Old 06-01-2004, 12:45 PM   #1
Robert OP
KickAss Adventurer
Robert's Avatar
Oddometer: 1,721
Windscreen chop
I've seen that most guys use a hacksaw to cut their windscreens...is this the general consensus??? What about a coping saw??? I wanna cutdown the tallscreen on my Gran Canyon.
I suppose a bandsaw would work nicely, but I don't have a fancy workshop...it will have to be by hand.
Any advice appreciated......
Robert
www.nakedtraveler.net
a Skorpion and a Gran Canyon....sold the the poor Elefant
Robert is offline   Reply With Quote
Old 06-01-2004, 12:57 PM   #2
Rad
Just me
Rad's Avatar
Oddometer: 12,172
I used a zig saw with a blade for plastics. I taped both sides of the screen then cut it.
I used a palm sander to round and sand the edges, finishing with 600 wet/dry ...Very smooth.
I have a Dremel now, so next time I will use it
Rad is offline   Reply With Quote
Old 06-01-2004, 01:00 PM   #3
Robert OP
KickAss Adventurer
Robert's Avatar
Oddometer: 1,721
I do have a jigsaw....is it possible to cut on the curved surface???
Robert
Old 06-03-2004, 10:40 AM   #4
AntWare
Lost In Translation
AntWare's Avatar
Oddometer: 16,483
trying mounting the jigsaw in a vice or something similar and run the plastic through the blade, it should be easier to control, get a better finish, and save handwork later on.
Be careful not to restrict the motor.
Choose Life. Choose a job. Choose a career. Choose a family.
Choose a fucking big television.
Choose sitting on that couch watching mind-numbing, spirit-crushing game shows,
stuffing fucking junk food into your mouth.
Choose rotting away at the end of it all, pishing your last in a miserable home,
nothing more than an embarrasment to the selfish, fucked up brats you spawned to replace yourself.
Choose your future. Choose life.
I chose not to choose life, I chose something else instead.
AntWare is offline   Reply With Quote
Old 06-03-2004, 11:00 AM   #5
Stephen
Stephen's Avatar
Oddometer: 3,188
Cutting plastic. Ah. Material and thickness matter, as does feed speed and cutting speed. Acrylic (plexiglass) is fairly hard, so a small-toothed (but not extra fine) saw is appropriate. Cutting speed should be lower than for metals so you don't melt material too far from the face of the cut. Feed speed is moderate; slow enough so the material on the edge can cool before the blade passes so the cut doesn't weld itself back together. Clearly, a lower cutting and feed speed will help keep the blade itself cool.
Lexan is softer and IIRC higher melting-point, thus implying larger teeth and slower cutting and feed speeds, but has seemed to cut about the same as acrylic though not as brittle.
Hacksaw works for straight cuts on either. Coping saw can be used carefully for curves. I've had horrible experiences with electric jig saws on plastics, but mine is old and loose. Real easy to make chips and cracks with it. X-acto saws yield a beautiful edge for straight cuts, but are exasperatingly slow.
ABS is a real PITA to cut. Hot knife or spiral saw are the only things I've had success with.
So now, that's more than you wanted to know, and some of it's probably wrong.
Stephen is offline   Reply With Quote
Old 06-03-2004, 01:50 PM   #6
Farnsrocket
Manos arribas!!!
Farnsrocket's Avatar
Oddometer: 3,983
Laugh
Farnsrocket is offline   Reply With Quote
Old 06-03-2004, 02:50 PM   #7
Robert OP
KickAss Adventurer
Robert's Avatar
Oddometer: 1,721
Thanks all....
I guess I'll just get a fresh hacksaw blade and give it a go.....I should only have to worry about getting the cut straight..
Robert
Old 06-07-2004, 12:14 PM   #8
Sgt.Floyd
delinquent
Sgt.Floyd's Avatar
Oddometer: 1,357
Thanks all....
I got great results using a table saw. I have an 80 tooth finishing blade in it, and the cut was very clean and very striaght, cleaed it up with a sanding drum in the dremel tool. If you have access to a band saw, that'll work too.
"It's a lonesome deal - but after a couple of shots of beer my heart began to go again. Bare the word - never ease up!"
"Don't be fooled by the quaintness of New England. It's like that because they hate change." -kbasa
my music
Sgt.Floyd is online now   Reply With Quote
Old 06-07-2004, 12:40 PM   #9
GENO
GENO's Avatar
Oddometer: 32
Question i need a taller screen
Hello GENO here,please excuse poor english and spelling. I ride a black GS 1100 with a standard screen,hoping to get advise on fitting taller screen. |s it worth it ,the cost ,etc etc. The weather here in Ireland is great for biking,looking to take GS down to County Cork. Thanks for reading and any replies . GENO
GENO is offline   Reply With Quote
Old 06-07-2004, 12:47 PM   #10
Sgt.Floyd
delinquent
Sgt.Floyd's Avatar
Oddometer: 1,357
GENO there is a ton if this info in the "Gspot" forum. including a whole FAQ here
my music
Times are GMT -7.   It's 03:25 PM.
