Old 11-29-2011, 11:58 AM   #481
Pigford
British
Pigford's Avatar
Oddometer: 969
Great stuff - been wondering where you've been
Pigford is offline   Reply With Quote
Old 11-30-2011, 12:07 PM   #482
Mollygrubber
Eschew obfuscation
Mollygrubber's Avatar
Oddometer: 1,383
I've really enjoyed this thread, you do nice work YZman. Thanks for sharing this build.
"What you damn kids need is a right good war" - my father
Mollygrubber is offline   Reply With Quote
Old 11-30-2011, 12:15 PM   #483
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,124
love this quote
and pigford.................... wtf man... your avitar....
YZman is offline   Reply With Quote
Old 12-04-2011, 08:56 PM   #484
tex_downey
tex_downey's Avatar
Oddometer: 468
getting closer. and were waiting for the GF's second post.
tex_downey is offline   Reply With Quote
Old 12-05-2011, 06:38 AM   #485
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,124
Spend some time this weekend staring at the bike and trying to figure out how I am going to lay out the wireing. Never created a harness before. The making the harness isnt so hard. Just trying to figure out where its going to run and how to keep it clean looking thats the hard part. Im going to try and run some of it thru the frame and out of site.
I just put an order in for some rubber grommets and some bolts for the valve cover. Those should be in this week and I can start laying wire as I think I have everything else that I need.
Made a test piece or my connectors. Just to get my process down. Turned out pretty good I think. Just using Bullet connectors for the most part. Its simple and clean. I dont want big bulky plastic connectors all over the bike. I like how these are very streamlined and kinda disapear on the wire once plugged together.
Still working on moving out of my old house. Lots to do yet but its getting closer. Another week or so and I should be out of there. 4 rooms down. 2 to go plus the outside shed stuff (shudder)
Old 12-06-2011, 07:40 AM   #486
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,124
So has anybody pulled wires thru a frame before?
Im not so concerned with pulling wires thru. Thats not that bad. Im just thinking. So I make this wireing harness complete with my bullet connectors and all that. Everything works fine and dandy. Well I have to take this bike apart still to get it painted. Am I going to be able to pull the wireing out of the frame and put it back in with the bullet connectors in place? Im only putting like a 3/8 hole in the frame. The grommets I have coming in are 9/32 id using a 3/8 hole. The rear frame tubes are only 1-1/8 dia so I cant go too big with my holes. Nor do I want to really.
My vision is to 1st fish a somewhat ridged wire thru the frame. Then on the end of that tape the 3 wires I want to pull thru staggering the connectors one after the other so they will go thru the hole easier. then just pull them thru. Sounds easy huh
I guess Ill just have to try a section and see how it works. The frame backbone wont be hard as thats a larger tube. Its mainly just the tailight run that concerns me as thats smaller tubing.
I know the pros usualy paint the frame 1st then wire it up. I dont really want to do that. I want to put it together and make sure everything works before I strip down for paint. Ya know. Make sure something doesnt need welding at the last minute. maybe Ill have to make 2 harness's. One temp one and the final one.
Hey also.. should I say black tape wrap the wires together that are running thru the frame to protect it from abrasion? Kinda thinking I should.
I did get some better solder last night. Flux core 1/16 dia so I can solder my bullet connectors on as well as crimp them. I did another test piece and the new solder is sooo much better to use. Flows beautifuly. The solder I was using on my 1st test piece...well lets just say it doesnt work for shit and leave it at that. I dont know why I even keep that crap around...just cant throw anything away I guess. Something I probably got from my grandpa that he got back in the recession...
YZman screwed with this post 12-06-2011 at 07:58 AM
Old 12-06-2011, 09:17 AM   #487
mike54
You don't get me
mike54's Avatar
Oddometer: 13,279
I've never put a wiring harness inside a frame before but a nice trick is to use compressed air to blow a string through the tube and use that to fish the wire back through. I've done it with heated hand grips and it works pretty good.
I wouldn't paint the frame with the wire inside. You're going to have to tape off the wire that's sticking out and the grommets. Sounds like more trouble than it's worth to me.
As far as never throwing anything away . . . I had a rental house and the hot water heater craped out on a saturday. The tennent called me and I went over to Home Depot and bought a hot water heater and went to install it. I spent all day trying to solder the pipes to get the install done. I had to come back the next day and the poor guy had to take a cold shower that morning. I called a plumber friend the next day and he came by and coudn't get it done either. Just couldn't get the solder to stick. Finally out of despairation I went and got new solder and flux. Bam! everything worked as it should. I missed 4 football playoff games that weekend messing around with old flux and solder. It's funny now but at the time . .
I check this thread every time you update, I'm digging it.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 12-06-2011, 09:25 AM   #488
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,124
No Im not planing on painting it with the wires in it. I just dont know if once I pull the wires out... if I can get them back in..hell Can I even get them out to begin with once I put the ends on. I guess Ill just have to try it and find out. I like the string idea though. Ill have to try that.
Old 12-06-2011, 09:32 AM   #489
mike54
You don't get me
mike54's Avatar
Oddometer: 13,279
I get what you're saying. Heck yes I would do a test run with the wires before the paint. To me the whole pre-assembly process is to find functional faults in the design and get them corrected before paint, but it's also to find faults in the assembly process. Practice makes perfect.
It's your bike. Do what you feel comfortable with. I'm just saying what I would do. Knowing my skills and my ability to scratch new paint and all.
Old 12-06-2011, 09:40 AM   #490
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,124
By the way I cannot rave enough about Mcmaster Carr's shipping and website. Its just a model of how a company should run. There website is 2nd to none. I ordered my parts yesterday morning at like 9am. 10am they were shipped. Today they are out for delivery. That just amazes me. love that place. love love love that place.
And at work (im an engineer) they have 3d cad data for most any part on there site avaliable for download that I can put into my assemblies.
They might not be the cheepest place in town. But they always have what I need and get it to me fast. Some things are just worth the money spent.
Old 12-07-2011, 06:54 AM   #491
jphii
OK, now what?
jphii's Avatar
Oddometer: 1,960
I don't care if I order $5 or $500 worth of parts, it's the same for me. Great people to deal with.
jphii is online now   Reply With Quote
Old 12-12-2011, 08:40 AM   #492
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,124
So Friday night I had a few spare minutes so I wandered down into the shop to do some tinkering with the electrics. Which is code for staring at this growing pile of electrical shit and figure out how the fuck to unpile it and make it play nice together.
About this time I notice...ie smell a problem. Apears my dog has had an accident in the basement (if its going to happen this is the room for it) but it was quickly aparent we had a problem. I wont go into the specifics of it but I knew my dog was not well. So I shuffled her off to the garage (dont need anymore accidents in the house) and took off for an hour to pick up my girlfriend at the airport. By the time we got back we knew we had a serious issue and raced her to the emergency pet care but it wasnt meant to be.
R.I.P. Angel. You will be missed baby.
Old 12-12-2011, 09:12 AM   #493
Dorzok
Dorzok's Avatar
Oddometer: 1,926
Blows. we'll all understand if this bike NEVER gets finished now. but if you do name it Angel.
Dorzok is online now   Reply With Quote
Old 12-12-2011, 11:39 AM   #494
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,124
Oh no... it shall be finished. That was just a delay for the weekend. Moms in town this week but this weekend I should be back at it again. Might even drill holes in the frame and stuff...
Old 12-12-2011, 08:26 PM   #495
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,663
Sorry to hear YZ
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Times are GMT -7.   It's 07:12 AM.
