Old 11-14-2012, 06:31 AM   #76
BikerBobber
Trying to get lost
BikerBobber's Avatar
Oddometer: 190
Here are some pics of the front end
Sent from my mobile.
Bob.
formerly KLRbobber
FEEDING MY 'MID-LIFE' CRISIS....
My translab adventure http://bobandmike10x10.blogspot.com/
BikerBobber is offline   Reply With Quote
Old 11-26-2012, 05:54 PM   #77
BikerBobber
Trying to get lost
Oddometer: 190
Bob.
formerly KLRbobber
Old 12-31-2012, 06:40 AM   #78
pingvin
pingvin's Avatar
Oddometer: 273
Hi,
Got a 2009 KTM690ER but have more or less all parts for SMC (wheels, forks, shock, brakes). Planning to also have 19/17 DS setup and use SMC 17x5"rear wheel.
Front, I've got a SMC hub from a damaged wheel and found the below 19" rim on internet. It's a MX rear wheel and I think 2.5" wide. Will this fit? How about spokes?
Does it soud like a good plan? Planned to use ER forks but can use SMC forks if a clash issue.
2009 KTM 690 Enduro R (converted to SMC)
2010 KTM 530 EXC-R
2006 Suzuki RM-Z 250
1981 Husqvarna 520 AE
pingvin is offline   Reply With Quote
Old 12-31-2012, 08:36 AM   #79
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,088
19'' front wheel on KTM690!
The rear wheel will work great with the front 19'', normally we run a 4.25 x 17 so you can use the 150/70-17 and have much better tire choices for.
We can modify the rim to work with the front hub, it looks like a 2.15 not a 2.5 which would be best with the 110/80-19 tires. It would be 235 to lace your hub/rim with new stainless steel spokes/nipples.
thanks zach
Originally Posted by pingvin View Post
Hi,
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 01-01-2013, 05:49 AM   #80
pingvin
pingvin's Avatar
Oddometer: 273
thanks zach
Thanks. OE for SMC is 160 so 150 should be OK? Also new KTM 1190 Adventure is 17" 170 rear so hopefully that size will be available from more manufacturers, believe conti trail attack from factory.
Thanks for offer, bit inconveneint (cost) with shipping from europe back and forth and added tax (unless sent as warranty :) ) but might do it no one around here can do it.
2010 KTM 530 EXC-R
Old 01-03-2013, 01:33 PM   #81
Built to Last
Oddometer: 3,088
Options?
Hi,
Yea we do have to custom drill the rims to make it work.
The other option is shipping a rim and spoke kit to you to lace it up.
The best option would be the 2.5 x 19 with a 110/80-19 front, maybe you can sell the 2.15 x 19 or save for your dirt bike.
The 150 will be ok, but the 160 is better.
thanks zach
PS from Woody: picking rim/tire combos is often a rider preference,,,folks liking to drift/spin the tires prefer smaller/narrower combos...things to consider:
bigger tires although theoretically having more grip area are also heavier, thus contributing to increased un-sprung weight as well as rotational mass...so a smaller bike ie with less HP will actually suffer more from the change....
usually there are trade-offs ranging from performance to the aesthetic....BWOE i just looked at this stunning Norton Commando cafe racer in the shop,with it's matching 2.15x19 front and rear rims sporting identical 4.10x19 tires...the rear just looks like it is way to skinny for the job,,not to mention few performance tires are available for it....so in this lucky case switching to a 120/90x18 would be a practical improvement ie tire availability,,,an aesthetic improvement ie ie better proportion and a technical improvement
at the expense of not being OEM.
woody
woody's wheel works screwed with this post 01-05-2013 at 04:02 AM
Old 01-03-2013, 04:07 PM   #82
pingvin
pingvin's Avatar
Oddometer: 273
Actually haven't bought the rim yet and the seller said it was 2.5" so maybe I won't buy it then.
If I send you the hub, how much for rim+lacing. If you can use the nipples from the damaged wheel, I've got those. Maybe several options for rim (orange?)?
The 150 will be ok, but the 160 is better. It will basically fall off the edge once you get there.
