Old 02-27-2010, 08:42 PM   #466
Travmoto
almost there...
Travmoto's Avatar
Oddometer: 221
Joe just leave one spark plug out during the build...... does that technically make it a thumper?
Travmoto is offline   Reply With Quote
Old 02-27-2010, 09:30 PM   #467
DRjoe OP
DRjoe's Avatar
Oddometer: 5,064
I wouldn't think any of the mods check in here very often so if we all keep quite about the extra cylinder they'll never find out and i can carry on playing in the thumper sandpit.
Old 02-28-2010, 01:03 AM   #468
dirt_bloke
No idea
dirt_bloke's Avatar
Oddometer: 899
Originally Posted by Gustavo.Ramos
Looking very nice! Its there any way to smooth those welds on the inner area of the pipes?
Don't know if i had the patience to do so many welds... but then again...
Keep up!
A bit late now, but to make the welds smooth on the inside while you use the Tig. You must 'purge' the inside of the pipe with Argon.
Method: Tape both ends of the pipe. Insert gas line on one end (place a 'Tee' in you gas hose) the other end, prick the tape. This will let the air escape, and fill the space with Argon.
After a few practise runs, you'll work it out.
If you go chasing performance, this is important.
Before you hot up this motor, buy 'Four-Stroke Performance Tuning' by A. Graham Bell. I found this book more releavent that 'Tuning for Speed' by Phil Irving (but still a bloody good read).
While reading this, many weird 'why is it so' things will become apparent!
I've often thought that
_________________________________________
Not a Member of the......Quorn Schnitzel Club
(yet)
dirt_bloke is offline   Reply With Quote
Old 02-28-2010, 02:28 AM   #469
DRjoe OP
DRjoe's Avatar
Oddometer: 5,064
Thanks for the purging tip i'll do that next time.
The guy at the exhaust shop mentioned it once but i didn't have a clue what he was going on about but it all make sense now you've mentioned it
Hey Mezo I tried your dads exhaust program and it turns out my header are the correct length and diameter for 7000rpm but the exhaust ports are way to small and would be more suited to about 4000rpm
also the inlet tracks are the perfect length to match my headers but are about 100mm to short for the the exhaust port diameter.
I was surprised at the difference of the length that the inlet tracks should be when you change the chosen rpm by just a few thousand.
Old 02-28-2010, 03:48 AM   #470
dirt_bloke
No idea
dirt_bloke's Avatar
Oddometer: 899
No worries
the exhaust ports are way to small and would be more suited to about 4000rpm.
See tip B before you attack the ports with the die grinder.
(yet)
Old 02-28-2010, 05:47 AM   #471
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 888
I like this kind of reading!
One more for the weird book list noone would ever find to offer me unless i specifically indicate all the details! Tkz
690R
Old 02-28-2010, 05:59 PM   #472
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
That is some excellent work Joe! Good to see you sticking to it. :) Can't wait to see it finished.
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 02-28-2010, 08:56 PM   #473
DRjoe OP
DRjoe's Avatar
Oddometer: 5,064
No worries
I wont be taking a grinder to the ports for awhile yet so i'll have plenty of time to read that book.
thanks again for the tip
Old 03-01-2010, 06:16 AM   #474
NOSIGN
NOSIGN's Avatar
Oddometer: 95
nice pipe man!
NOSIGN
DR650SE ('97) current project
CBR954 ('03) daily ride
CBR900 ('96) the 'ol days
CR250 ('03), 125 ('89), 80 ('85) the 'ol days
KX80 ('92) the 'ol days
NOSIGN is offline   Reply With Quote
Old 03-01-2010, 03:28 PM   #475
Ron Seida
Adventman
Ron Seida's Avatar
Oddometer: 1,256
Wow! I{m impressed! Nice job Joe! Looking foreward to the first ride.
"¿Qué sería de la vida si no tuviéramos el valor de intentar algo nuevo?"
Van Gogh...
"Your the only guy i've met driving a BMW who isn't an asshole."
D. Irwin...
Ron Seida is offline   Reply With Quote
Old 03-01-2010, 05:15 PM   #476
DRjoe OP
DRjoe's Avatar
Oddometer: 5,064
look what arrived today
there quite heavy so i started a bit of weight saving by cutting out the cat.
pretty aren't they
weight with the cat
without the cat
and the cat itself
with my highly accurate scales i reckon once I've drilled a few holes in the baffles for weight saving purposes and then welded them back up they'll come in at just over 3kg each
Old 03-01-2010, 05:22 PM   #477
Travmoto
almost there...
Travmoto's Avatar
Oddometer: 221
lol I'm picturing now the puzzled looks on peoples faces when you ride past, KTM bits, Suzuki bits and god knows what else... this things going to be a hoot when its finished.
Keep up the good work mate, and don't let the rain slow you down, we all need these updates
Old 03-01-2010, 05:45 PM   #478
DRjoe OP
DRjoe's Avatar
Oddometer: 5,064
It'll definitely going to be a laugh when i first get pulled over by a cop.
I'm hoping it will go something like this.
Pc plod: "alow alow alow whats all this then"
Me: "it's a bike officer"
Pc plod: "and what kind of bike would it be sonny"
Me: "well officer I started with a dr650 which then blew up so i put a gs500 motor in it which meant i had to change a few bits so i suppose its a dr500t"
Pc plod: "ah maybe you should just go"
Me: "ok" barp baarp baaaarp baaaaaaaaaarp baaaaaaaaaaaaaaaaaaaaaaaaarp baaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
The rain is speeding things up. I took a week of work to finish the bike and i keep getting calls from people wanting work done on there boats and now its raining i can say no without loosing out.
So it's full steam ahead with the bike now well that's if i can get off the dam computer.
Old 03-01-2010, 06:28 PM   #479
Travmoto
almost there...
Travmoto's Avatar
Oddometer: 221
Old 03-02-2010, 06:29 AM   #480
DRjoe OP
DRjoe's Avatar
Oddometer: 5,064
got a bit more done today.
first off i finished the mufflers after cutting the cats out i sat stared at the baffles for a while.
I Have grow to prefer quieter pipes but for some reason i just couldn't stop myself from doing this.
oops a might have drilled strieght through the baffle
I cut the end off the cat and welded it back on
Since i bought my tig welder last year i've only really done alloy with it so the exhaust headers and the mufflers are the only stainless work i have done. It turns out stainless is a crap load easier to weld than alloy.
Times are GMT -7.   It's 11:56 AM.
