Thread Tools Rating: Thread Rating: 28 votes, 4.86 average. Display Modes
Old 11-07-2012, 04:36 PM   #826
Jason F.
Will Ride for Beer...
Jason F.'s Avatar
Oddometer: 341
i exchange my tanks at a local welding supply place. if you get MIG gas it is mixed but if you ask for CO2 it is just staight CO2. same story as above, it all comes out of the same tank.
"I've come to realize that just about everything is none of my business." Br. Cassian Vigna
Jason F. is offline   Reply With Quote
Old 11-08-2012, 05:11 AM   #827
Apocalypse Cow
SHEEP LIE!!!!!
Apocalypse Cow's Avatar
Oddometer: 378
Conical
Anyone use or not use a conical fermentor for any particular reason?
I have seen some fairly cheap tanks out there but am thinking about holding off until I go to larger batches, 20 gal+, I can buy a fair few buckets for the price of anything smaller.
Also, anyone harvesting yeast? How long have you been able to keep it between batches and does it seem to have a life span, looses potencey after so many batches?
If god had meant for us to be vegetarians he would have made brocccoli more fun to shoot at.
"I've set the bar high because I'm tired ducking."
Apocalypse Cow is offline   Reply With Quote
Old 11-08-2012, 03:19 PM   #828
tootal
Backroad traveler
tootal's Avatar
Oddometer: 196
We've been using a More Beer 14 gal. conical for a couple of years now. We love it! You can pressurize it and fill your kegs through the out post. If you force the Starsan out with CO2 and then fill thought the out post you never oxygenate the beer. They make plastic ones but my partner refused to heat up the cleaning water and it ended up making funky beer. He wouldn't heed my advice and ended up suggesting stainless, which I wanted to begin with. I stopped debating at that point and love the fermenter. It will take up to 5 psi of pressure for keg filling.
In my opnion this is the best one on the market today:
http://morebeer.com/view_product/107...ical_Fermenter
Tootal
The difference between ignorance and stupidity is that you can fix ignorance... if you're not stupid!
tootal is offline   Reply With Quote
Old 11-08-2012, 05:29 PM   #829
hyperboarder
Potato Farmer
hyperboarder's Avatar
Oddometer: 1,024
Conicals are nice, but I'm quite content with my carboys and they're definitely cheaper to control temp on. Plus some of the beers that need to sit for a while can be easily shuffled off into a corner and I've still got a few carboys I can ferment in. I don't really see myself switching over, just not quite enough bang for the buck for my current batch size and frequency.
Current: 08 Yamaha WR250R, 05 Suzuki DL1000, 92 Ford E250 Motohauler
Gone but not forgotten: 2008 KLR650, 2000 GSXR1000, 1999 ZX6R, 2000 GSXF600, 2004 Ural Tourist, 99 Suzuki DR650
Quarter Life Crisis 2011 Ural National Rally
hyperboarder is offline   Reply With Quote
Old 11-08-2012, 05:50 PM   #830
levain OP
STILL Jim Williams
levain's Avatar
Oddometer: 7,337
I had one and just didn't use it. I prefer pulling yeast off the top of fermenting beer than off the bottom of a conical. They're cool, but don't get one for the cool factor. If you actually think you'll use the bottom dump maybe its worth the investment. Otherwise, I wouldn't bother.
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-09-2012, 02:11 PM   #831
Kinsman
Ribs....for her pleasure
Kinsman's Avatar
Oddometer: 4,085
Interesting take on conicals.
Yeast:I have harvested from primary with great success. I've reused up to about ten generations and could not not notice any difference, but guys who oughta know say I shouldn't.
I've not used this technique but it looks like a good way to run. I'd like to make some slants too....seems pretty straightforward and growing yeast is actually pretty damn easy.
Chris R
Schreckendgust Field, Montana
Kinsman is offline   Reply With Quote
Old 11-10-2012, 06:51 AM   #832
tootal
Backroad traveler
tootal's Avatar
Oddometer: 196
Our reasoning for a conical was the time savings of not having to transfer off the trub after the primary fermentation. With cleaning another car boy, sanatizing everything, transfering and then cleaning everything again we just didn't have time to do all of that. I should say my partner didn't have the time, he's got too many other endeavors! With the conical we just open the dump valve slowly and drop the trub out from under the beer. We could save the yeast but we just don't brew enough to warrant it. It's that time thing again! I noticed the price on the More Beer unit has gone up too! Ouch!
