Old 09-20-2010, 04:30 PM   #136
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,106
Could be some really good deals on /5 parts here. Could be junk though too...
PARTING: 1972 BMW R75/5 - $1 (Ballard)
Date: 2010-09-20, 3:01PM PDT
Reply to: sale-kbt6v-1964539946@craigslist.org [Errors when replying to ads?]
Parting out a classic 1972 R75/5 toaster beemer with 42K on it.
Engine block with crank $95
Cylinders $65
Pistons $25
Starter $45
Transmission (untested) $85
Frame, subframe and forks $145
Many small parts in boxes. Text me your part requests ...206-316-0424
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Airhead Wrangler is online now   Reply With Quote
Old 09-25-2010, 08:40 AM   #137
DCrider
Live from THE Hill
DCrider's Avatar
Oddometer: 3,023
KLR 650 Tengai ready to go! - $1700 (Damascus)
Date: 2010-09-20, 9:21PM EDT
Reply to: sale-dnyau-1964787952@craigslist.org [Errors when replying to ads?]
The same bike was made from 1987-2007, this one is a 1990 Tengai (KLR 650-B2), which was a city version. It means that the seat is a touch lower, it has the low "city style" front fender, the turn signals cancel when you push the button (don't have to slide it back to center), slightly softer suspension, and most of all, a two-piston front brake (not great but better than most KLRs). Has about 19,000 miles.
The tank and side panels were replaced to make this a better campus ride for the U of Md and as a city commuter. Ironically, the bike never got dropped in the year and a half we've owned it. The custom tall windshield is actually effective, the turn signals are tucked in where they shouldn't get broken off if the bike falls, there are 10mm socket holes in the side panels for easier seat removal, a connector for a battery tender, etc. The body is obviously a repaint that came out pretty good. It's painted with engine paint, so it's somewhat gas-resistant. If you spill a bit at the pump, wipe it off right away and use some rubbing compound later - you won't strip the paint the way most enamels will.
The bad:
The countershaft leaks about three drops of oil whenever we park the bike, so we watch the oil level. A new bushing, seal, and o-ring are only $32 and the replacement is easy - we just never got around to it.
The tank has a small dent in the right.
The good:
It's been taken care of and that shows!
New clutch cable (Pretty sure that we also changed the throttle cable),
Welded crashbars around the radiator as part of the bodywork,
Pelican case toolbox under the license plate,
Massively improved rear lighting, including 3 LED brake lights, & lit turn signals
Enlarged plastic cargo rack,
EagleMike doohickey with the better torsion spring,
The metal choke thimble on the carb,
New rear tire (Kenda 761) with only a couple hundred miles on it.
Improved headlight is MUCH brighter than stock.
A bottle of blue Locktite comes with it. I use the stuff on everything I unscrew.
The JC Whitney topbox is a mixture of good & bad. It's there, holds a helmet, and whatever else. However, the latch never worked well, so I drilled a hole for a lock to securely keep things shut. That worked till somebody tried to force it open and there are now two small cracks. One is at the lock hole and the other is at the right hinge. Just being up front about it and again, the box still works. JC Whitney puts these on sale now & then for 30-some bucks, so it could always be replaced cheaply.
With the updates, the price is $1700 firm. I do have the original bodywork and tank for another $400.
http://washingtondc.craigslist.org/m...964787952.html
ADV'ing from America's fine Crapital...
DCrider is online now   Reply With Quote
Old 09-26-2010, 10:59 AM   #138
elmontanero
Practicing...
elmontanero's Avatar
Oddometer: 1,429
wow...
Nice...not sure there's a 82 r100gs (doesn't make sense at all) but what ever it was it's nice now. No affiliation.
http://sfbay.craigslist.org/eby/mcy/1971327342.html
"And if we have food and covering, with these we shall be content."
elmontanero is offline   Reply With Quote
Old 09-27-2010, 06:54 AM   #139
AntonLargiader
AntonLargiader's Avatar
Oddometer: 3,460
That '82 R100GS' has been posted for sale in various places for probably at least a year now. There have been threads on it. FWIW I have no idea what the seller thinks the GS connection is.
Old 10-05-2010, 06:28 AM   #140
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 1,849
Hey, that's mine!
Thanks for the mention. The bike's in Maryland and I'm doing lots of travel for work, so haven't been able to show it. If people sent me a message, I really will try to get back to them.
You can pm me here on ADV.
