08-05-2009, 11:57 PM
#166 | |
Better to be Offroad!
Oddometer: 671
Sorry for this bad photo but you can see my slide is worn badly. I am going to change the idle screw to the opposite side today and then reroute my bowl vent lines later today and hopefully it will be idling right!
Kapp555 screwed with this post 08-06-2009 at 08:43 AM |
08-06-2009, 10:27 AM
#167 |
T-bone
Oddometer: 20
Carbs
Thanks for the advice and the contacts guys. It will be a few days before I can dig into this a bit more. I spoke to the PO and it sounds like he had it rejetted a while back. I'll have to find out what was done.
Kapp, how do you post a picture in the message? I've had no luck. I'd like to take a picture of the vent lines and have you guys tell me if they look like they are routed properly. |
08-06-2009, 10:34 AM
#168 | |
Oddometer: 671
** Update, I took my carb off again today and I confirmed I cannot move the idle screw from one side to the other. So, I am going to attempt to get my slide welded so that it will idle. I took another photo for you Tsprings so you can tell if your slide is damaged. Just take the top of your carb off. The part where the throttle cable goes into the carb and look at the bottom of the round slide. There are only 2 sides you can see em indented on my photo. If your idle screw has caused the slide to get dented then you either need a new slide or you need to get the old slide welded. You can see from the photo that one side is smooth and the other side is all dented from the throttle slamming shut on it. Hope this helps.
Kapp555 screwed with this post 08-06-2009 at 03:39 PM |
08-09-2009, 03:39 AM
#169 |
Oddometer: 671
Where are you ATK 605 guys getting your oil filters from? Is there anything aftermarket and easy to get?
08-21-2009, 08:20 AM
#170 | |
Oddometer: 15
ReWeak side stand
The Wire is stainless steel twist cable with a couple of eyelets and swedged in place. Most of thats readily available. The tangs (bent flat pieces) are left over from my hang gliding days but should be easily fabbed. finally the bungee pulls the wire forward when the stand is raised to keep it from inerfering with the rear tire. Under the swing arm I drilled a single 3/16" hole and put a steel rivet in to hold the tang. this will receive a side load only and I'm hoping its up to it. I expect this to be the weak point. I believe your only other choice is to remove the swing arm and re weld with a stronger gusset. [IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG] ![]() ![]() ![]()
Dogs look up to us, cats look down on us, pigs regard us as their equal....Churchill |
08-28-2009, 03:05 AM
#171 | |
Oddometer: 671
08-28-2009, 03:07 AM
#172 |
Oddometer: 671
And I think you guys might like this...those of you that have carb problems.
http://www.guzzino.com/flupchscinph.html Its a flip up choke for the dellorto. With my slide being welded, the valves set at .005 and this new choke my bike is purring at idle. I also did the overflow valve T as recommended. I am down to getting the clutch adjusted, the suspension dialed in and rebuilding the seat.
09-18-2009, 11:16 AM
#173 |
That's MR. Toothless
Oddometer: 25,568
Has anyone thought about getting a frame welded up that would fit aftermarket tank? Instead of running that curved backbone, make it straight and weld on some tabs to fit KTM tanks... Don't look like it'd be THAT tough
M
There. I've moved back to VA. Can you PLEASE change the weather?! |
09-18-2009, 01:30 PM
#174 |
Oddometer: 26
That's an interesting idea. It would take a jig to ensure everything ended up in the right place after welding though. I have an extra frame and it sounds like a cool idea. If someone spent the time to do it right and had good skills with the welding I'd consider it. How much difference is there between the older style frame and what would result with this change?
02 E440 St legal Cannondale 98 gasgas 200 enduro 97 gasgas trials |
09-19-2009, 08:39 AM
#175 | |
Motorcyclest
Oddometer: 2,202
Mike M. Creswell, Oregon '09 XR 650-L Ride what makes you giggle in your helmet |
09-27-2009, 09:09 PM
#176 | |
Oddometer: 1,020
The enduro is a fantastic trail bike... 1990 406 enduro 6 speeder with the 4 gal tank and nickel plated frame.. ![]() 1990 406 MX with the 5 speed and light flywheel, I have the MX tank and seat for it... ![]() Ok, now back to finish the thread...
Originally Posted by d0gWateR Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider! |
09-28-2009, 06:15 AM
#177 |
Loose nut behind h/bars
Oddometer: 4,508
![]() 2002 Super Moto, I miss that thing! Won a shit load of races on it. The pic is Beaver Run, Pa. Great track! I also had a 1999 605 DSES.....gone also ![]() Replaced with a 2006 KTM 525 EXC ( I can get parts for this!!!)Anybody want a 2001 VOR 400 Enduro? (figured since ATK had parts once.............................................) Chris
http://www.theshining.info/ KTM 950 Adv. "S"...'06 KTM 525 EXC... '76 MV Agusta 750 America S...'84 Honda VF1000... '90 Kawasaki ZX11...'76 Kawasaki 900 Z1...'01 VOR 400E |
10-15-2009, 04:37 PM
#178 |
Oddometer: 25,568
So I got out on the ATK for about an hour last nite. Rode around the desert behind the house as well as the next stretch of desert down the road.
Did you know you could steer 90deg out and still go straight if yer giving her the welly? Did you also know that once you hit a sand berm, it WILL turn while you have the bars turned 90deg and giving it the welly? ![]() Yeah, deep sand still sux, but its better than riding deep sand on the GS-Adv! ![]() Things to do: handguards bar risers strengthen the rear subframe to haul s'more fuel 'cause the area I rode the GS-Adv thru today has MANY many more trails. M
10-15-2009, 06:36 PM
#179 | |
BRP Rider
Oddometer: 365
10-4 on "deep sand sucks." Dave |
10-15-2009, 06:41 PM
#180 | |
Oddometer: 25,568
What happened to you today? LstZephyr and I had a great little ride. ![]() Speaking of semi-legal... The reg/rect I got from the PO isn't *quite* right. I don't know if I hit something and jarred the pos battery cable loose or if it isn't putting out enough juice. I'll hafta take her apart again to make sure. I guess I *could* be doing that now, but there's mosquitos out there that've already chewed on my legs. ![]() M