OK. Not many 160 dual sport tyres that i can find. ContitrailAttack and Anakee 3 have 170, that should be fine I guess (know some actually prefer 180 for track).
2010 KTM 530 EXC-R
pingvin screwed with this post 01-03-2013 at 11:18 PM
Old 01-17-2013, 04:46 AM   #83
meteorite
MoreDust
meteorite's Avatar
Oddometer: 5
Rim width
Woody, man how handy!!! I am considering getting a second rear rim for my 690 Enduro R. One will stay setup for road use and the other with the knobbies for the off-road stuff. I am looking at the Excel rim with Rad hub for the off-road stuff and keep the stock for the road. There are 2 widths on the KTMTwins site, 2.50 (stronger) and 2.15 (strongest with more tire choices) What do you recommend?? What are the considerations?? Thanks
"Some of you will give up. Some of you will even try to run. I warn you, until now no one succeeded. When the Legion doesn't get you, the Arabs will. When the Arabs won't catch you, the desert will. And when the desert doesn't devour your measly corpses, then I will. I wouldn't know what's worse".
Major Foster "March or Die"
meteorite is offline   Reply With Quote
Old 04-01-2013, 09:17 PM   #84
renogeorge
Oddometer: 315
I have been through several threads including this one. I must be going in a little different direction with my 990 Adventure. I am fine with the 18/21 combo. But I would like to go tubeless. Can you recommend anything short of changing wheels? Tubliss???
Thanks and apologies if this is the wrong place for the question.
renogeorge is offline   Reply With Quote
Old 04-02-2013, 05:18 AM   #85
Built to Last
Oddometer: 3,088
2.15 or 2.50 on rear KTM 690R,,,what's best??
Originally Posted by meteorite View Post
Woody, man how handy!!! I am considering getting a second rear rim for my 690 Enduro R. One will stay setup for road use and the other with the knobbies for the off-road stuff.... I am looking at the Excel rim with Rad hub for the off-road stuff and keep the stock for the road. There are 2 widths on the KTMTwins site, 2.50 (stronger) and 2.15 (strongest with more tire choices) What do you recommend?? What are the considerations?? Thanks
since those ar the two options you give me..id recommend the wider rim for road use and the 2.5 for off road,,,
however,,if it were my bike,,i'd leave the stocker's alone for off road and build a 19/17 setup with tubeless setup...this set up will rock your world on anything the slab can dish out to you...an amazing transformation...better than sex from what i've been told
woody
there's a fellow from australia who did a great review on his set-up,,'human one' is his advrider handle i believe
Old 04-02-2013, 05:27 AM   #86
Built to Last
Oddometer: 3,088
KTM 990 adv wants to go tubeless,,
forget the tubliss for on road application besides none of their sizes are compatible with your rim sizes...
somewhere in this forum i described how to seal your rims...that's one option...
or,,,
you can send your rear wheel in and we'll seal it for you for $99 with one year warranty....OBTW,,,we won't seal your front because it doesn't sport a safety bead
FYI,,we highly recommend Superlacing the rear because that set-up provides the highest gauranty you won't ever be mucking with truing your wheel again...if not that then minimally re torqing/truing your wheel is a good investment...ie to keep from having to turn the nipples and possibly ruining the sealing job.
holler
woody
Old 04-03-2013, 03:07 AM   #87
sproot
Sturdy Adventurer
Oddometer: 156
Hi Woody
Still loving my 19/17 setup on the 950 Adventure, truly can do anything now
Love it so much, in fact, that I've worn the wheel bearings out What size are they (rears, at least)?
NB: This is the Capo / RAD-hub version, not the stock KTM hub (or I'd know what size they were! )
Cheers
950 A (04)
sproot is offline   Reply With Quote
Old 04-04-2013, 09:03 AM   #88
Built to Last
Oddometer: 3,088
Wheel bearings for Rad rear cush hubs.
The bearings in the hubs they use on the rad hubs are as follows
Hub disc side-6205 2RS
Hub drive side 60/28-2RS x 2
Carrier- 60/282RS x 2
We have some in stock for 10 ea+ shipping.
thanks zach
Originally Posted by sproot View Post
Hi Woody
Cheers
Times are GMT -7.   It's 02:17 AM.
