshifted into 4th. Then back up
to about 65 then into 5th and I would drop back down to 55. I feel
certain that the windy day had something to do with it, but it was
unacceptable.
My question is why did this happen?
Is it the front gear to 15 that did it? or was it going to a 47 on the rear that did it? I am
thinking that I should go back to 50 and keep the 15 ( easier) But
will that make any difference?
Interesting that everything else was way better. The engine
especially seemed much less stressed and ran at a much better rpm.
But 5th was disappointing.
Any thoughts before I make the next move!
Surf
Surfn54 is offline   Reply With Quote
Old 02-17-2009, 07:39 AM   #120
Streamin' E
Half-assed adventurer
Streamin' E's Avatar
Oddometer: 1,435
I suspect that when you shift into 5th, the reduced rpm's puts you below the torque peak of the engine, hence you slow down.
Freedom is not simply the right of intellectuals to circulate their merchandise. It is, above all, the right of ordinary people to find elbow room for themselves and a refuge from the rampaging presumptions of their “betters.”- Tom Sowell
Streamin' E is offline   Reply With Quote
Times are GMT -7.   It's 07:14 AM.
