Old 02-10-2009, 11:37 AM   #1
ShadyRascal OP
Master of None
ShadyRascal's Avatar
Oddometer: 6,398
Alcohol Stoves
UPDATE: The bottles I make these stoves from are not available anymore. I have depleted my stock and will at this point 1/26/2015 not be able to ship any more stoves. It has been a pleasure to serve my fellow ADV riders with my little stoves for the last 6 years. Thanks to all who have participated.
Stever
I am building alcohol stoves (or more accurately, alcohol burners) out of aluminum bottles. They are simple, strong, and foolproof.
The difference between these and the more common aluminum can stoves is that the material used in these is .025" thick, so they are very sturdy. I can even stand on one and pretend I'm riding my motorcycle.
Really.
For fuel, I find Heet is the best. (Methyl Alcohol) It burns very clean, leaves no residue on your pots, and has lots of heat energy.
To operate: Pour your Heet right in the middle of the can.
Light it right in the middle.
You will get a very faint flame up out of the burner.
Just let it burn, and after about one minute, it will heat up and self-generate flames out of the side jets. If you want to speed up this process, go ahead and hold a flame along the outside of the can after about 30 seconds and you can ignite the jets manually.
Now you're burning and ready to cook.
Or, if you have a surface such as a flat piece of aluminum, you can dribble a little Heet around the bottom as a primer. Then, light the top as shown
Then light the Heet on the bottom.
The flame will quickly spread around and up the side, and ignite the side jets in seconds
Then your burner is again, fully lit and ready for action.
The fastest way to heat is to put your pot right on the stove. With the side ports on this burner, that works best. Here is a 6" diameter pot on the burner.
In this pot, covered in 30 degree air temperature, I brought 2 cups of water to full boil in 5 minutes.
You can also simmer by holding pot above the stove slightly. I improvised a little grill, and your imagination is your only limit here. You will also need a simple windscreen to guard at least two sides from air movement. The stove doesn't blow out, but air movement dissipates the heat too much.
For burn time, 1.5 ounces of Heet burns about ten minutes. 2 ounces, about 13 to 14 minutes. You can put more than that in one of these stoves. To put the stove out, just letting it burn itself out is best. Have one going to boil, and a second stove to start up under a grill and simmer. Heck, they don't cost much.
The stove packs easy, weighs about an ounce, and as shown above with the Big Dummy standing on it, is very strong. Brushed aluminum finish so it doesn't look like an old beer bottle too. What else can you ask for?
And, oh yeah, it makes a great handwarmer. How many times have you been hunting, riding, etc, and would love to have something light and portable that would warm you up for a few minutes?
The stoves pictured are the regular SteverStove with 14 flame holes. I also now make what I'm calling the SimmerStove which has 7 flame holes. It burns slightly cooler and longer, for, well, simmering. Same price as the regular stove.
Now besides for the task of boiling water for coffee, rice, noodles etc, some have asked about cooking a piece of meat with this stove. So, I did a test.
Fired up the SteverStove and had a burger handy. I took an old cheapo frying pan out of my camp kit--many folks carry one like this but smaller in their bike kt.
Set the pan on the stove, of course with your windscreen, and watch the magic. Within seconds you'll hear the sizzle.
I flipped the burger over at 4 minutes, and it was finished in 6 minutes total. I had plenty of fuel left in the stove to cook longer. This was done outside with air temperature of 35 degrees.
I also tried this with the lid from my light steel camp kit. The instructions said use the lid as a fry pan. I was doubtful for its effectiveness as the steel is thin and won't distribute & transfer heat well.
And I was right: the stove was too hot for the thin steel and wouldn't cook the burger properly without holding the pan up above the flame, and the outsides got hot whereas the center did not. So it's thumbs-down to fry in the flimsy stuff unless you are stir-frying and keep the material moving around the pan to absorb the heat.
My conclusion for cooking meat is to use an actual fry pan, and also probably best to use a Simmer Stove as the regular stove does make a lot of heat, but that's up to each chef. I see no problem frying up a steak, pork chop or bacon on one stove charge.
I sell them for nine bucks each delivered to your door for this stove, best deal you'll find anywhere. You can contact me through a PM, or email to valstever@gmail.com which is also our Paypal address. I am keeping these in stock for quick shipments.
