Old 01-25-2009, 10:37 AM   #1
PauHana OP
PauHana's Avatar
Oddometer: 64
2610 gone crazy
at start of ride today my 2610 seemed to be working fine. About 30 miles into the ride it's started doing some strange things. Added a extra (straight line) running off from the route it was running. Keep losing the route, rerouting in wrong direction, etc. Restarted unit and worked ok for a short time than did it again. Restarted again, unit worked but than lost my destination. Did a turn and the route was gone. Thought maybe I screwed up setting up the route but it did the same thing on two different routes I had setup for the ride back home. What the heck?
Am running V9 with latest upgrade (first time I have used unit since upgrade) Firmware is up to date.
Should I try a hard restart? Will I need to reload my maps if I do this??
Up to today have had no issues with unit. Still under warranty as it's a refurb I got last May.
Life is too short for traffic. ~Dan Bellack
PauHana is offline   Reply With Quote
Old 01-25-2009, 03:03 PM   #2
JR356
JR356's Avatar
Oddometer: 3,829
Reboot it,you will not lose maps as they are on the data card(take out the card if this is a concern to you)
JR356
JR356 is offline   Reply With Quote
Old 01-26-2009, 06:43 AM   #3
daGeeeze
Geeezed lightning
daGeeeze's Avatar
Oddometer: 2,051
When my old 2610 started doing similar things I took it into a public restroom and washed it with warm soapy water in the sink. I made sure to clean around the edges of the screen (gently) to get the little stuff that collected there.
It worked fine for a long time after that. It started acting up again and I repeated the washing again with good results.
Riding season is finally getting in gear!<br><br>Pat<br>aka Geeeze
daGeeeze is offline   Reply With Quote
Old 01-26-2009, 12:52 PM   #4
gahboo
Oddometer: 41
Mine just freaked out...
After lots of use it just stopped working, and misbehaved like you say. Rebooting did not help. So, I just bought another one off eBay for $50. They are so cheap now, that I am actually stocking up... Great units for bikes.
gahboo is offline   Reply With Quote
Old 01-27-2009, 02:55 AM   #5
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,125
OK - so at first I thought you were just making a funny comment about giving it a good wash and making it clean and happy.
Then I realized it was a touchscreen - and crud on the screen might be giving it false inputs, so cleaning the screen, and the crud around the edges might eliminate that.
dunno.....
Old 01-27-2009, 04:49 AM   #6
LowAdvRider
Why aren't we Riding?
LowAdvRider's Avatar
Oddometer: 131
Shut off the remote. Sun in the IR port will do this. Also, pull and reset the card. The connection get weird. If nothing else, give it a smack. Works for me every time. Or at least it makes me feel good.
You know what? Stupidity SHOULD be painful!!!
LowAdvRider is offline   Reply With Quote
Old 01-27-2009, 05:32 AM   #7
daGeeeze
Geeezed lightning
daGeeeze's Avatar
Oddometer: 2,051
Sorry, I guess I should have said that but I figured anybody with one would realize it's a touch screen.
Old 01-28-2009, 04:54 AM   #8
PauHana OP
PauHana's Avatar
Oddometer: 64
Ok, I must admit when I first read this I thought that maybe the exhaust fumes were getting to much for you...............but after the 3rd time reading it made sense.
Have reset the unit and the card. Going to give it a run and see what happens. If still buggered up will contact Garmin and see about return while still in warranty.
Old 02-01-2009, 12:21 AM   #9
Jamie Z
Jamie Z's Avatar
Oddometer: 7,709
I've been having a intermittent problem with my 2610, somewhat like the problems described above.
Occasionally my screen will get stuck in one spot and it flickers. That is, as I'm driving, the maps stop moving with my location and the whole map screen wiggles at about 5 Hz. Touching the screen nor pressing the buttons fixes it. Usually if I turn off the GPS and turn it back on it'll be fine.
I've washed the screen (per the strange advice above), reloaded the firmware, did a hard reset, and removed and re-installed the CF card. I'll see if it continues to give me the same problem.
I fear I may have a new GPS in my future.
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is offline   Reply With Quote
Old 02-01-2009, 09:24 PM   #10
Jamie Z
Jamie Z's Avatar
Oddometer: 7,709
A short 100-mile ride today produced no problems. Maybe that fixed it. Hope so.
Jamie
Old 02-02-2009, 04:55 AM   #11
PauHana OP
PauHana's Avatar
Oddometer: 64
Mine is still screwed. Now goes into safe mode whatever that is.
Old 02-02-2009, 04:52 PM   #12
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,336
Just curoius how you "Shut off the remote"?
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 02-02-2009, 05:12 PM   #13
PauHana OP
PauHana's Avatar
Oddometer: 64
Talked with Garmin today. Unit is on it's way back to them for repair.
Old 02-02-2009, 06:30 PM   #14
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,634
Jamie
Mine used to go wonky too. Found the solution was to tape off the light sensor (for the auto dimming), and also turn off the auto-dimming feature for the screen. Never had a problem again after that.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 02-02-2009, 06:34 PM   #15
Moving Pictures
Sir Loin of Biff
Moving Pictures's Avatar
Oddometer: 8,566
Correction: turn off the remote-sensor option in the main menu on the unit.
People before prophets.
Moving Pictures is offline   Reply With Quote
Times are GMT -7.   It's 02:36 AM.
