Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 34 votes, 4.88 average. Display Modes
Old 11-18-2012, 10:31 PM   #841
urbancowboy
Vicious Cycler
urbancowboy's Avatar
Oddometer: 1,790
thanks
as always, adv is a bad influence:
just bought the keg, 5lb CO2, regulator, etc.
haven't cleaned the keg yet, but i know it will be a hell of a lot quicker to clean one keg than to wash and sanitize 50 bottles.
hope to be drinking from the keg by the end of the week.
milk stout is ready to move to the keg, only did a primary this time (lazy). i moved the bucket into racking location so it can settle overnight.
anyone want to describe their method for carbonating? do you shake or not? how much pressure?
bmw makes motorcycles now?
smugmug link: https://secure.smugmug.com/signup?Coupon=fMX8CMi5nSlps will save you $5 at the best photo hosting site on the internets. you can almost buy a beer in nyc with that. your welcome.
[/B]
urbancowboy is offline   Reply With Quote
Old 11-19-2012, 03:40 AM   #842
levain OP
STILL Jim Williams
levain's Avatar
Oddometer: 7,562
Congrats! Youll never bottle again!
There are lots of ways to force carb. I like the simplest. I put the filled keg in the serving fridge. Hook it up to serving pressure, generally around 10-12 psi and forget about it for a week. It'll be carbonated perfectly, all the sediment will have dropped oit and after a pint or two you'll be drinking clear beer with minimal fuss.
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-19-2012, 07:07 AM   #843
discochris
discochris's Avatar
Location: Sometimes the Twin Cities, Sometimes NW Wisconsin
Oddometer: 1,353
I set it to 20 psi for two days, release the gas, drop it down to about 9 or 10, and it's good to go.
discochris is offline   Reply With Quote
Old 11-19-2012, 08:50 AM   #844
Nytelyte
Somewhere about
Nytelyte's Avatar
Oddometer: 684
's my exact procedure. After a few 'tuning' days at 9 - 10, I drop it to 6 or so for serving pressure, but that will depend on your line lengths.
Nytelyte is offline   Reply With Quote
Old 11-19-2012, 08:52 AM   #845
Dansrc51
I need a cape....
Dansrc51's Avatar
Oddometer: 1,718
I prefer this method. It eliminates all the stupid from the equation such as over carbing, shaking (yeast in your beer), forgetting to adjust and fighting with your regulator. Set it and forget it. Plus, a week is great for clearing your beer.
hi-brow, low wit
Dansrc51 is offline   Reply With Quote
Old 11-19-2012, 11:31 AM   #846
bergermeister
housin'
bergermeister's Avatar
Oddometer: 2,086
I'd like to pick up a kit to start brewing, and would appreciate your thoughts. Hopefully under $1k? I can build my own steel rack like the one I've seen in this thread to keep the numbers down. Thinking of going all grain and 5 gal kegging.
bergermeister is offline   Reply With Quote
Old 11-19-2012, 11:48 AM   #847
levain OP
STILL Jim Williams
levain's Avatar
Oddometer: 7,562
I brewed 5 gal. all grain batches with a 5 gal bucket with a false bottom, 2x ss pots (5gal&8gal), random hoses and a turkey fryer outside. Oh, and an immersion chiller.
You can get going for $2-400. Don't get sucked into thinking you need an expensive setup. You don't. The SS pots are the only major expense.
Old 11-19-2012, 12:34 PM   #848
discochris
discochris's Avatar
Oddometer: 1,353
I've been going lower as well for serving - probably closer to 6-8 as I've had some really foamy batches as of late.
Old 11-19-2012, 01:02 PM   #849
Dansrc51
I need a cape....
Dansrc51's Avatar
Oddometer: 1,718
shop Craigslist. People selling their brew stuff all the time as they upgrade or get bored of brewing (weird I know).
making beer is very easy. making really good beer over and over again takes some trial and error. relax...have a homebrew
hi-brow, low wit
Old 11-19-2012, 02:25 PM   #850
bergermeister
housin'
Oddometer: 2,086
thanks guys, those are good suggestions - and, in fact, I will be using my turkey fryer this Thursday!
anyway, the parents and inlaws want some xmas gift ideas, so I can look at new rather than craigslist.
Old 11-19-2012, 02:34 PM   #851
tootal
Backroad traveler
tootal's Avatar
Oddometer: 196
Well I'm a shaker. You can look up a chart on the web and find out how many Volumes of CO2 is required for the style of beer your making. Look at the chart, know your beer temperature and see where you should set your pressure at. I like to get it about 33 degrees for a couple of days and settle out. Draw off the yeast and then set my CO2 pressure to what's required and start shaking it. I put an OUT connector on the CO2 and put the gas into the OUT post so it bubbles up through the beer. You shake until you don't hear it bubbling anymore. If you have the time to wait by all means do as mentioned above. But using the chart and shaking the keg will carbonate your beer in less than ten minutes and it will be right on. I have never over carbonated using this method. For an example, if you have a pilsner at 40 degress you can use 12 psi on the gauge and shake until there are no more bubbles. Done. Perfect.
Tootal
The difference between ignorance and stupidity is that you can fix ignorance... if you're not stupid!
tootal is offline   Reply With Quote
Old 11-19-2012, 05:11 PM   #852
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,720
I set it at 50psi, leave it 24hrs.
Or 30psi for 48hrs.
I serve most beers at 10psi (38deg). Stout at 7ish psi for now. I want a stout faucet! :cool:
Sent from my fat thumbs on a small touch screen.
GRAVEL WORLDS
'14 KTM ADV R - '06 DRZ 400 - lot's of bicycles
fifthcircle is offline   Reply With Quote
Old 11-19-2012, 10:29 PM   #853
discochris
discochris's Avatar
Oddometer: 1,353
I also bottle a six-pack of each batch I keg, using the sugar drops, so I usually have 70-100 bottles sitting in the basement for when people come over, or when I want something different.
About every fourth or fifth batch I brew, I do specifically to bottle, usually for something that I would not want to drink on a weekly basis. (plus, in order to get enough bottles, I get to buy a bunch of good beer - usually Boulevard or Sierra Nevada, since I like their stubby bottles the best). I usually do this with a porter or most recently an Irish Stout. I just tried the first couple bottles of the stout, bottled 10-1, tonight. It's very good, and since I have a Bass clone on tap right now, it makes an excellent Black and Tan.
If I didn't keg, I'd probably have lost interest long ago. Bottling is messy and a pain IMO. As it is, I brew once a month or so.
Old 11-20-2012, 05:51 PM   #854
urbancowboy
Vicious Cycler
Oddometer: 1,790
50 psi
Or 30psi for 48hrs.
i'm going to try this method.
i can wait for 24 hrs. i can't wait for two weeks. i'm hoping to be trying this stout tomorrow night, and hopefully filling a few bottles to bring along for the weekend.
good thing i don't keep food in the fridge:
[/B]
Old 11-21-2012, 08:12 AM   #855
Dansrc51
I need a cape....
Dansrc51's Avatar
Oddometer: 1,718
Make sure you check the pressure rating on your corney. most are only rated to 35 PSI. that being said, I've gone over that before, but you should know before you take a risk. most likely it will just leak, YMMV
hi-brow, low wit
Thread Tools
Times are GMT -7.   It's 11:35 PM.