Bob
The bad:
The good:
Super Tenere in black
AMA, IBA
June 2012 Maryland to Alaska: http://advrider.com/forums/showthread.php?t=796138
Wreckchecker is offline   Reply With Quote
Old 10-07-2010, 04:03 PM   #141
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 2,858
http://boston.craigslist.org/bmw/mcy/1994303083.html
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is online now   Reply With Quote
Old 10-07-2010, 07:05 PM   #142
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,898
Originally Posted by mrt10x
"Bike in great shape. Bought it 4 years ago with 12000 miles. Now have 15000. No problems I just don't ride it "
Thats a problem.
What to do... What to do...
Stagehand is online now   Reply With Quote
Old 10-09-2010, 07:18 PM   #143
LotaBikes
Oddometer: 80
Too bad there is no pic.
http://oklahomacity.craigslist.org/mcy/1998172178.html
LotaBikes is offline   Reply With Quote
Old 10-10-2010, 10:26 AM   #144
Uncle Pollo
Von Hochstaden's son
Uncle Pollo's Avatar
Oddometer: 44,977
Originally Posted by Airhead Wrangler
Dream on, jackass...
1995 BMW R100GSPD - $10800
Date: 2010-09-08, 9:19PM PDT
Reply to: sale-exckd-1944159472@craigslist.org [Errors when replying to ads?]
1995 R100GSPD Classic 15700 miles. totally stock with factory bags, manual and original tool kit. Condition is 8.5/10. Bike starts easily, idles smoothly and runs perfectly. There were less than 120 of these motorcycles imported to the USA. Truly a collectible machine and a rare find in original stock condition.
You never sat on a salesman's chair at a dealership listening to the trade in expected values ... right?
mikuni vm32-33 both sides :\ 5000 feet altitude/
140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide
35 mpg around town riding like a asno
Uncle Pollo is offline   Reply With Quote
Old 10-22-2010, 10:51 AM   #145
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 6,911
Send a message via AIM to crazydrummerdude
If I had a real job, I would buy this:
1972 BSA 650 cc - $750 (WEBSTER)
Date: 2010-10-11, 12:32PM CDT
Reply to: sale-7femb-2000499722@craigslist.org [Errors when replying to ads?]
FIRST 750 CASH
99% COMPLETE, TOP END OFF, TURNS OVER, NO TITLE, NICE PROJECT
  • it's NOT ok to contact this poster with services or other commercial interests
crazydrummerdude is online now   Reply With Quote
Old 10-26-2010, 07:37 AM   #146
Bulleteer
Aimless Wanderer
Bulleteer's Avatar
Oddometer: 320
http://greenville.craigslist.org/mcy/2023808964.html
"a very nice r80 with minor modifications, single corbin seat with cowl, mini fairing, new mufflers(not shown) and top end rebuild. runs great, 5 speed about 500 miles on tires. have many parts to return to stock condition included."
No affiliation with the seller, but the bike looks pretty clean in the photos.
Bulleteer is offline   Reply With Quote
Old 10-26-2010, 05:38 PM   #147
DCrider
Live from THE Hill
DCrider's Avatar
Oddometer: 3,023
that is a nice bike, looks like a very fair price
Old 10-28-2010, 03:24 PM   #148
thumpism
Oddometer: 246
I'd like to have this one:
http://richmond.craigslist.org/mcy/2029807482.html
1990 BMW K75 with fairing, 750 cc, garaged, 45,000 miles, locking hardbags, extra windshield, 2 helmets, 45 mpg. Runs well, but needs a little work. Known flaws: failed state inspection due to short in blinker in fairing, the rear shock is leaking a bit and will need replaced. Feel free to email and leave a phone number to call for more information. Note, Kelly Blue Book values this at around 2800. Will take 1800 cash OBO.
thumpism is offline   Reply With Quote
Old 10-28-2010, 03:37 PM   #149
notarex
Can U taste the waste?
notarex's Avatar
Oddometer: 1,213
Anyone looking to build a boardtracker? Teens HD motor
http://hartford.craigslist.org/mcy/2027803667.html
1972 GUZZI AMBO
1963 CA95
2006 RUCKUS
To boldly go where no Ruckus has gone before...
notarex is offline   Reply With Quote
Old 11-08-2010, 10:04 AM   #150
Brian-M
Melting in GA
Oddometer: 943
Thought this was kinda neat, not mine so don't ask me about it:
http://denver.craigslist.org/mcy/2048879197.html
BMW R-90/6-GS - $6000 (DENVER)
Date: 2010-11-08, 10:25AM MST
Reply to: sale-nahjs-2048879197@craigslist.org [Errors when replying to ads?]
1975 BMW R-90/6-GS
Custom built GS. 12" travel. All original bike with custom suspension and subframe.
Based on the GS prototype. Goes everywhere!
Serious parties only please.
Brian-M is offline   Reply With Quote
Times are GMT -7.   It's 06:56 PM.
