01-20-2012, 11:52 AM
#1441 | |
Will Ride for Beer...
I do like the benefits drop protection of the bags. Dropped tested mine twice on a trip last fall and there is not a scratch on the bike. Made it easier to pick up as well. Soft ground in the campground caused the first tip over. A hasty ill planned U turn to try to get back to riding partner that had just crashed behind me was the cause of the second.
"I've come to realize that just about everything is none of my business." Br. Cassian Vigna |
01-22-2012, 05:50 PM
#1442 |
Full blown child
Oddometer: 160
Are you guys buying the pelican cases and givi rack online or in a local dealer?
01-22-2012, 07:50 PM
#1443 | |
Stromer
Oddometer: 61
- the full meal deal - that would be to place an order with Caribou Cases - they are basically Pelicans that a supplier has made a custom mount for - supposed to be well engineered - the do it yourself method - buy the givi rack from a dealer, then the cases from your closest supplier and bolt the two together - quite a bit cheaper, but a little bit of practical know how required as far as dealer vs on-line - i found a good deal for the rack locally, the cases were found on-line mayday screwed with this post 01-22-2012 at 07:52 PM Reason: additional info |
01-23-2012, 05:00 AM
#1444 |
Thread Ninja
Oddometer: 1,168
list is getting shorter of what i want, basically oggie knobs (which i beleive a lovely lady has brought me) and Pc5, wouldnt mind some pannier inner bags for the v35 if i can find some on teh cheap.
Summary a 2011 VFR800Fi in Limited Edition Pearl White, Givi Plxr166 Rapid release pannier brackets Givi FZ166 MonoKey topbox bracket Givi V35 Panniers, closer fittign and more aerodynamic. Givi V46 Topbox Givi Topbox rack Givi Touring Spoiler Screen, Ignigtor Alarm Pazzoish levers Carbon Fibre tripple tree cover Ram mount, for gps, and camera mount, Ottor Box as well Powerlet headStem Powersocket. Oxford Sports Heated Grips Powerlet Top box power. Stain Tunes and Sandy Decat Headers K&N High Flow Air filter picked up a givi v46 top box brake like kit for 20 bucks one of them new old stock things, seems like a complicated thing, plug in bottom of the box, then a contact plug for when you open the top box.. Should i get a rear hugger, and/or a fender eliminator if they fit with my pannier mounts (under number plate)? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
01-23-2012, 03:56 PM
#1445 |
Oddometer: 89
Fork Upgrade
Alright so I've decided I'd like to put some work into the front end of my 99 as its already got a 929'd shock.
I've been on VFRD researching and my head is spinning. I don't want to go through the hassle of swapping entire front ends. Although I'm sure the results would be stellar, I'd rather be riding than collecting pieces from 5 different kinds of bikes. I also don't mind the linked brakes, either. Therefore it seems the best way to go is racetech springs and valving kits on the stock forks, but which ones? I've read the VFRs compression valve is harsh so just doing springs and oil won't cut it (although I'm sure it would be better than whats in the bike right now!). I'd probably go with .90 kg/mm springs fwiw. I've never delved that deep into forks before (just springs/oil on my old bandit). How much more involved is revalving? Can anyone recommend a shop if its beyond the level of work you can do in a garage? |
01-23-2012, 05:55 PM
#1446 | |
Yeah! I want Cheesy Poofs
Oddometer: 17,789
Don't be afraid of doing it yourself. If you talk to Racetech they'll tailor the bits to your bike and weight. You've already pulled a fork set apart before and this won't be much different, it'll be just remove and replace. |
01-23-2012, 06:27 PM
#1447 |
Oddometer: 82
Checking in with my Y2K VFR. Bought new in May, 2000 from Musselman Honda (Tucson). I use a tank bag for weekend trips and have a matching Arai helmet. Great bike. Only mods are to the levers (not shown in photo) and she still cleans up well.
01-23-2012, 06:32 PM
#1448 |
Oddometer: 88
Hopefully some of you guys can answer a few questions for me, I am looking to put one of two bikes in my garage for a stablemate to my Ultra. I am looking at a VFR and a Kawi 1000. Looking for comfort as well as handling.. My question for you is, what known problems will I need to address with say a 2007-2009 vfr ie: did I read about having to replace the wiring harness and the R/R (not a mechanic so I have no idea what the heck that is.....?) Is this a common problem to be dealt with? And, is the insurance really steep ( I know that is subjective.) as compared to say the Ninja. I am 52, married, home owner, no tickets or wrecks (knocks on wood!). The Ninja looks to be about 1K a year for full coverage with a multi bike policy.....sheeeesh. Anyway, I ramble...my wife will tell you not to make eye contact or I won't shut up.
Thanks for all of your help Rexford
I bet young Bozo took a lot of shit in grade school. ---- Jack Handey '13 HD Sweet Glide.... ![]() Many others gone but not forgotten
01-24-2012, 04:07 AM
#1449 | |
Oddometer: 176
'88 KLR650 Project Thread: http://www.advrider.com/forums/showthread.php?t=667727 '01 VFR800, '03 CBR600RR, '78 CX500, '04 EX250, '82 XJ650L, '75 CB360. Projects: '89 GS500, '86 ZX1000R, '85 XL350R, '71 CB750, '78 GL1000,'90 CH250 |
01-25-2012, 07:26 AM
#1450 |
Full blown child
Oddometer: 160
Just ordered a new givi rack buuuut reg rectifier just blew. Wheres the cheapest place to track one down online for a generation 3?
01-25-2012, 08:05 AM
#1451 |
Full blown child
Oddometer: 160
Tracked a solid deal for one down on ebay, The veefer should be back on the road in three days =)
01-25-2012, 03:22 PM
#1452 | |
Oddometer: 89
I also found some info about people cutting about 4 inches off the stock springs (and adding appropriate length spacer) with good results. Seems a bit shade-tree mechanic-y to me though
01-25-2012, 03:33 PM
#1453 | |
luddite
Oddometer: 566
![]() ![]() ![]() This is a very bad idea (as well as quite stupid). |
01-25-2012, 03:47 PM
#1454 | |
Rides slow bike slow
Oddometer: 9,549
The VFR will have higher maintenance costs for regular maintenance -- you say you aren't a mechanic so I assume a shop/dealer is going to be doing the work for you. The vtec valves are quite a chore to adjust and I regularly hear of dealers charging $700 and up for this service. That said, the VFR, if maintained, is not going to break down. Incredibly reliable bikes. Boringly reliable. Which is good.
You couldn't hear a dump truck driving through a nitro glycerin plant!Cobbie Award Winner |
01-25-2012, 05:06 PM
#1455 | |
AWolff
Oddometer: 371
Vfr
As for VFR v. Ninja 1000 - I have a Ducati 848 as well and if I'm honest I am no faster on the Ducati than on the VFR. It is self-preservation and avoiding magistrates court that limits my performance on the road, not the bike. If I had to let one go, the VFR would stay. In all the years and across all the types, I've never had anything that was so good and so much as the VFR. Truly an excellent motorcycle. -AWolff |
