Go Back   ADVrider > Riding > Regional forums
Old 07-08-2014, 08:18 AM   #5491
Gathaway
Oddometer: 19
Originally Posted by Yankee Dog View Post
fix a flat... How did it work. I am having nightmares thinking about getting a flat on the rear tire.
Try ride-on. You can put it in before or after the flat. If you put it in before it balances the tire and will seal any puncture you get along the way. I know a guy who put 5, 000 miles on his front after he got a flat and added ride-on. I just put it in my rear when I swapped tires. No balancing and it is as smooth as when the last tire was balanced at the shop, and I don't have to worry about a flat
Gathaway is offline   Reply With Quote
Old 07-08-2014, 09:46 AM   #5492
shallowskiff
shallowskiff's Avatar
Oddometer: 489
Originally Posted by gathaway View Post
try ride-on. You can put it in before or after the flat. If you put it in before it balances the tire and will seal any puncture you get along the way. I know a guy who put 5, 000 miles on his front after he got a flat and added ride-on. I just put it in my rear when i swapped tires. No balancing and it is as smooth as when the last tire was balanced at the shop, and i don't have to worry about a flat
1++
shallowskiff is online now   Reply With Quote
Old 07-09-2014, 09:12 AM   #5493
ajayhawkfan
Rock Chalk
ajayhawkfan's Avatar
Oddometer: 4,541
Sooner or later you will get a flat that can't be fixed with fix-a-flat or Ride-On.
You might consider carrying spare tubes (front tube can be put in the rear of you only want to carry one) and 2 or 3 spoons. I also carry a tire patch kit and some liquid soap as well as radial patches in case I have to repair a tubeless tire if a plug does not work. The soap is added to water to make the rims a little slicker and helps get the tire on and off the wheel. The soapy water can also help find a hole in a tube.
You should make sure you carry the tools needed to remove the wheels from the bike (otherwise you will have to patch the tube while still on the bike). The tool kits that came on my wife's GS650 (tubed tires) and my GS1200A (tubeless tires) did not have all the tools needed.
Consider removing your tires at home, breaking the bead and spooning the tire off and then back on. Learning at home sure beats learning on the road in the middle of no where.
"Wilderness is not a luxury, but a necessity of the human spirit" Mark Twain
Texas Hill Country Badlands and Black Hills Riding the T.W.A.T Photos
ajayhawkfan is offline   Reply With Quote
Old 07-09-2014, 10:16 AM   #5494
JGNC
JGNC's Avatar
Oddometer: 395
It's really easy to change motorcycle tires once you do it once or twice.
Another tip, only use the tools you keep on the bike when doing any repairs or maintenance at home. This way you will learn what you need to keep on your bike for whatever issue you run into in the road.
-Jesse
JGNC is offline   Reply With Quote
Old 07-09-2014, 10:22 AM   #5495
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 14,049
Al Tuna is online now   Reply With Quote
Old 07-09-2014, 11:14 AM   #5496
wb57
wb57's Avatar
Oddometer: 6,905
Originally Posted by Al Tuna View Post
+1
Well, plus 4.5 for the C14...
'10 Kawasaki Concours (EB)
'11 Kawasaki Versys
Turning money into spent fossil fuels.
(Smiley crap is implied in all posts.)
wb57 is offline   Reply With Quote
Old 07-09-2014, 01:01 PM   #5497
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,999
I have changed tires at home which is exactly why i really dread trying to change one on the field. Especially the rear tire.
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 07-09-2014, 04:17 PM   #5498
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 2,872
Then you can come do my next set. I have a fridge with beer.
Good theory.
I guess I oughta try not to bump into the tire changing machine when doing this on the floor, right?
Super Tenere & WR250R, AMA, IBA
Wreckchecker is offline   Reply With Quote
Old 07-09-2014, 05:16 PM   #5499
JGNC
JGNC's Avatar
Oddometer: 395
Good theory.
What's a tire changing machine? lol
-Jesse
Old 07-09-2014, 05:24 PM   #5500
yru
After 6, it's iffy
yru's Avatar
Oddometer: 3,156
This was me and my friend Chris in the middle of WTFAW (where the fuck are we) Massachusetts, on the way to Nova Scotia and beyond. Sunday morning with a flat. Great guy at a BJ's helped us out. Then I rode to a Harley dealer about 40 miles away that was open on a Sunday who had the BMW inner tube. Really saved our asses.
BJ's was a God send!
Lesson learned, take anything that can repair a flat with you (fix a flat etc and a tire pump) and then take it to a place that repairs motorcycle tires (hopefully near-by). I say FUCK trying to repair it yourself (unless you are Superman with very long levers!).
yru is online now   Reply With Quote
Old 07-09-2014, 05:27 PM   #5501
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 14,049
Old 07-09-2014, 05:45 PM   #5502
JGNC
JGNC's Avatar
Oddometer: 395
Like other things in life it's all about proper technique and a lot of lubricant. I have the Motion Pro Enduro levers (like 10-12" long) plus a third slightly larger spoon for sport bike tires. You could leave the larger one at home if space is more important than saving a few minutes in case of a flat.
I've broken beads with only tire spoons before. It took over half an hour of profanity per tire though. Also once used another bikes side stand to break the bead.
-Jesse
JGNC screwed with this post 07-09-2014 at 05:50 PM
Old 07-09-2014, 05:58 PM   #5503
yru
After 6, it's iffy
yru's Avatar
Oddometer: 3,156
If you believe this then you will believe anything. It TOTALLY depends on the tire. Not some general fix for ever bike and tire combination out there. It really helps not to listen to retards with quick fixes to complicated problems.
Old 07-09-2014, 06:24 PM   #5504
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,999
Originally Posted by yrunotriding View Post
.................Lesson learned, take anything that can repair a flat with you (fix a flat etc and a tire pump) and then take it to a place that repairs motorcycle tires (hopefully near-by). I say FUCK trying to repair it yourself (unless you are Superman with very long levers!).
+37
I like my 800xc. But I think I would like a regular 800 with cast wheels and tubeless tires even better.
2005 Ural
2005 BMW F650GS
Old 07-09-2014, 07:14 PM   #5505
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 14,049
Always on the bike, air compressor, tire tools, one long and two short, patches and plugs and a can of Slime. Main thing I try to do, is keep good tires and watch were I pull over.
Edit: always carry both tubes on the spoke bike.
Times are GMT -7.   It's 12:49 PM.
