Old 06-07-2004, 07:55 PM   #1
dragoon OP
I'm the REAL Dingo Joe
dragoon's Avatar
Oddometer: 23,180
Water in the fuel (airhead)
I was coming back from BYOBGYNII Sunday and my '88 GS started backfiring. It would run for a while then it would backfire, run, backfire several times. I pulled over and it died. I tried to start it and it would fire then quit.
What I know:
The last gas I purchased was cheapo.
The cap on my Dakar tank has the little tit broken off where the vent tube attached and has a pin sized opening (it has been like this for years)
It rained like a mother on Friday. No problems Fri. or Sat
What I did:
I dumped most of the gas out of the tank and emptied the float bowls and tapped on the floats.
Checked the spark plugs to see if they were carboned (they weren't)
Pulled the wires from the coil to see it they may have been corroded
It started and I rode 1/2 mile to gas station with no problems
I filled it with Citgo 93 (only station around)
What happened:
It started and I rode 500 miles home with out a hiccup
So will an airhead backfire, hesitate and keep on runing with moisture in the fuel?
What do you think?
Also the carbs have just been rebuilt and have 500 miles on them. It back fired once (one pop) before the BYII trip.
The bike has 102,000 miles
Everyone should be so lucky as to be able to ride a motorbike through the Himalayas.
- Misery Goat
daveology rule #143 - never ever pass up a chance to hear a band that has a stand up bass -Mutineer
dragoon is online now   Reply With Quote
Old 06-07-2004, 08:20 PM   #2
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,338
Hmmmm. You bet they'll stumble if there is water in the bowls. You did the right things with the carb bowls and tank. I'd go the extra step and clean off the main jets and emulsion tubes. See the diagram on the Bing Agency's web page here
Oh and get a new filler cap with a hose and one way check valve.
You should also check the electrics for issues by doing the following:
Start the bike and let it idle.
Take you garden hose or spray bottle and wet the sparkplug cables. If the bike caughs or stutters you may have a cracked cable. The same goes for the coil. How old is yours and what color is it? I believe that the newer ones are gray. The older/stock coils eventually develop small hairline cracks. Under certain really wet conditions water will seep into the cracks and short out the coil causing stalling.
Do you have any inline fuel filters? If not, you should ....especially if your PD tank is metal as they tend to accumulate debris which can enter the carb and casue the same symptoms.
Hope this helps.
Cheers,
Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Old 06-08-2004, 04:59 AM   #3
dragoon OP
dragoon's Avatar
Oddometer: 23,180
Hope this helps.
Cheers,
Jorge
Thanks Jorge! I'll give these things a try. The coil is new. The old one did exactly as you said and it left me sitting on the side of the road in the rain
- Misery Goat
Old 06-09-2004, 01:58 PM   #4
bigrichard
bigrichard's Avatar
Oddometer: 2,242
When you pull the float bowls look at what's in them
Water, being heavier than gas, will form a bubble at the bottom of the bowl
Easy to see
bigrichard is offline   Reply With Quote
Old 06-09-2004, 02:19 PM   #5
Queen
Escapee
Oddometer: 24,469
That wasn't water, I saw Paul peeing in your tank - too far to the potty I guess.
Queen is offline   Reply With Quote
Times are GMT -7.   It's 02:26 PM.
