Go Back   ADVrider > Riding > Mapping & Navigation
Old 02-02-2009, 06:41 PM   #1
Countdown OP
Oddometer: 5,921
60Cx with 8 gig card?
My friend put an 8 gig card in his 60Cx and I tried to download about 0.1 gig of R&R & topo. Message on Mapsource says "GPS does not support Map Download"?
I reset card power on/off several times, same problem.
Tacks & Waypoints download fine.
Any one have an idea what I am doing wrong?
Jerry Counts
Countdown is offline   Reply With Quote
Old 02-02-2009, 09:16 PM   #2
Timmer
Timmer's Avatar
Oddometer: 2,401
I tried the same thing and then had several long email exchanges with Garmin tech support and was essentially told that I have to use the TOPO chip that I bought even though I would be writing track files to the factory SD card which I didn't want to do.
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 02-02-2009, 09:38 PM   #3
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,774
Wow, never heard of anyone using an 8 gig card in one, for a long time it was 2 gig max, but I think 4 is now OK with firmware update.
Why so big?
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 02-02-2009, 10:13 PM   #4
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 8,006
Given the prices of these things, why not I supppose? A couple of extra bucks is chicken feed really.
BTW Tbird, do you know which version of firmware supports the 4 gig card? I've asked the question on here a couple of times but the original posters just seem to fade away. I could definitely make full use of a 4g card if it will work.
GodSilla is offline   Reply With Quote
Old 02-02-2009, 11:24 PM   #5
Countdown OP
Oddometer: 5,921
I had no problem downloading R&R plus Topo with a 2 gig card in my 76Cx.
When I go to USB Interface, I can't see the memory. I don't think the extra 2 address lines would make a difference perhaps it is a bad memory.
Jerry Counts
Old 02-03-2009, 02:28 AM   #6
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
I've heard of a few people using 4GB cards okay
Not really a lot of point having a card above 2GB as this is the maximum size of map file you can load
BurnieM is offline   Reply With Quote
Old 02-03-2009, 03:03 AM   #7
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,501
2 was tops for a long while. Hadn't heard of a bump up to 4, but could be. Never heard of anyone successfully using and 8.
dunno.....
Old 02-03-2009, 05:37 AM   #8
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,774
Nope, just read it here like you I'm kinda behind on firmware updates anyway. I can't see needing more than 2 gig for my riding.
Mike S.
AMA MSTA
Old 02-03-2009, 07:36 AM   #9
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,356
You can find a few non SDHC 4 gig cards, as the 60CX/76cx may not except "SDHC" SD cards. But anything bigger and most 4 gigs are now SDHC so look at your card and see if it has the "SDHC" logo on it. The 8 gig would be for sure.
Transend makes a Non SDHC 4 gig.
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE
Robert
rwamf homepage
rwamf is offline   Reply With Quote
Old 02-03-2009, 09:02 AM   #10
Countdown OP
Oddometer: 5,921
Thanks Robert, it is an "HC", that probably is the problem. I will tell the owner to get a 2 gig non-HC card!
Jerry Counts
Old 02-03-2009, 05:53 PM   #11
BryceB
It's OK we know the Mayor
BryceB's Avatar
Oddometer: 358
I'm using a Kingston Micro SD HC 4GB card in mine... no issues. I'm on whatever firmware that the webupdater pulled about 3 or 4 weeks go.
'14 Super Ténéré - Team Yamaha Blue & '08 KLR650 - Blue 21
BryceB is offline   Reply With Quote
Old 02-03-2009, 07:04 PM   #12
Countdown OP
Oddometer: 5,921
The guy got a 2 gig non-HC card at lunch and it worked fine. Still don't know for sure that it wasn't a bad card although it was a Sandisk.
Jerry Counts
Old 02-04-2009, 01:53 AM   #13
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
Que?
HC = High capacity
All cards over 2GB are HC
Nothing to do with the speed or other factors
Old 02-04-2009, 06:48 AM   #14
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,356
Originally Posted by BurnieM
Que?
HC = High capacity
Not true there are a few 4 gigs that are not SDHC, I have a couple Transcend ones. They are getting harder to find
Secure Digital Cards have been around for nearly 10 years, SDHC Cards are a newer version developed for use with digital cameras and other such devices that not only a require a higher capacity card, but also one that comes with a performance to match. SDHC cards are designed for devices that are compatible with the SD 2.00 specification. Products designed exclusively to support previous SD specifications 1.0 and 1.1 will not be able to utilize SDHC cards. To check if your device is compatible with SDHC look in your device manual or on the packaging for the SDHC symbol
Remember, if your device accepts SDHC cards, it is backwards compatible with standard Secure Digital (SD) cards.
The growing demand for high-capacity flash memory springs partially from the increasing use of high-definition video and high-resolution digital photography. SDHC cards meet the challenge of these demanding products not only by providing ample storage but also by introducing a new feature - Classification of Data Transfer Speed (DTS).
Consumers can get the best performance value out of their digital products by using flash memory cards that support the device's highest standards for data transfer speed. The SD specification 2.00 calls for cards to be classified according to the minimal sustained DTS as follows:
* Class 2: minimum sustained DTS of 2MB/sec (13x Speed)
* Class 4: minimum sustained DTS of 4MB/sec (26x Speed)
* Class 6: minimum sustained DTS of 6MB/sec (40x Speed)
The issue with regular SD memory cards and other cards for that matter, is that if the card has a write speed of say 6MB/Sec or 40x Speed, then it's maximum speed is that. So the device (eg. camera) will start writing the image or data to the card at 0MB/sec and then work up to the top operating speed of 6MB/sec and then slow down again to 0MB/sec as it finishes wrting the data, thus meaning the average write speed may be around 3MB/Sec.
Therefore ther SDHC format, which has a guaranteed minimum write speed of say 6MB/Sec (40x Speed) will start at this speed and may in fact have a higher top speed - like the SanDisk Extreme III Secure Digital Card - SDHC 4gb Memory Card, this is a Class 6 card -therefore having a minimum sustained write speed of 6MB/Sec - 40x Speed, but has a top speed of 20MB/Sec - 133x Speed.
In simple terms this means SDHC cards start writing data a specified speed and sustain that speed, whereas regular SD Cards start writing data at 0MB/Sec and build up to a top speed; SDHC memory cards start writing the data at a higher minimum speed.
There, I hope that helps clarify things a bit.
Robert
rwamf homepage
rwamf screwed with this post 02-04-2009 at 09:25 AM
Times are GMT -7.   It's 01:07 AM.
