Old 08-12-2014, 02:04 PM   #2116
HerrDeacon
HerrDeacon's Avatar
Oddometer: 35
Originally Posted by Tugboat56 View Post
About to do a top end job on my CB/CL100, and am planning on changing the cam chain. To do that, I have to remove the rotor/flywheel. Can I just use one of the rotor pullers you can rent at an auto parts place, or does it take a special puller of some sort?
Its a special tool, don't use the automotive type pullers as you can damage the rotor. The special tool just threads into the center of the rotor until it pops off. They aren't that expensive, usually around $10. Not sure about the CB100 but on some of the old Honda's the rear wheel axle can be used since its the same thread as the rotor.
HerrDeacon is offline   Reply With Quote
Old 08-12-2014, 06:24 PM   #2117
jjxtrider
questionable
jjxtrider's Avatar
Oddometer: 1,209
Ya, never use those gear pullers on a flywheel. Many good flywheels have been bent up with them , plus sometimes thecrank end gets mushroomed as well.
A local Honda dealer may have one also or just do it for you quickly (crooked ones will charge).
Yamaha XT600 x 2, ..Yamaha XT600E/600N(SM),..Yamaha XT660(E) hybrid,.. KTM 525XC , Suzuki '01 DR650 & '07 LTR450,...Kawasaki KLX650.
jjxtrider is offline   Reply With Quote
Old 08-12-2014, 07:48 PM   #2118
baltimoron
Oddometer: 17
Originally Posted by baltimoron View Post
Hello Everyone,
It's been a while since my last posts with lots of hangups dealing with the old carb on this bike. I ended up going ahead and purchasing a new Mikuni carb and throttle kit from Dave at Xlint. It's all hooked up now, but as HerrDeacon mentioned, I should make sure that there isn't gas in the oil from the old leaky carb. So, I've got the oil draining now and am going to fill it tomorrow before I try to start her up.
I did somewhat of a chop job on the stock air box by removing it's holding bolts so that I could turn it inside the frame, and then using a dremel tool to cut the hole wide enough so that the new air filter fits through. Now I better not ride in the rain! I may fashion some sort of extension for this thing for down the road.
I also found a SuperTrapp exhaust on ebay for $129.00 and hooked that up... let's see what happens!
I got the bike running (with some great customer service from Xlint for the new carb, might I add) and rode it around the block, which is a serious achievement since it was not doing so well with the old carb!
I bolted on the exhaust that i bought online, and there is smoke coming out around the header pipe where it meets the engine. Is there supposed to be a gasket there? The original flanges on the stock exhaust do not fit the new header. Anyone know about this?
baltimoron is offline   Reply With Quote
Old 08-12-2014, 09:52 PM   #2119
jjxtrider
questionable
jjxtrider's Avatar
Oddometer: 1,209
There should be a gasket, usually like a copper crush ring between the header and head. If the muffler schematic doesn't link direct, open it up and you'll see it , item #3, http://www.rockymountainatvmc.com/oem-schematic/1
Old 08-13-2014, 03:57 PM   #2120
Bendernz
Torrential
Bendernz's Avatar
Oddometer: 567
Use the rear axle - it's the same thread. I used a shifting spanner (crescent) loosely over the axle when it was threaded into the rotor and whacked it using a nylon-headed hammer. Obviously the whacking motion is away from the engine. Works just fine.
Bendernz is online now   Reply With Quote
Old 08-13-2014, 05:38 PM   #2121
RPN
Oddometer: 338
Have been scanning old slides and found this favourite of mine featuring my XL600 with grey import Paris Dakar kit.
RPN is offline   Reply With Quote
Old 08-14-2014, 06:58 PM   #2122
baltimoron
Oddometer: 17
Thanks, jjxtrider. The website link for schematics is awesome!
Old 08-19-2014, 01:38 AM   #2123
lookfar
from the land of OZ
Oddometer: 679
That is an old pic, you were running the old "super" petrol too by the look of your white pipe.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 08-27-2014, 06:24 AM   #2124
Canadian80
Oddometer: 2
Originally Posted by vagabondmatt View Post
Hi All,
I just discovered this thread, and I am slowly reading my way through it. I just scored this 1979 Honda XL250S dual sport bike in fantastic condition with really low miles. The guy I bought it from just put a TON of new parts on the bike and was really OCD about keeping it clean and masterfully tuned. The only thing I am wrestling with are some wonky electrical issues...clearly the 6v system on certain years were very fussy. Over the weekend I identified three main issues (handlebar brake lever switch broken, turn signal flash relay not working, and rear turn signals so small and dim you can't see them) and have ordered all the necessary parts to hopefully get that all sorted.
New parts on the bike include: tires and tubes, exhaust with spark arrestor muffler, battery, front and rear sprockets, chain, shocks, air filter, oil filter, fuel lines and filter, vent and drain hoses, petcock, mirrors, rear break light and turn signals, front and rear brakes, and fork tube seals and oil. I am one happy boy!
I had several XRs and a couple of XLs when I was a young lad many years ago, and I've always really missed the XLs. Now for the pics...
Beautiful XL250S! What brand and model are the exhaust and rear shocks? Where did you get them? Any numbers or labels on them?
Thanks in advance,
-Ryan
Canadian80 is offline   Reply With Quote
Old 08-27-2014, 06:49 PM   #2125
luckychucky
luckychucky's Avatar
Oddometer: 1,395
Get it Running?
Originally Posted by kstklt View Post
Greeting good folks! So stoked to find this thread! Shades light to my XL185s restoration project!
