Go Back   ADVrider > Riding > Regional forums > Canada
Old 02-09-2013, 07:20 AM   #2896
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,002
Yo! Beema Killa
Hey I was out yesterday also! 350kms mostly bumpy paved roads and some gravel. Was thinking of contacting you, but you being a young fella, figured you'd be working. Too bad. None of my regulars could make it. Probably the best day we're going to have for a while. Maybe next week.
RED CAT is offline   Reply With Quote
Old 02-09-2013, 09:37 AM   #2897
Beema Killa
Beema Killa
Beema Killa's Avatar
Oddometer: 816
Yeah it was a great day. I only work Monday to Thursday, so after errands it's usually saddle time on Fridays.
Beema Killa is offline   Reply With Quote
Old 02-09-2013, 03:06 PM   #2898
flossandfly
flossandfly's Avatar
Oddometer: 339
today looked good for a ride until the short blizzard
Got the bike put together and it looked beautiful (the weather and the bike haha). Got cleaned up and it was blizzarding.
flossandfly is offline   Reply With Quote
Old 02-09-2013, 07:53 PM   #2899
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,002
And!
We actually pay them to do it. Sort of like using you own Vaseline.
Old 02-10-2013, 07:32 AM   #2900
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,002
Usually!
Don't need a bearing puller to replace a rear wheel bearing. Pop off the seals, maybe a circlip, so be careful.Apply WD40 and let sit for awhile. Then from the opposite side, slide a long punch through the axel hole and get it on the edge of the bearing and tap with a hammer moving the punch all around the edges of the bearing. Should eventually start sliding out. Clean up with WD40 or lube with oil and tap the new bearings in. Put the new bearings in the freezer for a while. Helps them slide in easier cause they contract a little. Use a socket to tap the new bearings in. Make sure you tap just on the outer edges of the bearing. Just take your time. If the punch doesn't work try a screw driver. Anyhow, this is how I've always did it.
Old 02-10-2013, 10:13 AM   #2901
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,573
A couple of brass punches of diffrent sizes are a worthwhile investment (if you don't already have them). It can mitigate some hamfisted gouging of the hub/cush drive.
I do know a good mechanic should you need one.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 02-10-2013, 12:58 PM   #2902
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,784
You can get a blind bearing puller at Princess Auto but I have always used a punch, too.
I also find that applying a heat gun to the hub helps on removal and install, too.
Send from my Droid using Tapatalk
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is online now   Reply With Quote
Old 02-11-2013, 07:16 PM   #2903
Jeathrow Bowdean
Oddometer: 458
I picked a good dealer to buy my bikes from, and I see a trusted family run buisness to do my service work. Family run shops take pride in thier work bing that this is what they live on. I don't trust big dealerships to work on my stuff, so the small dudes fill my needs.
From Jeathrow Bowdean in Western Canada
Jeathrow Bowdean is offline   Reply With Quote
Old 02-12-2013, 12:49 PM   #2904
Shibby!
Oddometer: 1,665
Originally Posted by Lycan1 View Post
BigDog seems to like his. There is a sm version (2008) for sale on Kijiji for $3900. north of the city. The bike is pretty much unchanged from 2008 - 2013. They just need a Safari tank to make them trip worthy. The engines are rock solid from everything that I have read. Thinking about one of these myself.
http://calgary.kijiji.ca/c-cars-vehi...AdIdZ450033108
I'm going back and forth with more things than one. Considering getting back into serious dirt biking, or new trip bike. XRR's aren't around so I revisited the WRR.
Sadly this one is gone and the rest of them are on crack pricing. This bike was a pretty good deal!
Anybody here pick it up? I'm to the point today that I thought I'd just buy it to ride around this summer and sell if I didnt like it, but when I went to check it out it was gone =(
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 02-12-2013, 04:25 PM   #2905
Shibby!
Oddometer: 1,665
There's a few on there that are higher than new pricing! The one quoted as being 10K+ has smoked a little too much. All I can see is full exhaust and tank. I know both those items are expensive compared to XRR pricing, but that doesn't mean they are 3 grand worth.
As you mentioned, parts don't add to the sell price, they help sell the bike.
3800 was a good deal. I've seen them over the years get listed for that price because they don't have a huge market. It's a solid bike for that price for sure though. 7500 used? Eh, there are other options just as good, or better. It puts you into Xchallenge, DR/XR, high mileaged 950/990's, TE610/630, GS800 and 690 range.
Old 02-12-2013, 05:23 PM   #2906
windquest
windquest's Avatar
Oddometer: 574
Shibby, I good friend of mine has a WR250R, I'm sure he'd let you try it out to see if u like it...
Trans-Canol 2014ish
windquest is offline   Reply With Quote
Old 02-12-2013, 07:27 PM   #2907
Shibby!
Oddometer: 1,665
I've actually rode on a bit in Yuma, AZ after a trip to Baja. It was hard to jump from the XRR to a 250, but I didn't give it a fair shot. Just around the neighborhood a bit.
