Old 01-18-2009, 08:18 AM   #16
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,354
Leo,
A couple things I can add...number one, big bikes can kink the front of the truck bed. I use one of these:
That device also serves to keep the front wheel from kicking out.
gaspipe [the original]
Hair of the dog that bit me, Lloyd...
gaspipe is offline   Reply With Quote
Old 01-18-2009, 08:46 AM   #17
C Squared
Now with TURBO!
C Squared's Avatar
Oddometer: 7,319
Just another thumbs up for placing the front tire into the corner of the bed.
I place the tire in the corner and then with the side stand down I tighten the strap on that side down til the rear tire is light. Then the off stand side to compress the forks. A couple or straps on the rear to keep the rear end from sliding and your'er off. Ratchet style work better than friction for the front. However, QUALITY" friction style are fine. I have gone thousants of miles this way over the years and never had a bike so much as move a little on me. Do check all straps after the first few miles.
I can explain it to you, but, I can't understand it for you.
C Squared is offline   Reply With Quote
Old 01-18-2009, 09:19 AM   #18
Lobby OP
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,868
Originally Posted by Jonnylotto
In theory, if you're balancing your ties, you have one on each side of the handlebar or tripletree or fork. This will theoretically prevent the front wheel from turning.
I've never seen this in real life but I read it somewhere on the internet.
I sense a sarcastic tone here.
I once tried to carry a small scooter in the bet of my truck. It took several tie down attempts before the front wheel wouldn't turn once underway.
And in case you hadn't thought about it, having your bike's front wheels turn isn't a good deal. DAMHIK.
Lobby is offline   Reply With Quote
Old 01-18-2009, 09:21 AM   #19
Lobby OP
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,868
Originally Posted by VonHelm
Discount Tramps? I so clicked on that link. All they had there was motorcycle stuff, though.
Seriously, nice pics of a good solution.
Old 01-18-2009, 09:25 AM   #20
Lobby OP
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,868
Originally Posted by gaspipe
Leo,
Looks like these have to be screwed into the bed?
Old 01-18-2009, 09:25 AM   #21
Steve1100gs
Steve1100gs's Avatar
Oddometer: 343
Originally Posted by Lobby
What prevents the front wheel from turning?
Did you mean what stops the steering from turning? I think that could have been the cause of the derision. I thought you were asking why the front wheel doesn't spin while the weight of the bike strapped in to a truck bed holds it still....
Anyhow,
Nose em into the corners and they stay put for sure.
+1 on the U bolts into the bed. I have just two in the center line (front and back) so I can get two bikes in. If I'm putting big bikes in, I put a length of scaffolding board (timber) under the bike to take the stress off the flap hinge.
Errr......
Steve1100gs is offline   Reply With Quote
Old 01-18-2009, 09:52 AM   #22
lateapex31
lateapex31's Avatar
Oddometer: 185
I always put something (block of wood) in between the front tire and the bottom triple. Otherwise when you hit a bump that compresses the bike suspension, chances are the straps will slacken and possibly fall off.
I am the gun lobby.
lateapex31 is offline   Reply With Quote
Old 01-18-2009, 10:17 AM   #23
RedRyder
Jose Adventurista
RedRyder's Avatar
Oddometer: 762
they bolt onto the front of the box at approx centre of the wheel height. Keeps the front of the box from bending, stops the wheel from turning and also provide more tie down points for straps.
Joe
Mason-Dixon Line
Jose
RedRyder is offline   Reply With Quote
Old 01-18-2009, 10:45 AM   #24
Jack90210
mindful
Jack90210's Avatar
Oddometer: 15,361
That looks SWEET. I think I need one for my landscape trailer.
I must say that my son has exposed a reservoir of love and of worry within me that I never knew existed. --nskitts, 9/2/12
Jack90210 is offline   Reply With Quote
Old 01-18-2009, 10:47 AM   #25
the_gr8t_waldo
Oddometer: 2,159
it would be nice to have the tail gate up n locked..but the bike will ride fine as long as both tires are in contact with the truck bed. and if you'r truck's tail gate is beefy enought, even that can support the weight of the rear wheel. loops on each side of the handle bars, and wratcheting straps foward n down to some attachment points. will take care of the front loading of the struts. in the rear loops around the passenger hand holds and back n down to attachment points. that's the basics. more straps to more points, just make it more betterer!
the_gr8t_waldo is offline   Reply With Quote
Old 01-18-2009, 10:55 AM   #26
Lobby OP
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,868
So, uh, how do you guys get the bikes up to the bed? Which ramps do you like?
Old 01-18-2009, 11:59 AM   #27
the_gr8t_waldo
Oddometer: 2,159
i liked to back up to a small hill and ride the bike up a homemade ramp. about 6 ft long 2X12fir.
Old 01-18-2009, 01:32 PM   #28
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
A short bed Ford F150 can haul a Guzzi and a Harley like this.
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 01-18-2009, 08:39 PM   #29
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
http://www.advrider.com/forums/showthread.php?t=62080
MookieBlaylock is offline   Reply With Quote
Old 01-18-2009, 08:43 PM   #30
TexasMule
Float away ya fairy...
TexasMule's Avatar
Oddometer: 3,911
I got a Tiger up, you should be able to get your Katoom in your monster truck.
I use this. Like others have said, it REALLY helps if you can find a slope to help with the "push up". Not sure if Elsa's got the oomph to get the KTM up the ramp on a flat surface.
TMule
You can buy everything, but more time...
______________________________________________
-to my mind alloy triumph tanks rank near titties in their inherent attractiveness -Mutt
TexasMule is offline   Reply With Quote
Times are GMT -7.   It's 05:55 PM.
