Old 02-03-2009, 09:28 AM   #1
huggybear OP
huggybear's Avatar
Oddometer: 384
Garmin Tracks- Magellan Meridan
Is there a way to load Garmin tracks to My Magellan Meridan?
huggybear is offline   Reply With Quote
Old 02-03-2009, 10:46 AM   #2
EmmEff
Oddometer: 1,718
Don't know anything about Magellan but chances are probable that GPSBabel will convert from Garmin to your GPS' native format.
Edit: I sorted assumed this unit was capable of loading tracks. If not, then no possible way.
2001 F650GS Dakar
2008 DR-Z 400S
EmmEff screwed with this post 02-03-2009 at 11:03 AM
EmmEff is offline   Reply With Quote
Old 02-03-2009, 10:53 AM   #3
Countdown
Oddometer: 5,345
A friend had one and I don't think it will accept tracks. It never worked long enough for him to even record tracks.
Jerry Counts
Countdown is offline   Reply With Quote
Old 02-03-2009, 03:49 PM   #4
huggybear OP
huggybear's Avatar
Oddometer: 384
Thanks Guy's I have had this for about six-seven yrs and it has been thru lots of crashes in the woods and still works fine,I also have a ZUMO for the street bikes but I don't think it will hold up to the abuse the Magellan will ,the Zumo is easy to load tracks in ,I was hoping the Magellan would too,if not I will just buy another ZUMO as the prices are coming down
Old 02-03-2009, 06:26 PM   #5
Countdown
Oddometer: 5,345
Very long thread on Zumo & tracks:
http://www.advrider.com/forums/showt...ht=Zumo+Tracks
Does your Zumo really show tracks or do you convert them to Routes before you can use them?
Jerry Counts
Old 02-03-2009, 10:30 PM   #6
Jamie Z
Jamie Z's Avatar
Oddometer: 7,695
The Meridian is a great GPS. I had a couple of them through the years and they are tanks. The Meridian set the standard in satellite reception, too.
It's getting a bit long in the tooth, and I rarely played with any tracks when I owned mine, so I don't recall its capabilities, but as mentioned above, GPSBabel (or Google GPSVisualizer) will convert your Garmin tracks to something the Magellan can understand.
I'm pretty sure you can load and save tracks on the SD card in the Meridian. It's a feature Garmin didn't have until several years later.
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is offline   Reply With Quote
Times are GMT -7.   It's 01:05 AM.
