Old 09-08-2012, 02:39 PM   #136
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,875
Bandit four cylinder...wide, CR500 swingarm....skinny. Hafta build a jack shaft to get power from wide to narrow.
Ever try to grind something that is hardened? It doesn't work. Starting with untempered sprockets gives us something easy to work with and cost effective. I would ruin the temper even if I could machine a hardened sprocket because I need to weld it to the splined hub.
I can't seem to find 520 sprockets to fit an 11 spline 3/4" shaft that are hardened and 14 tooth, otherwise I'd go that route.
Don't worry, I'll post pics when I have it designed and built, it's kind of confusing to try and explain in type.
larryboy is online now   Reply With Quote
Old 09-08-2012, 04:50 PM   #137
Nixels
Face fears - live life
Nixels's Avatar
Oddometer: 7,373
Originally Posted by larryboy View Post
... it's kind of confusing to try and explain in type.
Use a different typeface
Coffee first, then all your other mundane bullshit. Benjava
That tofu will kill you, stay away from it. Soy is the devils bean! moe.ron
SmugMug coupon: cwbkgu7KGL2D2/save $5
Nixels is offline   Reply With Quote
Old 09-08-2012, 05:26 PM   #138
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,161
My cbr has a narrow ktm swingarm. I got by using a spaced rear sprocket and by machining down the cs sprocket. Aligns perfect now. Probably had to go 1/8" out in the rear and maybe 1/4" in on the cs. Was a bitch to machine off the flange on the cs but a lot easier than designing a jack shaft
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 09-08-2012, 08:36 PM   #139
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,115
...thanks I need this.
Garthe is offline   Reply With Quote
Old 09-08-2012, 11:03 PM   #140
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,875
I'm an inch off, considered hacking up the swingarm...too many problems that direction, it'd hit the subframe if it got any wider.
I'm starting with a jack shaft for a go kart, I paid a ton of money for it, but it's well made from a chunk of billet with good sized bearings. The only snag was figuring out 520 sprockets and I finally have that figured out.
Man, things have sure changed since I started this project. Gonna try to scrape up some cash for a LithiumIon battery and an LED headlight.
Sorry it's not gonna be a chopper, Garthe.
Old 09-09-2012, 05:10 AM   #141
SwedeMix
SwedeMix's Avatar
Oddometer: 30
[/QUOTE]Sorry it's not gonna be a chopper, [/QUOTE]
Originally Posted by Tony P:
But in my view by far the most important piece of gear or equipment to get right is in your head. The right attitude. You cant buy that - but you can work on it!
SwedeMix is offline   Reply With Quote
Old 09-09-2012, 08:49 AM   #142
Garthe
Garthe's Avatar
Oddometer: 4,115
No worries, I'd follow any project your building.
Old 09-10-2012, 10:40 AM   #143
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,875
Got the repaired side cover back on and the XRR sprocket fitted yesterday.
I want to nail down the seat mounting, but need handlebars before I do, so I ordered up some Buell Ulysses bars.
Renthal has some FatBars with 4.5" of height, might not be enough and I don't like tall risers. I used to own a Uly and liked the sweep and all of that, plus they have 6.5" of height, so we'll start with those.
Old 09-14-2012, 10:26 AM   #144
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,875
Here's some pics of the splined hub and jack shaft assembly.
Machining and handlebars will happen next week, then we can make some real progress again.
Old 09-20-2012, 10:34 PM   #145
Nixels
Nixels's Avatar
Oddometer: 7,373
Splined hub
Old 09-20-2012, 11:45 PM   #146
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,875
Getting closer...
Got the handlebars today, glad I went with the Buell bars, they were the most outrageous highest rise longest sweep I could think of that would lessen the reach from where I want the seat.
Old 09-28-2012, 09:34 AM   #147
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,875
Wasted last weekend going to look at bikes, but I got to see JimmytheHogs bike for some inspiration.
I really, really want to do the 8" race light, but might have to settle for the lower priced torch.
Old 09-28-2012, 02:22 PM   #148
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,161
Toss a $25 HID from DDM tuning in the X2 and it's bright as hell. That's what I'm running on the CBR and it puts out a great pattern with a good clip, very impressive
Nessmuk
Old 09-28-2012, 04:45 PM   #149
Nixels
Nixels's Avatar
Oddometer: 7,373
I'm not mocking you, larryboy!
But you gotta take a seat to make a stand!
This seat is too slim.
But this one is Just Right! said little red riding hoodlum.
Can ya handle it?
Glad to get over there for a visual progress report.
Old 10-11-2012, 12:02 AM   #150
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 143
jjes man thats some serious work you are doing looking forward to seeing the finished ride.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Times are GMT -7.   It's 11:22 AM.
