Old 01-17-2009, 09:08 PM   #1
Lobby OP
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,287
Motorcycles in Pickup Truck Beds
Folks,
Say you want to transport a GS sized bike in the back of your pickup truck. How would you do that?
My pickup has a 79 inch (6.56 feet, 200 cm) bed length. The total length of my bike is about 8 feet (244 cm).
How do you tie it down? Do you use a front wheel chock?
Any advice / pictures is appreciated.
Lobby is offline   Reply With Quote
Old 01-17-2009, 10:03 PM   #2
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
like this:
Operation Rescue Jamie: straps to the front triple tree, tighten down so there's a little compression on the forks. I just strapped down the rear ones to prevent swaying.
datchew is offline   Reply With Quote
Old 01-17-2009, 10:06 PM   #3
Lobby OP
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,287
What prevents the front wheel from turning?
Old 01-17-2009, 10:34 PM   #4
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 3,999
Just load it in pointed straight ahead. The front wheel will be pressed against the forward wall of the bed. The rubber in the tire will ever so slightly compress, as the tie downs are tightened.
I like to use about a 2 square foot piece of 3/4" plywood under the side stand, to help spread the load in the bed and keep the bike a little more upright. A couple more straps to the rear peg mounts or rear sub-frame to keep the ass-end solidly planted.
Most importantly, I recheck my straps within the first block or two of leaving, before getting on the highway. That's when you'll find out if the bike has shifted, and anything has loosened up. From there on out, I recheck all the straps every time I stop for gas, lunch, etc. If I travel overnight, I always check the straps first thing on the morning, and especially if they get wet.
http://www.oilandpiston.com/
Well hes one of those who knows that life
Is just a leap of faith
Spread your arms and hold you breath
And always trust your cape (Guy Clark)
VonHelm is offline   Reply With Quote
Old 01-17-2009, 10:47 PM   #5
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 3,999
Another thing: Most good bike shops sell something called "soft loops". They are made of the same nylon webbing as tie down straps. Each one is about a foot long, and is sewn together in the middle, so they look like the number 8.
You can loop them around the front frame, in places you can't get a tie down hook in, and they won't scratch the paint. Loop a loop through the loop, sort of like a slip-knot, and then hook the tie strap hook to the loose end of the loop. It is not as complicated as it sounds. Any of the shop guys can show you how to do it.
Old 01-17-2009, 10:55 PM   #6
homeontherange
Ochlophobiac
homeontherange's Avatar
Oddometer: 207
I totally take back all those times I didn't want to nap when I was younger.
homeontherange is offline   Reply With Quote
Old 01-17-2009, 11:08 PM   #7
Lobby OP
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,287
Originally Posted by homeontherange
Screwing with a pui moderator isn't wise.
Old 01-17-2009, 11:14 PM   #8
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
these do
http://www.ccrsport.com/index.php?ma...505316c0c30d24
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 01-17-2009, 11:35 PM   #9
Jonnylotto
All out of care
Jonnylotto's Avatar
Oddometer: 15,520
In theory, if you're balancing your ties, you have one on each side of the handlebar or tripletree or fork. This will theoretically prevent the front wheel from turning.
I've never seen this in real life but I read it somewhere on the internet.
I'm done.
Jonnylotto is offline   Reply With Quote
Old 01-17-2009, 11:50 PM   #10
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 3,999
Oooh, look!
Pictures: http://www.discountramps.com/article...e-tie-down.htm
Old 01-18-2009, 05:55 AM   #11
cagiva549
whats a cagiva
Oddometer: 2,454
If you can turn your bike where the front tire fits into a front cornor of the truck bed it will stay in place . Pick up a handfull of U bolts at the hardware store and place them in your truck bed where tie downs would do the most good . I tie mine as high up on the bed as possible , the bike is secured from side to side . Let the bikes suspension do what it is supposed to do , be sure the tires cant slide side to side . I secure the bike tires in my trailer then attach a strap to each side so it cant rock to and fro , when you shake the bike the whole trailer shacks and the suspension has no load . If you have to cinch the bikes suspension down to haul it then go from sea level to 10,000 ft plus it is very possible to have a leaking fork seal when you get there . My bikes get plenty of trailer time because one is never enough when I find a good play area . The Ducati doesn't get much use , it's impossible to play leagal on it . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 01-18-2009, 06:31 AM   #12
mustang
Lurker Extraordinaire
mustang's Avatar
Oddometer: 635
mustang is offline   Reply With Quote
Old 01-18-2009, 07:52 AM   #13
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
When you run the straps to the handlebars or the triple trees, the straps keep the wheel from turning. I always double strap the front of the bike, and if I'm going on longer trips I'll tie down the rear of the bike as well.
