Old 02-15-2010, 01:05 AM   #391
DRjoe OP
DRjoe's Avatar
Oddometer: 5,096
Originally Posted by Pezz_gs
Looks great Joe
Maybe convert the rear shock to a remote reservoir?? I have seen it done on a WP Rear shock.
Then the inlet tract will be straighter for both carbies.
That and moving the shock body to the left a bit would be the best idea but I have already repositioned the reservoir once already so I don't want to mess with it again well not just know at least.
I think I'll make a small air box using all the space available that then connects to the main filter box
Old 02-15-2010, 06:03 AM   #392
DRjoe OP
DRjoe's Avatar
Oddometer: 5,096
I spent another few hours playing with the frame tonight and i managed to get the engine positioned pretty much in its final resting place.
I tacked the frame together just to check for front wheel clearance and see if I could remove the rocker cover and the engine.
The good news is there's 5mm of clearance between the frame and the tire when the forks are compressed and its very easy to remove the engine.
The right side of the gs frame unbolts so all you have to do is jack the engine up with a trolley jack, remove the right side frame and then you can just roll the engine out of frame.
The bad news is the only way to get the valve cover off is to pull the engine mount bolts out and let the engine drop enough to get clearance above the rocker cover.
here are a few pics
Low rider dr
enough clearance for you lukas
Old 02-15-2010, 06:09 AM   #393
Wolfdog
Not Scared
Wolfdog's Avatar
Oddometer: 83
I must say, this has been one of the most entertaining threads of late, Im late to the party, just checked it out from start to current progress 2 days ago.
DRJoe goes place's most fear to tread, good on ya Bloke!! its great to see that Not Scared atitude.
I admire your persistance, many would have put it in the bin already but just when you seem beat, you pull another rabbit out of the hat, its great.
Hope you have plenty more rabbits in your hat, On with the hybrid.
Wolfdog is offline   Reply With Quote
Old 02-15-2010, 06:15 AM   #394
LukasM
Oddometer: 5,415
Should be good to go, although those spindly fork legs might just flex enough so it hits when you brake and drive over a bump at the same time. Might I recommend some beefy WP 48mm USD forks? I hear the fit quite well on the DR!
Here is what you made me do yesterday (working on the update now):
Old 02-15-2010, 06:23 AM   #395
DRjoe OP
DRjoe's Avatar
Oddometer: 5,096
Thanks mate
One of the reasons I haven't binned it is because of all the kinds words of encouragement I get from people on this thread.
I'm gonna need as much encouragement as i can get because i have entered my first ever race which i have to be at (15 hours riding away) by the 2nd of April for scrutineering. http://www.condo750.com.au/index.html
I have already been excepted to race so i have to finish the bike in time.
not long to go.
Old 02-15-2010, 06:24 AM   #396
DRjoe OP
DRjoe's Avatar
Oddometer: 5,096
Good on ya Lukas I told you the grinder was your friend.
Old 02-15-2010, 06:27 AM   #397
Wolfdog
Not Scared
Wolfdog's Avatar
Oddometer: 83
Wow!! looks like DRJoe has infected others with the desire to graft forigen donks into the DR frame.
What are you putting in it Lukas, is that a 690 engine ?
Old 02-15-2010, 06:38 AM   #398
DRjoe OP
DRjoe's Avatar
Oddometer: 5,096
Ah it was Lukas that inspired me. He is putting a kwaka fuel injected er6 motor in a ktm 640adv frame.
His is going to be way more powerful and a better handling bike than mine but when one of his injectors cacks it in the middle of butfucknowhere he'll be wishing he had the gs donk.
more detail here
http://www.advrider.com/forums/showthread.php?t=456542
Old 02-15-2010, 06:43 AM   #399
LukasM
Oddometer: 5,415
Unfortunately it isn't. I was using my friends real pride & joy, a $500 FEIN tools grinder. Somehow the disc got stuck while cutting and the thing proceeded to lock up the gearbox and crack in two piece while in my hand. Let's just say he is not exactly thrilled with me, and my wallet hopes that they will replace it under warranty.
Luckily I have a chop saw that made quick work of the rest:
What Joe said!
Old 02-15-2010, 06:47 AM   #400
LukasM
Oddometer: 5,415
Is anybody else having trouble seeing my pics? Looks like Photobucket is acting up....
Old 02-15-2010, 06:56 AM   #401
DRjoe OP
DRjoe's Avatar
Oddometer: 5,096
I can see them.
Un lucky with the grinder you should stick with makita.
I've killed a fair few grinders in the past but i have never had a gear box split in two oh apart from when one i was using got crushed by a ten ton pontoon (dam clumsy crane drivers)
Old 02-15-2010, 01:41 PM   #402
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
Cool, this thread is still delivering! Good work Joe. I'm anxious to see the final product.
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 02-16-2010, 12:29 AM   #403
cooneyr
terra firma rider
cooneyr's Avatar
Oddometer: 520
Just read the thread from scratch after Lukas posted a link from his thread. Very cool project Joe. GS twin motor in a DR is cool enough without all the other mods to the what was DR frame!
Watching with interest!
P.S. Nordie when you going to do it (GS500) in your spare frame
"The ultimate result of shielding men from the effects of folly is to fill the world with fools." - Herbert Spencer, English Philosopher (1820-1903)
05 KTM 450 EXC
cooneyr is offline   Reply With Quote
Old 02-16-2010, 01:38 AM   #404
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Wouldn't mind a twin but mine'll be a DR400F.
With the Corbin/IMS etc that'll be the long distance/adventure bike and the 650 will end up with the skinnier seat/tank and more off-roady.
I could just put the Nordie's 558cc donk in the spare frame
DR600G.
NordieBoy is online now   Reply With Quote
Old 02-16-2010, 10:35 PM   #405
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
DR600G.
Hey Nordie
Im building an XR460Four - http://www.advrider.com/forums/showthread.php?t=497905
Were you thinking of a GSXR400
Apologies for the Hi-jack Joe
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Times are GMT -7.   It's 09:50 PM.
