Old 11-16-2011, 02:28 PM   #841
Johnnyboxer
Oddometer: 1,057
So having been away from XR's so long - I have a few questions
a) What are the best handguards and handlebars?
b) Any 'must do' mods?
c) I plan on changing the Oil&Filter every 1000 miles with Semi-Synth 10/40 - is this about right or would you do it sooner?
Any tips are gratefully received
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer screwed with this post 11-16-2011 at 02:40 PM
Johnnyboxer is offline   Reply With Quote
Old 11-16-2011, 02:38 PM   #842
windquest
windquest's Avatar
Oddometer: 574
Any tips are greatfully received
Answers:
a) Highway Dirt Bikes, this is the ultimate hanguard setup, and completely customizable.
b) check that all bearings are good and bushings greased, check valve clearance, make sure your air filter is clean and go ride!
c) your plan looks good, just make sure to check oil level before each ride to make sure you aren't running the bike with low oil.
Trans-Canol 2014ish
windquest is offline   Reply With Quote
Old 11-16-2011, 02:46 PM   #843
Johnnyboxer
Oddometer: 1,057
Originally Posted by windquest View Post
Answers:
I will check out HDB stuff
The exhaust valves were way too loose, when i did some wrenching earlier tonight, all adjusted and in spec now, she runs like a sewing machine - checked everything else before I bought it and felt great, so i'll just start at the front and work backwards
The main issue was the dragging brakes front & rear, the PO had fitted new pads but not serviced the calipers So I purchased some new Honda OEM pads and new seal kits, stripped and cleaned out - plus new fluid (the old looked like it was done at the factory 13 years ago) and took 2 flushes to run clean
I'll keep an eye on the oil, always used to and found they used no oil and hope this new to me XR250R is the same, but with only 4300 miles the motor feels sweet
Old 11-18-2011, 05:15 AM   #844
me06
Oddometer: 18
Here's another photo of mine during a recent ride. Great little bike, seriously!
me06 is offline   Reply With Quote
Old 11-24-2011, 03:05 AM   #845
*nick*
*nick*'s Avatar
Oddometer: 381
urgent. does anyone have an exploded diagram of the handlbar mounted LHS switchgear off the 96-04 XR250R?
i have an Austrlian model which is bettery-less but has headlight (with high/low beam), horn, indicators and tail light.
have bike, will travel.
*nick* is offline   Reply With Quote
Old 11-24-2011, 03:44 PM   #846
*nick*
*nick*'s Avatar
Oddometer: 381
sorted. when rebuilding the switchgear i had a small bracket left over, couldn't figure out where it went but got there in the end. pphheeww.
Old 11-26-2011, 02:29 PM   #847
Johnnyboxer
Oddometer: 1,057
Best Renthal bars for a 98 XR250?
Want some 7/8ths in stock clamps
Old 11-26-2011, 02:46 PM   #848
Olas
the darkness
Olas's Avatar
Oddometer: 4,065
Not Renthal but I love my Pro-Taper SE bars with the Henry/Reed bend.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 12-02-2011, 08:47 PM   #849
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,405
went for a scoot today....
n16ht5 is offline   Reply With Quote
Old 12-02-2011, 08:48 PM   #850
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,405
ditch the 7/8ths. get fattys. I like Henry/Reed bend protapers
Old 12-02-2011, 08:53 PM   #851
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,405
nice bike...
moose handgaurds with buckets cut up and bolted to them are my fav.
must do.... search thumpertalk.com xr250 section. gordons mods
sounds good to oil. i run rotella 15.40w
Old 12-03-2011, 05:18 AM   #852
AC909
Great Job!
AC909's Avatar
Oddometer: 1,233
"went for a scoot today...."
GREAT PICS!
A CT175 & XR250R Do A Few States of the TAT
http://advrider.com/forums/showthread.php?t=827855
A CT175 & DR350 Do a Few More States of the TAT
http://advrider.com/forums/showthread.php?t=1010764
AC909 is offline   Reply With Quote
Old 12-05-2011, 02:45 AM   #853
Johnnyboxer
Oddometer: 1,057
I went out on its maiden ride yesterday and it performed faultlessly, did 100 miles door to door - road and trails and it went great, untill the snow started to fall and it was too cold to ride, luckily no snow really settled
A lovely trail bike
Here's some pics
Old 12-05-2011, 08:06 AM   #854
tortugo
Oddometer: 41
I really love your phots and your front fork...
Could you tell us some more about the front fork change?
Thanks!!!
tortugo.
- Stella Alpina 2007 (Bardonecchia - Italy) -
tortugo is offline   Reply With Quote
Old 12-05-2011, 11:49 AM   #855
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,405
looks nice Johnny... did you do Gordon's mods yet?
here's a thread on my xrl. about the same process as a 250. there's lots of info on thumpertalk. cheapest way to do it is machine down the stock triple and press it into the USD triple. thanks btw
www.thumpertalk.com/forum/showthread.php?t=1014262&highlight=
Times are GMT -7.   It's 12:10 AM.