I got my 83 XL185s 2 years ago, this is how it looks like when i first got it. Malaysia (where i live) has bad weather for motorcycles, it's in very bad shape, but it is in running condition when i got it.
after a good wash, the 'black' front mud guard turns out to be white
The engine had been dismantled, cleaned and polished the exterior, but not too sure what else should be replaced for a complete rebuild? Need your advice guys. =)
And also, does anybody happend to have the wiring diagram for this particular model? My wire loom is really messy, I can figure out most but not sure where the wires from the CDI unit should be connect to ...
any help would be very appreciated, thank you so much guys! Help me get my bike running please. =)
Riding it? There is a website full of schematics, some cycle parts site. I can't remember exactly, but just search motorcycle schematics. Good luck. Looking forward to seeing your finished 185.
luckychucky is offline   Reply With Quote
Old 08-31-2014, 08:51 PM   #2126
Ixheimer
Ixheimer's Avatar
Oddometer: 93
Xl175
On the subject of XL's. Great to find a thread about these fine old machines. My first bike back in the mid (late?) '70s was an XL175. I learned to ride on that little machine, much of the mileage being on dirt roads & gravel pits. I was never a racer or motocrosser, but those early years exploring the back roads of north eastern Alberta have served me well with respect to riding experience on varied terrain. My buddy had a Suzuki 185 enduro of some sort, don't recall the model but we spent many weekends tooling around in the dirt on those bikes. Our other compadres (spelling?) were tearing up the backroads on two stroke CanAms. More power than our relatively docile four strokes, but it didn't take long for most of them to blow the engines on the CanAms, the majority of them didn't last very long!
(edit) I think my pal's Suzuki was actually a 2 stroker. In any case, it was more reliable & less high strung than those CanAms with the Rotax screamers! Len was a bit partial to 2 strokes. I recall him reminiscing about a certain infamous Kawi 2 stroke triple he owned before we met through our occupation maintaining aeroplanes. Now that was a high strung crazy bike, the true definition of a 'crotch rocket'.
Climbing a hill near Cherry Grove Alberta. It took some yanking to get the front wheel off the ground near the top of the hill going almost 0 mph & I ended up sliding off the back of the bike after going over all the way. Landed on both feet and held on to it though. Only damage was a bent licence plate.
I ended up out of the country for a few years & stored the bike at my parent's place in British Columbia. Here I'm back for a visit preparing to give it a run as my Dad's brother Johnny from Winterpeg looks on.
Dad's wearing a helmet, so he must have taken it for a spin 'round the block too.
I wish I still had that old thumper.
Ixheimer screwed with this post 09-02-2014 at 07:32 PM
Ixheimer is offline   Reply With Quote
Old 09-01-2014, 09:20 AM   #2127
brucifer
brucifer's Avatar
Oddometer: 2,557
Cool pics and back story, Iexheimer.
2014.5 Kawasaki KLR650 NE-2002 Kawasaki KLX300R-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 09-02-2014, 04:55 AM   #2128
piratemcgee
Oddometer: 4
Hello all, first post on ADV but I've frequented expeditionportal for quite some time. Anyways here's my XL185s I just picked up. 1979 with 4k miles, tires are good tread wise but cracking (ordered Shinko 244's for now), the carb needed cleaned as it had been sitting but no rust, and someone disconnected the turn signals. It now runs great but is pretty cold blooded. Looking for a rightside cover if anyone knows of one.
piratemcgee is offline   Reply With Quote
Old 09-02-2014, 03:50 PM   #2129
TheCheesus
Fabrication Warrior
TheCheesus's Avatar
Oddometer: 55
EDIT just saw the old's cool FM thread. If anybody has an issue with my post PM me and I'll sort it and post a thread in the FM. Sorry!! Don't frequent y'all much
Hey XL riders
Not sure if you have a classifieds section like we do over on the NX thread but I have some XL parts I wanted to offer here first before putting them on eBay
These are off a 1985 XL350R
I have the ignition switch, entire front end (forks, rim, tire, caliper, rotor, master cylinder, brake line, steering stem and triple trees), a whole swingarm with the clicker shock and shock linkage along with the rear axle. I have a whole frame with kickstand and right footpeg bracket. I have the voltage regulator / rectifier (they're separate I think?), the CDI box, and the coil. Have the rear brake pedal and linkage.
I will cut someone a salacious deal if you're local to me (Indianapolis) and even better if you take it all!!. Less so if I have to go through the mega hassle of shipping it, but PM me with wants or needs. I'll break some of this stuff down further if you need something small. All of it is in decent --> very good condition. Thanks!
My insurance guy tells me that as a motorcycle rider, statistically speaking, my life will probably be too short to worry about whether I bought the right bike or not.
2 x 89 NX250's, 90 VTR250
TheCheesus is offline   Reply With Quote
Old 09-04-2014, 05:29 PM   #2130
SenorNoob
SenorNoob's Avatar
Oddometer: 18
This is probably common knowledge but, the air cut-off valve that's listed for the earlier XL350 still works on a '78. I found a site with all of them listed and pictures laying over a ruler. All of the valve appear to have the same size diaphragm so I just picked the one that had the same style of metal tip.
Also, does anyone know of another bikes exhaust that would work from the slip joint back on that same '78 XL350? I'm open to needing minor modifications but I don't have a way to bend pipe. I'm aware that Dave has a complete replacement system but it says e-mail for price so I'm kinda scared to find out.
-Luke
SenorNoob is offline   Reply With Quote
Times are GMT -7.   It's 09:27 PM.
