Old 10-30-2012, 01:27 PM   #1966
Mazaev
Mazaev's Avatar
Oddometer: 218
Cool2
Mine made a sketchy friend...
Mazaev is offline   Reply With Quote
Old 11-04-2012, 11:39 AM   #1967
AllBlackPearl
Alpoholic
AllBlackPearl's Avatar
Oddometer: 749
After last weeks snow and temperatures below -5°C (during the day...) I thought the riding season over. But yesterday brought us another beautiful autumn day, so I went for a quick ride to Chamonix-Mont Blanc.
It was wonderful.
A bit chilly on the higher passes, but I was still riding in my leathers without extra jacket and summer gloves. Not at al bad for November in the Alps!
Hope there will be some more possibilities for rideouts tis year.
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them you are a mile away and you have their shoes.
AllBlackPearl is offline   Reply With Quote
Old 11-04-2012, 07:02 PM   #1968
VietHorse
VietHorse's Avatar
Location: Recalculating... recalculating.... HCMC-Vietnam :)
Oddometer: 1,457
VFR? We have some of them last October in Robbinsville, NC:
VIETNAM by Motorcycle | My Ride Reports on ADV
VietHorse is offline   Reply With Quote
Old 11-05-2012, 06:51 AM   #1969
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,334
What is it about white third gens that is so perfect?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is online now   Reply With Quote
Old 11-05-2012, 07:01 AM   #1970
VietHorse
VietHorse's Avatar
Oddometer: 1,457
Really good catch.
That 's a awesome baby:
Old 11-05-2012, 07:57 PM   #1971
MapMaster
Human Compass
MapMaster's Avatar
Oddometer: 913
Originally Posted by VietHorse View Post
Really good catch.
Well, perfect except for two things:
White Wheels are an abomination, but even that offense does not justify caging one on a trailer.
MapMaster is online now   Reply With Quote
Old 11-06-2012, 05:38 AM   #1972
LuciferMutt
Oddometer: 11,334
Originally Posted by MapMaster View Post
White Wheels are an abomination...
HEATHEN! BE GONE!
(they do suck balls to clean)
Old 11-06-2012, 09:11 AM   #1973
slickwill
Exhiled
Oddometer: 209
[B]HEATHEN! BE GONE!
I'm with this guy. I love my white wheels and they get a lot of compliments.
slickwill is offline   Reply With Quote
Old 11-06-2012, 10:29 AM   #1974
yooperbikemike
high, wide and handsome
yooperbikemike's Avatar
Oddometer: 12,599
Yes, but as an owner of an '86 I can testify that they are imfuckingpossible to keep clean.
"...people in the stands want to see good, close racing. The thing is to put on a show, and that’s what’s going to draw people in..." -- Scotty Parker
yooperbikemike is offline   Reply With Quote
Old 11-06-2012, 10:35 AM   #1975
yooperbikemike
Oddometer: 12,599
Originally Posted by vfr870 View Post
Did you drill the VFR top triple clamp for 7/8 bar mounts? Stock lines and cables reach that far up? Some more pics from different angles would be appreciated.
Must be comfy on those long mile days.
I found a set of CBR1100XX LSL clamps (same fork tube diameter) on E-bay a long time ago (before I actually owned the VFR -- I mean, you never know, right?) for cheap and made them work with a bit of fiddling. I used ST1100 throttle cables (~2') longer, and rerouted the rest. The only one that was a bit troublesome was the choke cable, but with a bit of head scratching I made it work.
Old 11-06-2012, 12:04 PM   #1976
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,010
Thanks for the info. I'll keep it in mind if my lower back ever forces me to transform my bike into an ST870.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 11-06-2012, 03:57 PM   #1977
gtbensley
Oddometer: 258
Head bearing or tire?
A friend of mine has a 2000 vfr. We are currently on a cross country trip and he has been complaining about a wobble at 45 mph. The tire has been balanced so its not that. We are thinking that its easier the head bearing is lose, or the bike just doesn't like the tire which is a shinko raven 009. The head feels tight when rocking it back and forth but could it be a little lose? Any help would be great as we have over 4000 miles left in our trip.
04 FZ1, 06 DRZ400 SM
gtbensley is offline   Reply With Quote
Old 11-06-2012, 05:19 PM   #1978
viajero
Too old to be a nOOb
Oddometer: 2,374
Could also be caused by bad front wheel bearings.
viajero is offline   Reply With Quote
Old 11-06-2012, 06:57 PM   #1979
gtbensley
Oddometer: 258
It spins fine and when the front is suspended it doesn't seem to have slop.
Old 11-06-2012, 11:11 PM   #1980
DFH
270 deg crank
Oddometer: 392
Is this wobble through the handlebars when decelerating & when he has one or both hands off the handlebars? Both the front & rear wheels on motorcycles have a natural resonant flutter frequency, like a supermarket trolly wheel that flaps like crazy at certain speeds. Its easy to envisage the front wheel flutter rotating about the axis of the steering head, but also the rear wheel can do the same thing rotating around the steering head, but as the distance from the steering head to the rear wheel contact point is much greater the rear wheels flutter frequency is lower. The tricky part is when the natural flutter frequency of the front wheel becomes a harmonic of the rear wheels frequency. As the mass of the rear wheel & its lever ( basically all the motorcycle from the stem rearwards) has considerably more inertia the rear wheels attempt to flutter excites the front wheel into flutter mode. All bikes do this, but the road speed at which this occurs can be modified by design. The usual option is to design this flutter harmonic point to occur at low road speeds (30 to 45 mph for those that like feudal measures) and use the rider as an organic steering damper. Coast down through this speed range on any brand new, bog stock bike with both hands off the bars & you will spot the build & decay of harmonic steering flutter
As I said before all bikes have a point of harmonic flutter, so why is this a problem for your friend now & not before?
Things that will make the flutter point more obvious include tyres worn flat in the middle from too much slabbing, adding weight to the rear of the bike especially rigid hard panniers & double especially a loaded top box, rear suspension with too much sag, too low tyre pressures.
So start with the obvious. tell him to ride with both hands on the bars... death grip not necessary.
Cast a critical eye over how much crap he is carrying on the bike... or post a piccy so we can all waggle a finger at him.
Set tyre pressures @ 36psi front 42 psi rear from cold
Set preload so the bike sags 35 mm @ the rear with rider & all luggage installed. My guess a 12 year old VFR with stock shock & spring this will be impossible, but let us know how much sag their is now.
Check condition of tyres. Never ridden on Shinkos but any tyre worn flat in the centre from slabbing will cause problems long before its at legal limits.
Good luck & get back to us with how its going.
270 deg crank
DFH is offline   Reply With Quote
Times are GMT -7.   It's 07:14 PM.
