Old 10-26-2013, 07:48 PM   #1531
Beak
Oglyarchy Hunter
Beak's Avatar
Oddometer: 3,323
Originally Posted by Dualsport4ever View Post
Bought this bike 2 years ago for a winter project. Basically just needed a good cleaning (by means of full disassembly) and freshening up. Lots of fun to ride - love old bikes and hope to acquire a few more! Love this thread! 7600 miles on the odo.
Nice! It looks brand new!
"I haven't been paying attention, I just wanted some" - Anorak
Beak is offline   Reply With Quote
Old 10-26-2013, 08:43 PM   #1532
Kenyellowdesmo
Oddometer: 3
Originally Posted by DoubleBit View Post
Not sure on the sprocket sizes, where to even find the info on what was originally installed. Usually that's where I've left my bikes, seems a good compromise. If you are light enough and your roads are flat, taller than stock gearing may work for you. I wouldn't go as high as a whole countershaft sprocket tooth up. Maybe go down 3-5 on the rear sprocket. There's a bunch of discussion about sprocket changes in the Minimalist Touring thread under thumpers, maybe that'd be helpful.
As for the overly rich condition, I'd have to ask how it ran on the original carb? Maybe just jet that one up to match your new pipe. My observations have been that folks tend to put too much carb on their bikes, hot-rods, etc. Of course double check all your other tuning settings like valves and ignition before getting to far lost too.
Just check the sprocket on my bike,its 14t-53t....I'll try to go down on rear and find what's best for flat road!
Kenyellowdesmo is offline   Reply With Quote
Old 10-26-2013, 09:29 PM   #1533
DoubleBit
DoubleBit's Avatar
Oddometer: 305
Haven't had a 350, had '76 250 though and it was a tough, reliable ride, back in the early 80s. I imaging a 350 would be the same with more grunt... Looks like the Rh side cover is missing... Hard to find but easy to install..
Current rides: DR650, CT90.
Riding whatever runs, wherever I want.
DoubleBit is offline   Reply With Quote
Old 10-27-2013, 02:10 AM   #1534
Hotwheelbill
Hotwheelbill's Avatar
Oddometer: 90
Has anyone used one of the SS Bolt kits off of ebay before?
I would like to change out all of my screw head bolts on the case, with allen head bolts. Im not looking to tear it down, so I should be ok to just change out and retorque one at a time , right?
Hotwheelbill is offline   Reply With Quote
Old 10-27-2013, 06:16 AM   #1535
brucifer
brucifer's Avatar
Oddometer: 2,557
That should be fine.
2014.5 Kawasaki KLR650 NE-2002 Kawasaki KLX300R-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 10-27-2013, 06:52 AM   #1536
skorpioskorpio
skorpioskorpio's Avatar
Oddometer: 534
Make sure you put anti-sieze on every stainless steel fastener, or you'll be looking back fondly on those philips heads you took off. Stainless galls and will fuse itself to light metals and especially other stainless. Stainless is great but you need to follow a few rules.
skorpioskorpio is offline   Reply With Quote
Old 10-27-2013, 07:08 AM   #1537
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,091
+1 on the anti-seize. SS will gall more readily in aluminum than about any other combo.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 10-27-2013, 12:57 PM   #1538
EnduroRdr
Woods Racer & D/S Rider
EnduroRdr's Avatar
Location: Formerly South MS, LR-Ar, Houston-Tx, now BR-La
Oddometer: 798
Originally Posted by Skowinski View Post
On the local CL, about 6k miles, all original, with title. Asking $1700 obo. Anyone have one of these? I'm not really sure why, but it really appeals to me.
Yup I also had a 73, I kinda like the 73 a little better mostly cause of looks but the 76 was a great bike - the center port head frame may be a little stronger than the center backbone on previous models. Looks like you got one in great shape (except that leaking fork seal ). Keep posting as you move forward - inquiring minds like to know
EnduroRdr is offline   Reply With Quote
Old 10-27-2013, 02:07 PM   #1539
Hotwheelbill
Oddometer: 90
OK, Thanks for the heads up on that.
Old 10-27-2013, 06:25 PM   #1540
Kenyellowdesmo
Oddometer: 3
Just bought it from my friend.....
the engine is sound good except the Valves noice.
Front fork need to be changed! rear shocks also.
I'll try to rebuild it first,if it not work....i'll find the new pairs!
Old 11-01-2013, 04:17 AM   #1541
lookfar
from the land of OZ
Oddometer: 677
If you want to use stainless bolts and nuts, the trick is to make sure that they are different grades- eg. 316 bolt and 304 nut. Solves the galling problem.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 11-06-2013, 02:03 PM   #1542
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 785
Perhaps, but I've always used some sort of anti-sieze of any threaded stainless steel connection. Otherwise you'll only get it tight enough to gall the threads into whatever position the nut or bolt stops, and never any more.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 is offline   Reply With Quote
Old 11-06-2013, 03:51 PM   #1543
Beak
Oglyarchy Hunter
Beak's Avatar
Oddometer: 3,323
I've got a line on a complete front end from a 2001 XR250R. I'm considering attempting to mate it to my 1986 XL250R (disc brake, better suspension, more ground clearance, etc). Anyone have any thoughts. I'm guessing the steer tube will likely have to be machined at the very least....
Old 11-12-2013, 11:04 AM   #1544
Danconia
Danconia's Avatar
Oddometer: 3
De-Flowering Post
Question:
Can a XL350 K1 (73') exhaust be fitted to a XL250 k2 (75')? Or maybe a new exhaust flange could make it work?
I have seen some unverified accounts that it will work. Obviously they aren't the same part number and, according to cmsnl, the part number for the exhaust gasket is different between the two bikes. The exhaust in question is probably from an old race bike and has some great bends so I REAAALLY want it to work.
Thanks,
Noob looking to brag about his 75' XL250 basketcase
Danconia is offline   Reply With Quote
Old 11-12-2013, 11:30 AM   #1545
MCM
Oddometer: 95
XL Seat covers
Just picked up a 80 XL500s.
Anyone have a preference on seat covers? Several sellers on ebay and there all close in price. Pit replica, 1carri23, joemamma1931 etc. Any recommendations? Thanks!
Did some reading.. went with Gumtwo. Looks like a good option.
MCM screwed with this post 11-12-2013 at 12:08 PM
MCM is offline   Reply With Quote
Times are GMT -7.   It's 10:55 PM.