Things I instantly noticed:
1) They still aren't light. (about the same weight of the XRR I believe)
2) The power was missing, but that's not a huge issue.
3) Gearbox, although it has 6 gears, felt quite notchy. Dare I say almost cheap? Maybe it was just positive and not like the XRR I just finished riding 4000km's on.
4) Electric start, solid power generation, and a factory speedo/odo was luxury for me.
5) Pretty smooth if I remember correctly. I only got on it a few times.
Till I put more thought into this I'm not taking it overly seriously. If one comes up for cheap I might pick it up if I have the money laying around () but till then, I won't even entertain the thought until I see numbers in either low 4's or 3's.
Old 02-13-2013, 06:45 AM   #2908
desmodab
Oversized Canuck
desmodab's Avatar
Oddometer: 356
Dealers...
Hey guys - I know this is a dual sport thread so I'm hesitant to post here now that I have my Ducati (which despite their marketing materials is not and never will be a dual sport machine ). One of these days I'll get a second bike for DS but that will require a few more years of wife re-training. That being said, I was reading a few posts back about Lycan's challenges with the dealer routing his brake lines on the wrong side of the forks and thought I'd share this fun story of dealers (or lack thereof!) in Calgary:
http://advrider.com/forums/showthread.php?t=862582
So at least you HAVE a dealer in YYC!
Good riding, DD
desmodab is offline   Reply With Quote
Old 02-13-2013, 07:12 AM   #2909
Shibby!
Oddometer: 1,665
You could always put it past your wife to sell the ducati and with the same money buy a Vstrom and dual sport. Win-win.
At least you recognize it's not a dual sport, or even an adventure bike. You'd be surprised how many swear that bike is the "do it all wonder". They are nice bikes though. I'd get one for ADV Touring.
Sure, you can flog them down whatever you want. I used to ride the odd gravel road on a supersport bike. It's do-able, but I won't recommend it. haha.
I've given up on dealerships here long, long ago. I've only taken one of my bikes to one dealership a long time ago. I refused to deal with all stealerships hearing the horror stories and dealing with them on buying simple things in store. Of course, they did it wrong and tried to charge me for things I didn't authorize. I even clearly stated I didn't want it done when I brought the bike in. The reason I had to take it in was for a recalled swingarm. That dealership is now out of business (Aprilia / Ducati)
It's more rewarding and most times cheaper to do the work yourself. The benefit here is you LEARN. Not only how to do it, but the mechanics of your bike. It's the first step to kicking dealerships and their 120$/hr charges.
KTM: Know The Mechanic
BMW: Bet on Mechancal Work
Old 02-13-2013, 08:52 AM   #2910
Shibby!
Oddometer: 1,665
$120.00/ hr is the off- season rate. They have to pay for the bling-y showrooms and shops somehow, and I understand that. All I ask is that they do the work right and stand behind it. When that isn't the case then I can't and won't justify the cost!
Hell, there was a time I would let them do tire changes for me. I watched while the "mechanic" ripped off a valve stem from a tube (that he forgot to loosen the nut from) while pulling the tire off as if it were tubeless. Then they tried to tell me it was an old rotted tube. When I shut them down (I bought the tube 2 months before, from them) , they gave me a new HD tube no-charge. It would have been a different story if I had not been standing there, watching. That was the last time a paid to have someone change a tire for me. Anger and disgust can be great motivators to learn a new skill.
KTM: Keeps Taking Money
BMW: Bring more wallet
Sad thing is their "tech's" are often very green, or unskilled all together, yet they still charge 120$/hr. Tire changers are often highschool students and the like.
120$/hr isn't cheap, but for some things yes it might be worth it, but most often not. It's strange how mechanics make the same or less then most trades, but get charged out at nearly twice the price? Never did understand that. Oh yea, like you said, it's so they can have fancy show rooms with bikes that sit there and don't move because they gouge AND hire a ton of staff that know next to nothing about our industry and riding in general.
I made this comment on another forum and a store sponser made a bad comment about it, but I go into stores expecting the worse, so in the rare event they have or know something I come out happy. Going in expecting something is the wrong approach and normally leaves a sour taste in the mouth. This was in relation to gun stores, but same thing applies. I'm also into precision shooting.
What I do love and look forward to is either receiving incorrect information, or better yet the blank face received from asking a question that the person working at the store has NO idea about. Blackfoot is good for that one. The last time I had that I was asking about suspension shims for re-valving suspension. It went through nearly every person in their parts department like a domino effect of blank, dumbfounded faces. haha. GW (for honda parts) seems to be the best in town and often surprising how fair their pricing on parts can be. I always check there before buying stateside.
I'm excited to ride this spring but I know it's a long ways away. Even easy, non-pass trails will likely have AVY debri. This season hasn't been too bad so maybe things will be accessible earlier. I'd like to get some early season DS and camping in.
Shibby! screwed with this post 02-13-2013 at 08:57 AM
Times are GMT -7.   It's 09:56 PM.
