Old 02-19-2008, 06:47 PM   #1
Yooper_Lee OP
Yooper_Lee's Avatar
Oddometer: 4
XR650L transmission ratios
Well, the winter is growing long here in Houghton, MI... and I've been thinking XR650L project bike. I used to design gearboxes for a living as a consulting engineer and was going to plot out the XR's gradeability and tractive effort with the factory gears.... only I cant find anything on them. Does anybody have specs on the factory primary, 1-5 and final drive set up for the L machine? If you get them to me I promise to post the results. I've ran the same numbers for the KTM LC4 and the F650 just to see what those designers were going for. Thanks!
Yooper_Lee is offline   Reply With Quote
Old 02-19-2008, 07:02 PM   #2
kubiak
Oddometer: 4,829
maybe you can answer a question a lot of us 650l owners have,it seems most 650ls shift smooth except for the first to second gear change.its kind of rough on all the ones i have ridden.thanks!
Old 02-19-2008, 07:15 PM   #3
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,894
The XR650L has a big jump from 1st to 2nd. The good side it that it widens the overall spread for more versatility. The bad side is the shifting you describe.
Gear ratios coming up.
montesa_vr is offline   Reply With Quote
Old 02-19-2008, 07:19 PM   #4
kubiak
Oddometer: 4,829
does it cause any extra wear in the long run from notchy shifting or is it something i can just not worry about?thanks
Old 02-19-2008, 07:23 PM   #5
montesa_vr
montesa_vr's Avatar
Oddometer: 1,894
I guess for the XR650L I don't have the actual gear pairs, just the ratios. Here they are:
Primary 2.19
Final 3.00
First 2.67
Second 1.65
Third 1.25
Fourth 1.00
Fifth 0.84
Overall (primary*final*individual gear ratio):
First 17.53
Second 10.83
Third 8.21
Fourth 6.56
Fifth 5.51
Have you read the Five-speed vs. Six-speed thread? http://www.advrider.com/forums/showthread.php?t=281742
Old 02-20-2008, 05:33 PM   #6
Yooper_Lee OP
Yooper_Lee's Avatar
Oddometer: 4
Thanks a million!
As promised I will post the gradeability chart as soon as I work it up. Check back on Saturday!
Yoop
Old 02-20-2008, 05:50 PM   #7
Countdown
Oddometer: 5,611
Problem is that is is a giant gap in ratios on 650L. Larger than any other 5 speed and probably double the 6 speeds. With no syncro and the cogs moving a vastly different RPM it is a problem. Unlike old non-syncro car/truck transmissions you can't shift to neutral and double clutch. Make sure your clutch fully disengauges.
Jerry Counts
Countdown is online now   Reply With Quote
Old 02-21-2008, 09:41 AM   #8
XR650L_Dave
Oddometer: 3,742
You can always put a XR600R trans into the XRL and get rid of the big gap...
Dave
XR650L_Dave is offline   Reply With Quote
Old 02-21-2008, 02:07 PM   #9
Yooper_Lee OP
Yooper_Lee's Avatar
Oddometer: 4
As promised. My estimate of the 650's gradeability
Hope I did attached this!
Old 02-21-2008, 02:57 PM   #10
husky123
Oddometer: 1,454
uhhh, yeah.....
That's awesome, now maybe some interpretation for the "slow".
husky123 is offline   Reply With Quote
Old 02-21-2008, 03:17 PM   #11
Countdown
Oddometer: 5,611
Originally Posted by husky123
uhhh, yeah.....
For the lower 10% of the class, it shows that the valves are floating before you should shift to 2nd or shift to 2nd and slip clutch until wheel speed catches up to engine running in the power band.
Actually Honda geared 1st for very slow trails with stock gearing or just to get bike moving then short shift to 2nd. It is actually a 4 speed with granny low.
Jerry Counts
Old 02-21-2008, 04:52 PM   #12
husky123
Oddometer: 1,454
Why thank you. It's pretty cool when a fancy chart backs up what you've known all along. I love my ass.
Old 02-22-2008, 06:03 PM   #13
Yooper_Lee OP
Yooper_Lee's Avatar
Oddometer: 4
The Chart
:)) you guys are a hoot! Yup the chart says what ya think. BUT it also says the aero drag limits you to 140 KPH, and the 1 to 2 upshift is such that the counter shaft speed plays a major part in the dog clutches getting engaged in that upshift, it's about at the limit of where you can go and still get a reliable shift. I haven't yet looked, but suspect that there's some machining around the dogs to allow them to locate and lock-up.
Another thing, it looks like around 130 KPH is all the L can do unless you put a some kind of aero system up front. Countdown is very astute to note that this is really a four speed with a granny.
I just looked at some KTM's for a reality check. I like their approach. Nice spread through the range.
So if this analysis is worth anything lemme ask ya...
in 5th at 120 KPH, if you encounter a slight hill are you downshifting to 4th?
is 140 KPH the top end on level grade with no head wind, best day?
Thanks,
Yoop
Yooper_Lee screwed with this post 02-22-2008 at 06:11 PM
Old 02-22-2008, 06:11 PM   #14
husky123
Oddometer: 1,454
Yoop,
Stick around. I like your style. Keep the analysis coming.
Old 03-12-2015, 06:59 PM   #15
Mechanicalnightmare
Oddometer: 1
Sorry to bring up this old thread, I hope someone will be able to answer me, I really need to know one or two things, first, is the 28.5 lb*ft of torque that the XR650L makes at 5700 rpm to the wheels or to the crankshaft? And second of all, do you know where does the primary ratio come from, i guessed the final ratio was from the sprocket to the wheels, but Im a bit lost ? Correct me if im wrong... cause the values im calculating with your ratios dont exactly match with what i should be getting
Mechanicalnightmare is offline   Reply With Quote
Times are GMT -7.   It's 10:39 AM.
