Old 05-16-2013, 05:54 AM   #3331
Deans BMW
Granpa Hoon
Oddometer: 3,313
Ghazi, do you have a Tioga XL in your close outs?
If so, how much and I would like one.
Say hi to Hani from Pam
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Old 05-16-2013, 08:54 AM   #3332
teizms
teizms's Avatar
Oddometer: 1,727
hello
no tiogas that i have found yet - if i come across one i will let you know :)
teizms is offline   Reply With Quote
Old 05-16-2013, 09:30 AM   #3333
mud390
mud390's Avatar
Oddometer: 162
Ghazi,
The medium Lombard that you list is an old version? Which version? Are the liner's included? Thanks!
Kris
mud390 is offline   Reply With Quote
Old 05-16-2013, 09:36 AM   #3334
teizms
teizms's Avatar
Oddometer: 1,727
Originally Posted by mud390 View Post
Ghazi,
Kris
i think its a v2 with thermal liner
Old 05-22-2013, 09:57 AM   #3335
teizms
teizms's Avatar
Oddometer: 1,727
as seen on Facebook:
"loving my new suit"
Old 06-04-2013, 10:18 AM   #3336
teizms
teizms's Avatar
Oddometer: 1,727
feedback received over email regarding the Mojave:
OK, it's here! https://plus.google.com/photos/10639...L6GvYLF-ruduQE
Fit is near-identical to the trial suit, with additional armor. Again, I am 6'2" 195#. Inseam is *slightly* too long when not wearing boots, but I don't ride without boots. The sleeves fit well and offer adjustability to suit my body. I got the stock color scheme, which is silver mesh with black solid panels. Browse through the pics linked, it will show the nature of the mesh panels and the elastic areas. Armor to the shoulders, back, forearms, knees, and shins. I ordered mine with the thermal liner (it comes stock with an internal rain-suit). Time to arrival from ordering, receiving trial suit, confirming size, and final receipt was about 31 days. Ghazi was communicative throughout the process.
Fitment and donning/doffing suit:
Suit fits like I imagined after fit-testing the trial suit. Latge tall suited my 6'2: 195# frame well.
The sleeves fit perfectly with the 3-button adjustment system on upper and lower arms. The sleeve cuffs have infinite adjustability with the velcro closure. I'm not sure I would use a gauntlet-style glove with this suit, although I am sure you could make it work. I opted for a shorter cuff glove after receiving the trial suit. The arm adjustments are set it and forget it, the cuffs will probably be adjusted each time.
The torso and waist fit well with some room for layering if necessary, but it is currently WAY too warm/hot to try the waterproof liner and/or the thermal liner. Both zip in/out together or independently of each other. The inseam is a bit long when barefoot (I wear a 33 inch inseam), but in boots, there is the slightest drag at the rear cuff, which is inconsequential to me except for some potential cosmetic issues down the road. The waist adjusts nicely with the velcro belt, which does NOT interfere with the full body zipper.
The lower legs have ankle and mid-calf adjustments which allow you to tailor the fit to your contours with boots on. I would not tuck the suit into boots. The leg adjustments are also set it and forget it, unless something drastic changes with your underlayers.
The way I dress is to put my boots on, place right leg into right pant leg, put suit on shoulders, then bend down to secure right leg zipper, then full body zipper. I use the reverse to take it off. It takes a few seconds longer to put on than to take off (45 seconds on 30 seconds off). The zippers have a nice Teiz Motorsports zipper-pull that will help when gloved-up. I did lose the right leg zipper-pull after a few days, but it was probably due to my inattention when zipping up.
The materials seem up to par. The exterior mesh (view the pics in the link provided) truly breathes, especially when in motion. The stitching appears to be top-notch. There is a distinct lack of pockets, though. There is a waterproof left breast pocket with zipper closure and a right forearm pocket with velcro closure. There is also a large upper back pocket with velcro closure that could be used to hold the liner(s) and maybe a hydration system, but it is inaccessible unless you remove the suit. I tried to zip down to the waist and access the rear pocket, but I don't have that much twist left in this body... The interior mesh is similar to other suits I have seen, and does not add or detract in any way (except when my right boot gets stuck in it while donning/doffing *doh*)
The armor seems to be good quality, residing in the shoulders, upper back, forearms, knees, and shins. All armor, with the exception of the back plate, feels rigid on the outside with foam internals. The back plate appears to be a pure foam solution, and I will likely replace it with a Forcefield back protector, unless counseled otherwise. The knee and shin armor are independently adjustable. the knee armor has a pocket (see link) that allows quite a bit of adjustablilty. The shin and forearm armor require you to move the armor within its nestled location.
