Old 03-21-2012, 12:34 AM   #496
2upAussie990
Oddometer: 464
Originally Posted by Mark or Jack View Post
I sourced some pure methanol today, it is difficult to get small quantities here in Australia but luckily I have a neighbour who races sprint cars and has a supply
The stoves worked a treat, they definitely need a wind shield but are a good piece of kit.
If you're bike starts to run low mate just pour a bit in the tank, just watch you don't miss the next servo though if you roar past too quick on the meth.
2upAussie990 is offline   Reply With Quote
Old 03-21-2012, 01:35 PM   #497
Mark or Jack
BMW F 800 GS
Oddometer: 129
It's always an option
Are you using these stoves in Australia?
What fuel do you use?
my website
Mark or Jack is offline   Reply With Quote
Old 03-23-2012, 01:52 PM   #498
Noisymilk
Run What Ya Brung
Noisymilk's Avatar
Oddometer: 90
wind shield....my solution
Free bump because I love this stove!
So, yes, wind is a problem with any stove. Everywhere I've read, people are using random things as their wind block. I thought I might try one of these:
PIcked one up at my local mom and pop camping store (I like supporting small local business when I can) for 7 dollars. It folds up just as slick as it says.
You can see, these are designed for burning those fuel canisters from the buffet line. Shoots a single flame straight up. Great....but Stever Stoves have the flames from all around. First time I tried...lots of heat inside and not a lot up to the pot on top. So I played around with it a bit, and with some modifications (tin snips and a bit of a soup can) I came up with this:
And there it is cooking my udon noodles for lunch:
So the hole I cut is big enough that I can put a smaller pot right on the Stever for quick boiling water and the like, but small enough that my 8 inch frying pan sits on the coughlan's, not the Stever, and the heat gets distributed all along the bottom of the pan. The hole i cut wound up being 5.25" diameter. The soup can is 1" tall.
Early experiments caused some flaking of the paint. YMMV. I think i might clean it and use some bbq paint on it. We'll see.
Folded up:
Ok. Just an idea for y'all. It will get its first testing next weekend when my daughter and I camp for her birthday. I'll snap a few pics and post back.
Be safe all.
-Noisymilk
Low CC Touring Commences.
Noisymilk screwed with this post 03-23-2012 at 02:35 PM
Noisymilk is offline   Reply With Quote
Old 03-31-2012, 11:27 AM   #499
jon_l
jon_l's Avatar
Oddometer: 3,368
my new Steverstove
works great!
Initially I used some alcohol based, no-name brand automotive alcohol-based gas-line treatment that has been in my garage for 10 years (unopened). Result was a fireball the size of a melon.
Went out and found the recommended yellow bottles of Heet, and the stove works great! 2 cups of water was madly boiling in 5 minutes.
I have an ultralight MSR cannister stove which simmers well, and will come along for camping involving any real cooking, but for making coffee or tea, or just-add-boiling-water backpacking meals, the Steverstove is amazing. Maybe as a trail-side hand-warmer too?
CBF1000 & PCX150
jon_l screwed with this post 09-30-2012 at 04:42 AM
jon_l is offline   Reply With Quote
Old 04-02-2012, 09:55 AM   #500
jon_l
jon_l's Avatar
Oddometer: 3,368
Shady - you note that 1.5 ounces of Heet burns about ten minutes; since 2 cups of water boils in ~1/2 that time, I wondered about using less fuel. When I tried it with 1/2 the fuel (1 tablespoon) it didn't boil the water before it burned out. I haven't have time to experiment more yet.
Is there a minimum fuel level or volume for the Steverstove?