I never leave the kickstand down while hauling the bike. I don't use a wheel chock either, though I will put a piece of wood along the front of the truck bed to spread the load of the front wheel pushing against the front rail.
How strapping down and leveling the bike is a one man job. Get the bike centered in the bed on the side stand with the front wheel against the front of the bed. Run the left strap up to the handlebar or tripletree, and leave it just a little loose. Move over to the right side of the bike, and hook that strap up. Then tighten the right strap. As you tighten the right strap the bike will stand up, and compress the suspension against the left strap that you left a little loose and the front of the bed.
I use a combination of ratchet straps and regular friction straps(cam buckle).
I start the process off with the friction straps because as you're snugging down the right side of the bike, you'll be taking up tons of slack as the bike stands up. Ratchet straps don't deal well with tons of slack as the spool will fill up and bind if there is too much slack. Another trick I found with the cam straps is to put the cam end towards the bike instead of at the truck anchor. I do this because as you pull the loose end of the strap to tighten everything down, you're also pulling down on the front of the bike to help compress the suspension even better.
Once the bike is upright, you can continue to tighten both the right and left side equally, though you probably won't be able to do much more tightening. This is when i kick up the side stand. I like to double up the front so now I go back, and put on the ratched straps somewhere else on the front of the bike. If it's a long trip I'll strap down the back as well, but really with all the compression going on up front, the back isn't going to move around much at all.
Some people don't believe in compressing the suspension as they are afraid that It'll sag. I don't think this is the case. The springs are designed to compress, and often compress totally while riding. Just because you're holding them in a spot for a length of time doesn't mean they're going to take a set. IMHO the forks are no more likely to take a set when compressed for hauling than they are when riding and using the full travel of your forks.
Old 01-18-2009, 07:56 AM   #14
Jack90210
mindful
Jack90210's Avatar
Oddometer: 15,271
Tie-downs attached to handlebars will help keep the tire from turning but, as you suspect, won't completely prevent it. It does help to have the bike straight up and down when you are done tying it down. I'd recommend a minimum of four ratchet-style tie-downs.
If you have the inclination, it would probably help to wedge the tire in at the front of the bed with a couple of 4x4 wood pieces, cut to just the right size. Never tried that, though.
EDIT: Nice write-up, Gramps, I do it almost exactly the way you do, side-stand and all (after much solo trial-and-error over the years). I use ratchet straps everywhere, but if you've done it a bunch of times you know how to start the ratchet spool with just a little bit of strap so that you don't wind up with too much spooled strap at the end. I also am a big believer in compressing the suspension -- when I am done, I try HARD to bounce the suspension. If there's too much travel left in the suspension after tie-down, you can lose a tie-down on a hard bump when the suspension travels to the bottom of its stroke.
I must say that my son has exposed a reservoir of love and of worry within me that I never knew existed. --nskitts, 9/2/12
Jack90210 screwed with this post 01-18-2009 at 08:03 AM
Jack90210 is offline   Reply With Quote
Old 01-18-2009, 08:07 AM   #15
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
what about messing with a hungover moderator? he he.
No worries. When you tighten those straps and slightly compress the front end, it presses the tire against the fwd wall of the bed. You'd have a tough time turning the handlebars at this point.
It's the only pic i have above, but the straps go to the front corner of the bed so they're pulling down and fwd and also providing lateral stabilization. No wheel chocks, etc, are needed.
The rear end will lean a bit if you don't put the rear straps on, but it's not that big of a deal.
To avoid special straps and such, i just put the hooks of each end at the attachment point and only have the web of the nylon strap contacting the bike.
Times are GMT -7.   It's 05:34 PM.
