Old 07-30-2009, 08:06 AM   #151
tsprings
T-bone
tsprings's Avatar
Oddometer: 21
Oil Leaks
Originally Posted by Recyclerator
Oil leaks noted....thats next on the agenda. Oil seems to come from under the crash plate. Any ideas how to fix that?
Russ
When I bought my bike the skid plate was full of oil too. I've got the same bike, same year, and after removing the skid plate and doing some cleaning, it appears that it's leaking from the copper gasket around the 17mm hex head bolt that is next to the oil pan drain plug. It's the one that is kind of on an angle on the opposite side as the kick start. The owners manual specifically tells you not to remove that bolt because it is holding tension on the kick start return spring. But if that is leaking I don't think I have any other choice. Has anybody removed that bolt before?
Theran
tsprings is offline   Reply With Quote
Old 07-31-2009, 04:26 PM   #152
Huskyfatman
Huskyfatman's Avatar
Oddometer: 1,330
Rode the 605 to the hardware store the other morning and came out to see this parked next to it. Not an ATK, but the side case said ROTAX.
http://www.sharetrails.org/
http://www.americansandassociation.org/
"YOU KNOW. . . . . .WE ARE LIVING IN A HEAT LAMP SOCIETY!"-Ron Perez 2002
Huskyfatman is online now   Reply With Quote
Old 07-31-2009, 09:05 PM   #153
Gummee! OP
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,398
Buddy of mine has one. Neat bikes.
Short legs tho. HAVE to stop about every 100mi
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 08-01-2009, 03:13 AM   #154
Slowflyer
Oddometer: 40
Found an interesting picture of an ATK Avenger in another thread :
http://www.americandirtbike.com/Avenger13.jpg
Couple of things that caught my eye(s) :
- Has it got some sort of automatic chain tensioner ?
- Has anyone got (detailed) pictures of the rear shockmount ? It looks like the shock is almost horizontally mounted, and connected to the left hand side swing using round tubes ...
Slowflyer is offline   Reply With Quote
Old 08-01-2009, 08:15 AM   #155
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
The Original ATK had a wide device that prevented the chain from binding upon compression of the shock. Its a german thing. You can google ATK history and it will explain better than I can. American Dirt Bike is still building bike's off this old design.
Heres a picture of an Avenger naked.
Notice that they're still putting the rear brake rotor on the countershaft
Its a strange critter but then thats how all the early ATK's was till about 94 I think it was.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 08-01-2009, 09:28 AM   #156
Slowflyer
Oddometer: 40
Thanks !
Found a nice closeup picture of the sprocket/chain & countershaft rotor design :
Old 08-01-2009, 11:41 AM   #157
Rokoneer
Oddometer: 541
Has anyone here ever owned an Avenger?
Has anyone here ever seen an Avenger in person?
How many bikes do you think Avenger sells? How do they stay in business?
Rokoneer is offline   Reply With Quote
Old 08-01-2009, 02:06 PM   #158
Huskyfatman
Oddometer: 1,330
The device is where ATK originally got it's name. Anti Tension Kettenantreib, from the German "chain drive", was developed by ATK founder Horst Leitner, now head of AMP research.
Old 08-04-2009, 03:26 AM   #159
Kapp555
Better to be Offroad!
Kapp555's Avatar
Oddometer: 671
Anyone have a fix for the very weak side stand? Mine is on borrowed time
Kapp555 is offline   Reply With Quote
Old 08-04-2009, 08:53 AM   #160
Gummee! OP
Gummee!'s Avatar
Oddometer: 28,398
I thought I saw something on the ATKBB.
M
Old 08-05-2009, 10:49 AM   #161
tsprings
T-bone
tsprings's Avatar
Oddometer: 21
Question Dellorto
Need some help with the Dellorto carb on my '97 605DS. I removed the flipper choke the PO had installed and went back to the factory choke cable. Also took carb apart and cleaned all the jets. Now I'm having issues. It will not start with choke at all, gets bogged down. Will only start with open throttle. Then will only stay running with 1/4 to full throttle. Will not idle. Dies as soon as I let off the throttle.
I've taken the carb apart twice. Tried every sort of idle and bleed screw adjustment i can think of. At a loss for what to do next. Have tried so many times the battery is dead at the end of the night. Seems like its getting too much fuel vs. not enough.
Perhaps it's possible i didn't reassemble something right, but the fact that it will start and will run if the throttle is open confuses me.
The mechanics in my area are not willing to look at it...being an ATK.
Any hints?
Old 08-05-2009, 11:17 AM   #162
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 11,739
Are you sure you put the cable choke together properly? Is there slack in the choke cable when it's closed? It sounds like the choke plunger isn't sealing the port down inside the hole.
Donkey Hotey is offline   Reply With Quote
Old 08-05-2009, 11:19 AM   #163
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Any hints?
Double S Enterprises
799 US Highway 20 W
Elizabeth, IL 61028-9571
(815) 858-3881‎
Talk to Bruce,
he owns the place, its a small motorcycle shop. He has been an ATK dealer for years. He can probably help you.
He's open from 4pm to 7pm.
Tell him Terry said to call.
Old 08-05-2009, 01:05 PM   #164
Gummee! OP
Gummee!'s Avatar
Oddometer: 28,398
My first guess is air leak somewhere, but I'm no expert on carbs by any stretch of the imagination!
M
Old 08-05-2009, 07:24 PM   #165
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,397
check that the kill switch in in the run postion , don't laugh BTDT, then see if the choke is working, then make sure the needle and slide are working, basicly double check everything you've done. One more thing to check is the carb boot to the motor, I had mine backfire and push the carb out of the boot.
Mike M.
Creswell, Oregon
'14 KLR 650
Ride what makes you giggle in your helmet
oremike is online now   Reply With Quote
Times are GMT -7.   It's 12:16 PM.