CBF1000 & PCX150
Old 04-02-2012, 10:54 AM   #501
ShadyRascal OP
Master of None
ShadyRascal's Avatar
Oddometer: 6,759
I have noticed when trying to burn very small amounts of fuel that I end up with the stove out of fuel before I get much done. So I just typically run the 1.5 ounce minimum except if I'm doing something very light duty, like warming a cup of water for instant coffee or something. Also, temperature and air movement outside affects things enough to where there's no hard and fast rule for how much fuel to use for a certain task. But if you fill the stove up towards the bottom of the radius on the inner piece, that's 1.5 to 2 ounces, and you'll get enough BTU's to boil a couple cups of water, a little lower level for smaller jobs. At 1 ounce or less, it just doesn't get going enough to do too much.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is online now   Reply With Quote
Old 04-11-2012, 04:02 PM   #502
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,484
Got it
Steve,
I just received the stove today. It is so small and light it is great to add to the gear.
Thanks,
Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 04-14-2012, 09:14 AM   #503
FL_biker
Dakar Withdrawl
Oddometer: 477
Got back from my latest deployment in Mid-March, and FINALLY had time to open the stove pkg that arrived while I was gone.
Figured I'd give it a try inside:
They're gonna make a nice addition to my camping gear (got the simmer and regular stoves)
Thanks again
Dave in Tampa
(Formerly Dave in Dusty Doha, Qatar)
Dave in Afghanistan
2011 Ride - Key West To Deadhorse - SPOTWALLA - Smugmug Photos
Ned Suesse on Stage 2 of the 2012 Dakar: "You would have had to have been a blind monkey to get lost anywhere today!!"
FL_biker is offline   Reply With Quote
Old 04-16-2012, 08:28 PM   #504
BarKnee
BarKnee's Avatar
Oddometer: 72
Just wanted to say thanks for for offering up such a handy bit of cooking gear. I finally got mine from a friend who ordered each of us one a couple of weeks ago.
Here's my version of a burner base and pot platform to offer up a little more stability while I'm staggering around camp.
The drilled laminate reduces the likelihood of me tipping the burner over, gets warm to the touch but shouldn't burst into flames.
Made the grill low enough to offer support for the cup but allows it to rest on top of the burner, breaks down for easy packing.
BarKnee is offline   Reply With Quote
Old 04-17-2012, 09:24 AM   #505
TonyKZ1
TonyKZ1's Avatar
Oddometer: 723
Wow, that's a pretty nice accessory for his stove. Looks like it works pretty good!
Tony
1997 Yamaha Seca II - mostly stock, Oxford Sports Style Heated Grips, Barkbusters Blizzard Cold Weather Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old 04-27-2012, 05:36 PM   #506
award900
award900's Avatar
Oddometer: 281
Nice.
award900 is offline   Reply With Quote
Old 05-01-2012, 01:19 PM   #507
VG44
VG44's Avatar
Oddometer: 613
Ordered two; payment sent by paypal.
PM Address
'10 BMW R1200GSA
SmugMug Coupon - Ga3PqQ6TYbYKA
VG44 is offline   Reply With Quote
Old 05-01-2012, 07:50 PM   #508
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
I made a similar stove when I was in Iraq, but out of an aluminum can. Yours looks a lot better than mine, though! I used denatured alcohol in mine (it's what I could find). it worked just fine, but boy, don't let someone walk by while you're cooking in the daylight and kick the burner! Holy crap, you can't see the flames that are burning you! You should've seen the dance and run I did.
I do believe I'll be ordering a couple of these in the near future.
"If guns cause crime, then all of mine are defective." Ted Nugent
www.dehmotorcycle.com
Motorcycle storage with a personal touch
seabee1 is offline   Reply With Quote
Old 05-01-2012, 09:09 PM   #509
ShadyRascal OP
Master of None
Oddometer: 6,759
I've talked to several service guys who said they made these out of various things when they were in Iraq/Afghanistan---whatever it takes for a hot meal!
Old 07-02-2012, 09:50 PM   #510
AeroEngineer
AeroEngineer's Avatar
Oddometer: 231
Just ordered one of each.
I love simple, reliable stuff. These should suit me perfectly.
-Robert
2010 Ural Patrol (mine)
2009 KLX250SF (hers)
2006 DR650 (???)
AeroEngineer is offline   Reply With Quote
Times are GMT -7.   It's 07:35 PM.
