Go Back   ADVrider > Riding > Regional Forums > Canada
Old 05-07-2012, 04:13 AM   #4816
Allen ravine
Allen ravine's Avatar
Oddometer: 8
Originally Posted by Deadly99 View Post
Your lucky Tarzan didn't go with ya
He woulda been in a wheelie across that and into the 3 foot deep water hole around the corner without hesitation....that shiny bike woulda got muddy
Once life slows down a bit (July) you'll have to join us for a day, save you a bunch of time figuring out which parts of that hydroline are big bike friendly as some aren't and some are
The shiny bike tried to take a nap in at least one mud hole, the yellow one managed to keep its feet all day which is not how things usually go. Any weekend you're up for a run let me know. I think we're going to head out that way or possibly around Calabogie next weekend.
Allen ravine is offline   Reply With Quote
Old 05-07-2012, 05:47 AM   #4817
tarzan30
tarzan30's Avatar
Oddometer: 439
I wouldnt even call that one a mud hole! that is just a minor puddle! LOL
There is two types of mud/water holes
1. back wheel only gets dirty. "think parting of the sea!"
2. both wheels get clean! cus its so dam long or deep!
LOL
Just trying to keep the rubber side down
tarzan30 is offline   Reply With Quote
Old 05-07-2012, 05:53 AM   #4818
Rider23
-<EvilTed>-
Rider23's Avatar
Oddometer: 800
LOL
The faster you go, the smoother it gets
Moab 2012
Rider23 is offline   Reply With Quote
Old 05-07-2012, 07:37 AM   #4819
Rider23
-<EvilTed>-
Rider23's Avatar
Oddometer: 800
FYI
Just reading about a guy in California.
Pot Illegal, Even for Trades
A California man was arrested
in March after trying to buy
a used Motorcycle with
about $8000.00 worth of
marijuana. According to
an officer on the scene,
the man said, " I know you
can't sell it, but I thought it was
okay to trade it"
Moab 2012
Old 05-07-2012, 07:41 AM   #4820
tarzan30
tarzan30's Avatar
Oddometer: 439
Originally Posted by Rider23 View Post
FYI
okay to trade it"
I got some misc parts for "TRADE"
let me know what you got... LOL
Old 05-07-2012, 08:53 AM   #4821
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,940
Looking for a drift: time to change the steering head bearings on both of our GS BMWs and the lower ball on the stem is easy to get out if you have a 1/8" drift, as you can punch it off using the two holes in the steering yoke, but those holes are about 1.25 deep and none of the drifts I've found so far is that long.
Anyone have any idea where I can find that kind of tool, or some hardened rod I can use that way?
This is the kind of thing I need, but longer than normal:
This is what the outer bearing race looked like. (Bike handled terribly, of course)
Emmbeedee screwed with this post 05-07-2012 at 10:10 AM
Old 05-07-2012, 10:17 AM   #4822
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,738
Long drill bit, cut off end.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 05-07-2012, 10:25 AM   #4823
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,940
Good suggestion. I considered that originally but all the bits I had would have ended up too short but I could buy a couple of longer bits just for that purpose.
Old 05-07-2012, 12:03 PM   #4824
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,991
I used a drift like you show in your pic. Once the bearing started moving it was easy to keep it going. I just used a nail and could tap it off with out much force the last little bit.
pelvis_98 is online now   Reply With Quote
Old 05-07-2012, 03:42 PM   #4825
heli00
heli00's Avatar
Oddometer: 9
Originally Posted by thumpididump View Post
Hey Ovi,
How did you store the bike this past winter? Carb bowl drained? If not, then perhaps your pilot jet is clogged. If it was running properly last fall, and this spring you needed to mess around with the pilot jet to make it run better, then obviously something has happened to the pilot circuit, ie, the fuel broke down and gummed up the insides. That's where I'd start.
Derek
Thanks Derek.yes, everything was good last fall. I did drained the carb bowl, but I didn't run the motor after that. I suppose just draining the bawl may not be enough. Maybe I should have ran the engine until it would stop, that way all the gas left in the carb would have been consumed. Do you know, once the bowl is drained, is there still gas inside the carb?
I'll start with the pilot for now.
Ovi.
heli00 is offline   Reply With Quote
Old 05-07-2012, 05:38 PM   #4826
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,940
Thanks for this, Brian. I saw on F800Riders that you had changed yours so I wondered what tool you had used. I found some drill bits today which look like they'll get the race started (Cue audio - Gentlemen, start your engines!) and once it's moving, use the nail trick like you described.
Old 05-07-2012, 05:39 PM   #4827
Rider23
-<EvilTed>-
Rider23's Avatar
Oddometer: 800
Ovi.
There's always fuel left even if you run it dry, fuel stabilizer is the best bet. if the bike was running fine when you put it away then its a safe bet its the old gas that plugged it up.
Moab 2012
Old 05-08-2012, 03:27 AM   #4828
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,543
If that all it is, fresh gas and some seafoam might do the trick
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 05-08-2012, 03:40 AM   #4829
Rider23
-<EvilTed>-
Rider23's Avatar
Oddometer: 800
Recap lol I meant that stabilizer is better than draining in the fall. Not the cure for the problem :)
Moab 2012
Old 05-08-2012, 03:41 AM   #4830
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,104
UPS
after receiving bling by UPS, a few weeks later I receive in the mail a bill from them. Do I really have to pay it?
shipwrek12001 is offline   Reply With Quote
Times are GMT -7.   It's 10:34 AM.
