Thread Tools Rating: Thread Rating: 759 votes, 4.99 average. Display Modes
Old 02-14-2012, 02:27 PM   #4291
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,596
I run Damplifier Pro as my base vibration layer. Any of the brand names are fine.. just stay away from the asphalt based ones (like the roofing stuff you find at home depot that some people recommend) as the asphalt based stuff will run/make a mess in the heat. The brand name products are butyl rubber instead of asphalt. Basically mass = effective so heavier is better.
The damplifier/dynamat/fatmat layers are more anti-vibration than noise barrier. They get rid of rattles & such caused by vibrations (like from a subwoofer) and should be used to change the frequency of any body panel vibrates.
They are not a noise barrier.
A contiguous layer of mass loaded vinyl is the number one thing you can do to stop sound! It is a NOISE barrier.
Luxury Liner is a mass loaded vinyl (one of many available).
Luxuxry Liner Pro is that MLV bonded with CCF foam... the CCF foam is kind of the "final piece" in that it is a high frequency arrestor (and overkill).
I used Damplifier and then Luxury Liner Pro as my sound barrier.
They made me a deal because of the quantity I bought that made the upgrade from Luxury Liner to LLP @ no charge so I figured why not.
Here's a photo of my Luxury Liner Pro:
this stuff is HEAVY (and that mass is what stops sound) - I purchased 468 lbs of it.
This is what my floor looks like under the floor - all that black stuff is mass loaded vinyl:
Thus far my van is about 2/3 sound proofed and it is much quieter inside than an average automobile (it was a hollow drum when I started). My goal is "Mercedes S Class" quiet when I'm done. I don't know if that can be achieved with the huge windows but we'll see.
There are lots more details on sound damping in my van build thread:
http://advrider.com/forums/showthread.php?t=715683
Hope this helps
Geek screwed with this post 02-14-2012 at 02:36 PM
Old 02-14-2012, 02:31 PM   #4292
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,596
Final thought on sound damping:
If you are on a budget and want to quiet a van... start at the bottom and work up as most of your noise comes from the road.
1) do the footwells between you and the motor
2) do the floor behind you
3) do the doors around you
That will make more than a 60% noise reduction in the average van.
Old 02-14-2012, 02:34 PM   #4293
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,596
One more "final thought"
You can chase noise forever.
As I have made the van quieter and quieter you notice new sounds (that were drowned out previously). Currently I can hear the noise of the wind flowing over my windshield. I don't think I can do much about that
Old 02-14-2012, 02:40 PM   #4294
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,959
I really need to do my footwells.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 02-14-2012, 03:16 PM   #4295
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,454
Originally Posted by trailer Rails View Post
I don't see any need for all/4 wheel drive if all you do is drive on the road. All it does is make the drive train more complicated and add several hundred pounds to the vehicle. It also adds to the price. Where I live we get plenty of snow and ice. I run 4 good snow tires and I can go anywhere I want. All 4wd does is allow you get moving faster when conditions are crappy and then hit other objects harder when you cant stop or turn. All vehicles have 4 wheel brakes and 2 wheel steering.
Now for offroad driving, I can see the need for 4wd. But as you have proven in the above pictures, it is not really necessary either.
I feel the intense need to debate but...no.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 02-14-2012, 04:25 PM   #4296
Mr. J
Oddometer: 9,655
.... I can hear the noise of the wind flowing over my windshield....
this is why i am reluctant to put roof racks on any vehicle. in the windshield instance, would one of those bug deflector gadgets change anything?
Mr. J is offline   Reply With Quote
Old 02-14-2012, 04:47 PM   #4297
johnson357
Bad Monkey Racing
johnson357's Avatar
Oddometer: 1,333
Originally Posted by mark883 View Post
Let's soundproof this thing!
Well, maybe not soundPROOF, but at least a little less loud.
Do this to your doors, and they actually sound like a Mercedes when you slam the door.
Next up, is the roof, which is actually a Giant Tin Tympani Drum.
That sticker on the steering wheel makes it fast though!
johnson357 is offline   Reply With Quote
Old 02-14-2012, 04:57 PM   #4298
johnnyadventurepants
johnnyadventurepants's Avatar
Oddometer: 492
Hey Ford van dudes! Buy my van for cheap and get new tires and nice rims. Plunder it for parts!http://advrider.com/forums/showthread.php?t=764586
2008 WR250X/R
johnnyadventurepants is offline   Reply With Quote
Old 02-14-2012, 05:00 PM   #4299
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,596
I wondered about that.. the thing is that it is a mighty steep/short nose and my head is 5 feet above that deflector.
Old 02-14-2012, 07:12 PM   #4300
Wastegate84
Wastegate84's Avatar
Oddometer: 77
96 XR650L
07 TRX450
Wastegate84 is offline   Reply With Quote
Old 02-14-2012, 07:14 PM   #4301
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,959
Scarlet Fever
Old 02-14-2012, 08:03 PM   #4302
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,269
Saw this coming out of Mexico in Douglas, Az. It probably 6-8 blocks headed north from the border crossong with Agua Prieta. Sorry about the crappy photo, it was on the fly and I kinda saw it at the last moment. My main concern was getting a good hot shower. It's like a miniature VW bus, length about 10lf and height aout 5lf challanged.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 02-14-2012, 08:03 PM   #4303
mark883
Holding up Michoagán
Oddometer: 1,611
Wondered when you'd show up.... the poor van is just glad the monkey sticker is still attached.
But that sticker is not going anywhere... there's probably a dead goat head hiding underneath it.
Looks like a Sprinter yard sale in my Dad's barn.
Geek- thanks for the handy info. I won't be doing the floor under the cargo area, but anything I can do to make the cab quieter will help. I'm going to work on the slider door too. That's a like a steel barrel.
mark883 is offline   Reply With Quote
Old 02-14-2012, 08:05 PM   #4304
ballistic_ken
Helmet hair victim.
ballistic_ken's Avatar
Oddometer: 5,374
So, my van has a cargo area on the roof, but no ladder to get up there.
Who / where has the best ladders for climbing up? My searches only show ladder racks.
Thanks.
Running down a dream!
ballistic_ken is offline   Reply With Quote
Old 02-14-2012, 08:11 PM   #4305
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,959
Thanks.
I've bought a few things from these guys:
http://www.trucknvans.com/Van-RV-Lad...ries-s/747.htm
Thread Tools
Times are GMT -7.   It's 10:52 PM.