Tootal
Old 11-15-2012, 10:01 AM   #833
bergermeister
housin'
bergermeister's Avatar
Oddometer: 2,076
so I need a new thermostat for my kegerator and have decided on the Love TS2 temperature controller:
I can wire it up as a total on/off easy enough, but then I lose the light. anyone wire it up to interrupt the thermostat such that it only works the compressor? or maybe I just wire the light directly to a plug instead for sake of making it easy?
bergermeister is offline   Reply With Quote
Old 11-15-2012, 10:22 AM   #834
Dansrc51
I need a cape....
Dansrc51's Avatar
Oddometer: 1,589
hmm... hadn't thought of that as my keezer doesn't have a light. interesting point. might have to wire the light directly.
thinking about doing a 1bbl upgrade on my brewery..... looking at stainless steel drums. Thoughts?
Dansrc51 is online now   Reply With Quote
Old 11-15-2012, 06:26 PM   #835
Nytelyte
Somewhere about
Nytelyte's Avatar
Oddometer: 678
I did some reading and it seems that the operation you are seeing is pretty much how that thing is designed to run. You might be able to isolate the light circuit and run a separate electric feed to that on its own, or bypass the full on/off circuit for only the light circuit, which shouldn't be too hard, if you can open the fridge backside enough to see where the light & switch pull off of the main feed. Just add wiring that would circumvent the temp relay that splices straight into the light circuit.
Standard "Unplugged / proper safety / if you electrocute yourself I'm not liable / this post if for entertainment purposes only" disclaimer.
Nytelyte is offline   Reply With Quote
Old 11-15-2012, 06:35 PM   #836
bergermeister
housin'
Oddometer: 2,076
thanks man,
it's an old frigidaire, I think I posted a pic a few pages back. I rewired most of it, so I do know where the light run is located, and have easy access to it (underneath). I think it goes through some sort of relay however. That's likely the way to do it easiest.
Old 11-15-2012, 06:46 PM   #837
Nytelyte
Somewhere about
Nytelyte's Avatar
Oddometer: 678
thanks man,
I don't know your electrical expertise, so if you are well versed, take no offense...
Does that light circuit step down through the relay? Probably not, that being the age it is.. If not, you shouldn't have too many problems. Good Luck! I'd probably turn it on the first couple times on a good fused surge strip (my standard practice when I monkey with something on household current, its easier to reset that then truck out to the garage) rather than plugged straight to the wall.
Horray Beer!
Old 11-15-2012, 07:00 PM   #838
bergermeister
housin'
Oddometer: 2,076
thanks again,
please feel free to offend. I am not an electrician, but do have experience with simple wiring.
I doubt it is stepped down, as the relay is just a small square plastic box, maybe 2"x2" by 1" deep. I can post a pic if helpful, but I think a bypass should work since the light is switched by the door button and therefore needs a constant hot.
here's a few pics, starter relay?
bergermeister screwed with this post 11-15-2012 at 07:24 PM
Old 11-16-2012, 06:37 AM   #839
Nytelyte
Somewhere about
Nytelyte's Avatar
Oddometer: 678
Sounds like you have it nailed, hot bypassing the Love controller straight in to the light circuit. That circuit probably pulls straight off of a always hot side of the relay anyways. Maybe consider adding a fuse to that lead, since (I can't tell from here) the relay might have that in it. Or always run the thing from a fused surge strip, which will also protect the Love controller. Might be a good plan anyway, that aged wiring will make it easy to short since its been moved from its old resting places, cheap insurance and safety first with old electric things, IMHO.
Old 11-16-2012, 07:40 AM   #840
bergermeister
housin'
Oddometer: 2,076
thanks. that's a "before" pic of the wiring, which has all since been replaced. there were so many shorts that it was shocking my wife on the door handle when I brought it home. my buddy and I couldn't figure it out, until we noticed she was not wearing shoes.
in the 2nd pic, you see two runs of wiring going away from the relay to the front of the frig. one is to the thermostat, and one to the light. I'd rather not mess with a 60 yr old relay, so I figure the light remains the easy way to move around the controller, and the main power cord through the controller, then set the thermostat to its coldest setting so always on.
Thread Tools
Times are GMT -7.   It's 07:26 PM.
