Old 02-04-2009, 09:00 PM   #1
sixer OP
I suffer from Ainrofilac
Oddometer: 1,220
The XR250R Thread...
I searched but didn't find a dedicated thread for the lovely XR250R. No year limitation. I just picked up a nice clean 2003 XR250R. So far I'm really excited about it. It is the prefect bike for a n00b like myself. My plan is for this thread to be a place to chit-chat, drool, and index cool stuff about/for our little 250's. Thanks in advance!
My plans for mods:
1) Cyrca handguards
2) Whipps bashplate
3) Clarke 3.8gal tank
Future mods:
1) Change the rear tail light
2) Nice little rack
3) Quiet her down
4) Raise the bars/new bars
5) Suspension set-up/stiffer springs
6) ???
"There are no such things as accidents—just two people competing for the same point on the space-time continuum."
Support your local Search and Rescue Teams.
sixer screwed with this post 02-10-2009 at 02:54 PM
sixer is offline   Reply With Quote
Old 02-05-2009, 09:46 PM   #2
sixer OP
Oddometer: 1,220
Ok I'll be the first one to ask a oil related question. To do a oil change w/filter change, I've read anywhere from 1.5L to 2.0L to refill. Also to drain the oil do you just remove the frame bolt or is there a bolt under the engine too?
Old 02-06-2009, 01:04 AM   #3
valvecrusher
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,749
valvecrusher is offline   Reply With Quote
Old 02-06-2009, 05:56 AM   #4
XRsteve
Oddometer: 254
There's an engine drain plug too. You need to drain them both. The oil capacity (with a filter change) is 1.5 quarts.
XRsteve is offline   Reply With Quote
Old 02-06-2009, 06:45 AM   #5
sixer OP
Oddometer: 1,220
Thanks. I need to get a service manual.
Old 02-09-2009, 09:24 PM   #6
sixer OP
Oddometer: 1,220
So oil/filter changed, air filter cleaned, and I'm all ready to ride the local trails....its snowing.
I'm still getting used to the starting procedure on this bike. I just got to remember to put the switch on the right setting. Spent 15 minutes kicking it over on the "kill" setting.
Old 02-09-2009, 09:50 PM   #7
XRsteve
Oddometer: 254
The procedure in the owner's manual says to hold the compression release lever and kick it over several times when cold. I've found that the 250s are harder to start cold than a lot of other bikes. And it helps a lot if you turn off the gas and let the carb run dry when putting it away. The only other advice I have for starting it is to kick hard. I don't bother using the compression release and finding top dead center.
Old 02-09-2009, 10:42 PM   #8
sonic reducer
Oddometer: 256
just for clarity, what are the differences between the '95 and lower, and '96+ bikes?
sonic reducer is offline   Reply With Quote
Old 02-10-2009, 08:57 AM   #9
sixer OP
Oddometer: 1,220
Thanks for the advice, pretty much what I've been doing. I miss how easy my DRZ400K was to kickstart.
Old 02-10-2009, 09:10 AM   #10
cedric
Oddometer: 217
I'm no expert on this material, but I'm pretty sure that almost every part changed from 95 to 96. It was a full redesign of the bike. Having said that, the overall result is quite similar. All of the bodywork is different, the suspension is different, the motor went from wet sump to dry sump oiling and I'm sure a bunch of other details I'm overlooking.
I'd have to think that the newer version handles better and has some more power, but in the grand scheme of things, an XR250 is an XR250 - these bikes have decent performance, are tough as nails and are friendly for beginning off roaders.
cedric is offline   Reply With Quote
Old 02-10-2009, 09:47 AM   #11
yater
yater's Avatar
Oddometer: 8,517
If your jetting is right, kick it 5 or so times with the compression release in, then choke, NO throttle, and kick from TDC. My would fire every time this way. Once warm, it's a one kicker no matter what.
yater is offline   Reply With Quote
Old 02-10-2009, 10:03 AM   #12
valvecrusher
tractus pro pensio™
Oddometer: 1,749
If ya'll ever get into the 84-95 RFVC XRs, XLs... I'll be back to chime in.
I deleted the photos, as per original poster's request to remain 96-04.
9-27-09 *edit* ok, someone said it's ok...
valvecrusher screwed with this post 09-29-2009 at 06:26 PM
Old 02-10-2009, 02:19 PM   #13
sixer OP
Oddometer: 1,220
Thanks, I'll try this next time around. I'm not sure on the jetting. It runs great so I don't really want to fiddle with the carb.
Go for it, post away! This thread needs someone other then myself to be posting in it. I'll edit the first post to include the change.
Old 02-10-2009, 02:23 PM   #14
guesswork
guesswork's Avatar
Oddometer: 265
Mine is a "93"
Guess I can't post here.....
guesswork is offline   Reply With Quote
Old 02-10-2009, 02:56 PM   #15
sixer OP
Oddometer: 1,220
Post away, I changed the first post to reflect this. Seems theres just as many inmates with the earlier XR250's.
Times are GMT -7.   It's 03:05 AM.
