05-17-2012, 07:40 AM
#1651 |
Ambivilator
Oddometer: 1,374
Been crashed?
"Live your own life, for you will die your own death" Roman proverb. "practice empathy" bouldergeek "Touratech have nice mounting kits but they want a testicle and half a square yard of scrotum skin for them. They can fuck right off." Frey Bentos |
05-17-2012, 08:41 AM
#1652 | |
luddite
Oddometer: 567
![]() That won't prevent it from becoming a great ride (though maybe not a great looking ride). The turn-in issue will probably go away with new rubber. Some tire profiles are worse than others in combination with front spring rates and inflation pressures, especially as the tire wears. What's on there now? Try a different brand next time. |
05-17-2012, 10:18 AM
#1653 |
Too old to be a nOOb
Oddometer: 1,939
05-17-2012, 11:56 AM
#1654 |
luddite
Oddometer: 567
Good point, forgot that one
(Academic to me, I've never had excessive torque on the head bearings cause noticeable-to-the-point-of-objection influence on the turn in, but I've had tire profile/wear issues that made a night and day difference.) |
05-17-2012, 12:09 PM
#1655 |
Rides slow bike slow
Oddometer: 9,784
Heavy bikes like the VFR have famously under-inflated tires when bought from clueless POs. Rear should be 40-42psi and the front should be 36 or so. EVen a few pounds under and mine starts to handle terribly. New tires, proper inflation and adjusting the sag with the preload adjusters solved all my turn in problems.
You couldn't hear a dump truck driving through a nitro glycerin plant!Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka |
05-17-2012, 01:26 PM
#1656 |
-Devo
Oddometer: 2,923
Well I picked up a 97' last Saturday so it's time to check in. The previous owners, including the seller who is a fellow inmate, took exceptional care of it. It only has 16K on the clock and aside from 2-3 insignificant scratches it is in mint condition with plenty of extras.
I was getting it inspected not too long ago and I mentioned to the shop owner I picked up a vfr. He looks me in the eye and says "A vfr huh? Well that was a big mistake." ![]() After a 150 mile loop I can safely say no fucking way! ![]() It still needs some heli-bars though
06' Wee 99' DR350 |
05-17-2012, 03:10 PM
#1657 | |
PussyWagon™ Chauffer
Oddometer: 3,593
He's right, you know. I'll give you $1500 for it but you have to deliver it to me.
Steve 07 KLX250S w/300 kit, 05 DR650SE, 04 XT225 99 VFR800 w/870 kit, 96 GPz1100 |
05-17-2012, 04:06 PM
#1658 | ||
Oddometer: 332
Yes but appears to be very minor pipe rash and engine cover every so slightly scraped.
And after the first ride around the block....the sound...I don't care if had pink sparkly unicorns painted on it, I'd ride it just to be able to listen to it. My god these things sound good. Quote:
Got to check and see about the RR and see if it's been swapped for an aftermarket unit and then I'll get some tires on order and blow it apart for cleaning and painting. I'll post pics when I get it done. Appreaciate all the info guys!
Current: 2013 Ninja 300 Past: 07 ZX6-R, 90 XT350, 88 KLR650, 09 Ninja 250, 98 VFR, 12 KLR 650 Jeremy Clarkson for President! How hard can it be.... http://www.nationalmssociety.org |
05-17-2012, 06:57 PM
#1659 | |
Oddometer: 136
The corbin saddle, carbon vance and hines, and helibars to boot. When it comes to buying bikes I keep $ at home ready to go at a moments notice. But you did good and your bike should last you for many miles. From my bicycle wrenching days over tightening the head bearings makes the steering notchy. Check to see if the front is squared off.
1987 BMW R80 (SOLD) : ( 1996 Honda elite 80 2000 honda vfr no flames, skulls or cupholders : [ 1995 orange speed triple (SOLD) : { |
05-17-2012, 07:54 PM
#1660 | |
luddite
Oddometer: 567
Cheers, Greg |
05-17-2012, 08:43 PM
#1661 | |
Oddometer: 332
05-18-2012, 08:51 PM
#1662 |
Thread Ninja
Oddometer: 1,257
![]() ![]() Summary a 2011 VFR800Fi in Limited Edition Pearl White, Givi Plxr166 Rapid release pannier brackets Givi FZ166 MonoKey topbox bracket Givi V35 Panniers, closer fittign and more aerodynamic. Givi V46 Topbox givi v46 top box brake light Givi Topbox rack Powerlet Bulkhead power socket in topbox. Givi Touring Spoiler Screen, Ignigtor Alarm Pazzoish levers Real Carbon Fibre tripple tree cover Ram mount double of clutch bracket, with Spot Commect gps, Garmin GPS, and camera mount, Ottor Box as well Powerlet headStem Powersocket. Oxford Sports Heated Grips Stain Tunes and Sandy Decat Headers K&N High Flow Air filter Oggy Not Cut Crash Knobs White Power Commander 5 with the exception of suspention mods, which i didnt expect to need, i think its all done. Storm Shadow screwed with this post 05-18-2012 at 09:02 PM |
05-19-2012, 06:17 AM
#1663 | |
Oddometer: 38
I picked it up with 36,000 miles, Corbin seat, D&D slip-on pipe plus original, Lindemann Engineering front suspension, Givi wingrack/top rack and two side cases (I usually ride with one as a top box on my commute), "coated" exhaust, new tires (still with the nubs on them), Zero Gravity screen (plus original), new fluids everywhere. I upgraded the R/R with one from a 98 after some charging issues and added the VFRness wiring harness from Wiremybike.com, plus a new battery. I added a blue sea fuse block under the seat and will add a Signal Dynamics voltage monitor this weekend and powerlet. Fun with older bikes! |
05-19-2012, 10:46 PM
#1664 |
Moto Dragon
Oddometer: 54
Probably going to buy a '99 VFR this week. It has 39k miles on it, recently had valve check without need for any adjustments, and has been kept in near perfect condition. He is asking $3250 for it. Sound like a good deal? I am beyond excited about the bike, I hope it doesn't get sold while I wait to get the money from a friend who is buying my SVS.
05-20-2012, 07:22 AM
#1665 | |
Oddometer: 38
I bought the '95 mentioned above for $2,800 with lots of extras in Va Beach. It was above KBB, but the extras were significant. It may be a bit on the high side, but if you like it, who cares. I'd look at the consumables (tires, last fluid changes, etc.) and see how much more you have to put into it in the next few months vs just riding it. Good luck with the purchase! |