Thanks,
Shady Rascal
ShadyRascal screwed with this post 01-26-2015 at 09:37 AM
ShadyRascal is online now   Reply With Quote
Old 02-10-2009, 11:51 AM   #2
Hotspice
Satellites not acquired
Hotspice's Avatar
Oddometer: 5,533
Now that's a new one to me. I had NO idea you could use heet as a fuel for a fire.
So, what are the rivets for?
GREAT idea for a compact stove.
Cyclenutz.com motorcycle accessories
Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5.
Hotspice is offline   Reply With Quote
Old 02-10-2009, 11:56 AM   #3
ShadyRascal OP
Master of None
Oddometer: 6,398
There are two pieces slid together to make this stove, and the rivets keep them from coming apart. They probably wouldn't as they are stuck together pretty good, but I want these things tough as nails.
Old 02-10-2009, 12:02 PM   #4
sandmar
llama llama..rabbit
sandmar's Avatar
Oddometer: 3,309
Hiya Shady,
Got my stove in the mail yesterday. Good quality,great service,works as advertised Thanks for your prompt delivery .
sandmar is offline   Reply With Quote
Old 02-10-2009, 07:59 PM   #5
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
The HEET is Methanol. You can buy it by the gallon at most any hot rod shop.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 02-10-2009, 11:02 PM   #6
lightsdarkness
Oddometer: 4
is it a Budweiser aluminum bottle? Just looks like it to me. The top and the bottom.
lightsdarkness is offline   Reply With Quote
Old 02-11-2009, 07:46 AM   #7
MikeyT
Krusty Olde Pharte™
MikeyT's Avatar
Oddometer: 5,295
Shady, is it possible to just go to PayPal and send money to you there, including a shipping addy and a note of what it's for? Do you have any other products for sale?
MikeyT
99 Shadow Spirit 1100
"Non Illegitimi Carborundum"
MikeyT is offline   Reply With Quote
Old 02-11-2009, 08:18 AM   #8
ShadyRascal OP
Master of None
Oddometer: 6,398
Yes, no problem doing that, as many have thus far. My other products I sell are ATV related, skid plates bumpers racks etc.
Old 02-11-2009, 07:12 PM   #9
AngryScot
AngryScot's Avatar
Oddometer: 18,321
Mine just arrived.
in no wind
0-1:30
light to blossom of flame
@ 8:30
Rolling boil
12min the fuel was gone
Filled halfway.
Used a snowpeak pot with 4 3/8" dia
Not as fast as my pepsi stove at 4 1/2 minutes to boil but the lighting and blossom of the pepsi stove put it right at the same time frame.
nice, thanks shady!
⊕R1200GS⊕ For sale soon, snap it up and contact me.
⊕Zuma 125⊕For sale soon, snap it up and contact me.
Save $5 on Smugmug "so9RUAXlMm0bE"
AngryScot screwed with this post 02-11-2009 at 09:38 PM
AngryScot is offline   Reply With Quote
Old 02-11-2009, 10:09 PM   #10
ShadyRascal OP
Master of None
Oddometer: 6,398
Just FYI, my experience is that a lid on the pot speeds up boil times, and also a wider, shallower pot speeds the boil time as well.
But looks like it'll work just fine with your SnowPeak pot. Glad you like it and thanks for the review!
SR
Old 02-12-2009, 12:12 AM   #11
AngryScot
AngryScot's Avatar
Oddometer: 18,321
SR
I have been eye balling that damn tea kettle
Old 02-12-2009, 09:21 AM   #12
debaisley
debaisley's Avatar
Oddometer: 1,426
Got my stove , works great , i just used some rubbing alcohol from the medicine cabinet , and even that worked to get a mean flame.
debaisley is offline   Reply With Quote
Old 02-12-2009, 09:48 AM   #13
bigfoot
bigfoot's Avatar
Oddometer: 71
Just ordered two stoves. Paypal sent.
Dean
IBA 8535
bigfoot is offline   Reply With Quote
Old 02-12-2009, 08:31 PM   #14
30Bones
30Bones's Avatar
Oddometer: 4,634
Got both of mine today Steve, thanks a bunch. Now I just have to use them
30Bones is offline   Reply With Quote
Old 02-12-2009, 08:56 PM   #15
kalispell365
on the road to shambala..
kalispell365's Avatar
Oddometer: 126
send one up to me...paypal on its way,thank you!
kalispell365 is offline   Reply With Quote
Times are GMT -7.   It's 10:45 AM.