Riding impressions: I have been using the suit for my daily 24 mile round trip commute and it has performed flawlessly in terms of ease of use. I hope to never test its crash-worthiness.
The suit breathes well. In fact, compared to the trial suit, I could wear it around the house and garage without overheating. On the street, as long as you are in motion, the breeze helps cool you down. The full coverage keeps the sun off of your bare skin, which is a HUGE reason the suit works so well when not moving, and helps even more when you are.
The left breast pocket is sufficiently large to hold cell phone, wallet, actually quite a bit of stuff before becoming uncomfortable full. I have not yet figured out what to put in the left forearm pocket, but it will likely mimic the emergency info carried under my bike seat. Might also add a AAA flashlight and paper/pen.
The large rear pocket is likely very useful, and I would like to hear the designer's thoughts on why it was included. Other than holding the liner(s) and maybe a hydration pack, I'm not sure what else you would carry in there. It IS big enough to hold a change of clothes, some books, a pilllow, etc.
Well so far, there it is. I will continue to update this post as I gain more time in the suit. Hope this helps anyone looking for a one-piece, affordable, mesh based suit.
Thanks for reading!
Old 06-06-2013, 09:07 AM   #3337
teizms
teizms's Avatar
Oddometer: 1,727
Custom Sahara Jacket & Pants
Old 06-10-2013, 02:29 PM   #3338
teizms
teizms's Avatar
Oddometer: 1,727
Air Shell Review & Pics:
http://www.advrider.com/forums/showthread.php?t=893596
Old 06-12-2013, 09:34 AM   #3339
teizms
teizms's Avatar
Oddometer: 1,727
Now available in our discount section:
Power shell - hi viz - large
Power shell - light gray - 2xl
these are popular sizes and will not last for long. easy way to save $200
http://store.teizms.com/discounts
Old 06-17-2013, 10:33 AM   #3340
teizms
teizms's Avatar
Oddometer: 1,727
Finally - the complete Sahara suit
Old 06-19-2013, 12:28 PM   #3341
teizms
teizms's Avatar
Oddometer: 1,727
Mojave review:
http://www.vfrdiscussion.com/forum/i...ne-piece-suit/
Old 06-20-2013, 09:38 AM   #3342
davesax36
Oddometer: 36
So I've read pretty much this whole book of a thread in the last couple days. Ghazi, I'm interested in riding out to meet with you and possibly try on suits. It would be an easy trip for me, since I'm only in Fort Worth. Having owned a Roadcrafter, and with the possibility of soon relocating back to the East coast, I'm very interested in a Power Shell. I'll send you a PM, but I wanted to get in on this thread. I met the 6th gear (or whatever his name is) guy at the Dallas MC show last year. He did seem very shady indeed. Great honest reviews here. I hope to meet you soon.
davesax36 is offline   Reply With Quote
Old 06-20-2013, 10:00 AM   #3343
teizms
teizms's Avatar
Oddometer: 1,727
hey,
since we don't have a office or a warehouse here anymore - i don't have too many sizes with me. so, depending on your size, it would probably have to be brought in via our trial shipping service anyway. However, i can show you a Power Shell so that you can familiarize yourself with the features and materials. we will exchange contact info via PM
thanks
Old 06-21-2013, 11:29 AM   #3344
Kraonn
Oddometer: 1
Arm strap retrofit?
I've got an early model AirShell and I love it. Like others I have noticed that the arm adjustments (the velcro strap style) don't pull down as snugly on my arms as I would like. Are there "approved" mods or alterations you would recommend to address this?
Kraonn is offline   Reply With Quote
Old 06-21-2013, 03:29 PM   #3345
teizms
teizms's Avatar
Oddometer: 1,727
this can be be easily done at any local alterations shop.
they can make the strap smaller and adjust according to your liking -so that if its more snug.
Times are GMT -7.   It's 07:15 PM.
