Old 05-29-2011, 03:43 AM   #586
emil55
sponsors needed...
emil55's Avatar
Oddometer: 82
Found a pic of Glen's:
I could give mine a measure and let you know dimensions if you like.
RE water crossings - have submarined mine with the same setup and it predictably stopped. Talking a very wet sploosh, not a retrieve-bike-with-scuba. No lasting ill effects - just drained half a cup of water from the airbox drain and hit the button.
Strength, courage, determination & brute stupidity!
emil55 is offline   Reply With Quote
Old 05-29-2011, 03:46 AM   #587
DRjoe OP
DRjoe's Avatar
Oddometer: 5,151
Originally Posted by tmotten View Post
Sounds to me that you're copying the new Berg system. Just have a look at what's under the seat there. I liked it, not sure about water crossings though.
I thought the new bergs had there air filters where the tank normally goes a bit like the photo above of Glens.
Water crossings shouldn't be a problem as the intake would be as high or higher than most dirt bikes
Old 05-29-2011, 04:04 AM   #588
DRjoe OP
DRjoe's Avatar
Oddometer: 5,151
Thanks mate it would be handy if you could measure it when you get a chance, is it foam or paper?
From the photos it looks like it is quiet round a stocky instead of long and thin.
I want the air box to run along the top of the rear tank/subframe with the tank forming the bottom of the air box with the filter and then the seat will be the top of the air box and snorkel.
It hard to describe how I'm thinking of building the bike.
Old 06-03-2011, 02:25 AM   #589
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,303
How did you go Joe.
Unifilter sell foam sheets to make you own.
http://www.unifilter.com/online%20catalog/UNICAT07.pdf
page 11
Nice pics from boot camp
WILL_S is offline   Reply With Quote
Old 06-03-2011, 02:41 AM   #590
DRjoe OP
DRjoe's Avatar
Oddometer: 5,151
That's a good idea Will
Sorry I haven't finished your swing arm, I'm painting a jet ski in the garage so I can do any steel work at the moment.
I was suposed to have the ski done last week but i stuffed up and had to start again so its still taking up valuable garage space.
That was a good little ride Phil put on not to easy but not to hard.
Old 06-03-2011, 04:59 AM   #591
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,106
Hey Joe the 70 degree Bergs may have what you are after with filter and airbox able to be modded to suit your needs.
http://www.cyclebuy.com/husaberg/hus...2010_FE390.pdf
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-04-2011, 07:27 AM   #592
emil55
sponsors needed...
emil55's Avatar
Oddometer: 82
Yeah it's not particularly thin... foam though. I use the twin things with two layers. Rough dimensions are 215L x 170W x 70H. Hope that helps.
Old 06-06-2011, 04:09 AM   #593
DRjoe OP
DRjoe's Avatar
Oddometer: 5,151
cheers fellas.
I have few designs and idea's stored away for the airbox and filter now
The photos of the berg have given me more ideas for the frame.
I'm trying to design the frame round the engine, carbs, airbox and suspension and its harder than you might think to get everything to fit and work well without making compromises.
I've ruled out a single back bone frame like I was using because I have to make to many compromises and I cant use a lattice frame like the 690 because it will be to wide where it goes round the cylinder head so I was planing a cross between the two.
Now I'm thinking I could do frame like the berg but make it a little deeper and out of lattice instead.
Any ideas and suggestions you guys have are welcome
Need to get all my components together and mounted on a beam in there correct place first and the hopefully the frame will be easy to work out.
easy i tel ya easy
Old 07-28-2011, 03:21 AM   #594
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,030
so whats happening Joe
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 07-28-2011, 03:36 AM   #595
DRjoe OP
DRjoe's Avatar
Oddometer: 5,151
just a few bits to add and it finished
Uh there has been one step forward but many many steps back.
Not a lot of dr650 left
But moving the engine into the living room is providing plenty of inspiration
Need to buy a rear shock before I start the frame, Just waiting for my funds to catch up to my plans.
Old 07-28-2011, 07:06 AM   #596
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,606
Lefthand brew, a weber grill and the rocky mountains,...it all goes away!
Utah Bones is offline   Reply With Quote
Old 02-09-2012, 10:24 PM   #597
Faux Real
Oddometer: 8
I can't believe I just read this whole thread. Sitting on the train gives a fella some free time. You have done some great work on this project, I am afraid I would have binned after the 2nd blowup.
If you are looking for frame ideas check out the eurospares site. Micheal Moore has thousands of frame pictures both road racing and offroad. It is mostly vintage racing stuff, but some of that was pretty stiff and light. BTW he is a GS500 guy too. His email list on frame design was very good too. (It still may good, I have not been there for many years.)
http://www.eurospares.com/
Faux Real is offline   Reply With Quote
Old 02-10-2012, 01:38 AM   #598
DRjoe OP
DRjoe's Avatar
Oddometer: 5,151
Thanks for your coments mate.
Ive been lurking on that mailing list for a few months now and it's a great source of info.
I've bought a few bike design books as well so I've been busy learning.
Its books before grinder with this new frame.
I'm looking for a new shed and once I'm all set up I'll be building a jig and starting on the frame.
Thanks again
Joe
Old 02-10-2012, 03:40 AM   #599
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,848
2018 then Joe
White pig
b0mb3r is offline   Reply With Quote
Old 02-10-2012, 01:26 PM   #600
DRjoe OP
DRjoe's Avatar
Oddometer: 5,151
Originally Posted by b0mb3r View Post
2018 then Joe
That'll be just in time for your next ride.
Times are GMT -7.   It's 08:33 AM.
